I made one adaptation before completing this scan, and it is this:
Carbon Fiber MFD
17 - Instruments
Adaptation - 10
Select “display depiction”
Change to “Version 2” (default is Version 1)
Monday,29,February,2016,20:48:59:53379
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: [deleted] License Plate: SPBLAT
Mileage: 7522km-4673mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 32 3C 42 44 52 55 5F
75 A5 A9
VIN: [deleted] Mileage: 7522km-4673miles
Address 01: Engine (J623-CXCB) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 D HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 091D00324464002F1000
Shop #: WSC 00066 790 00060
ASAM Dataset: EV_ECM20TFS0205G0906259D 001002
ROD: EV_ECM20TFS0205G0906259D_VW37.rod
VCID: AF2E5FF2F6CD4F4657-80FA
Readiness: 1010 0101
Part No SW: 0D9 300 020 J HW: 02E 927 770 AQ
Component: DQ250-6V MQB H53 4902
Revision: 06253104 Serial number: TFK01505290519
ROD: EV_TCMDQ250021_AU37.rod
VCID: 9C74983E977BC4DE02-80C8
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 61435000000369
Coding: 01FA6BA154200974007A020241C36880D62A9000408216B616435053C089
Shop #: WSC 01383 790 50316
VCID: FAB8BEA67D0F5AEEB0-80AE
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 247
Mileage: 2222 km
Date: 2015.11.30
Time: 12:21:20
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0370706267
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: BA387EA63D8F9AEEF0-80EE
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5GM 907 044 A HW: 5GM 907 044 A
Component: Climatronic H03 1001
Revision: 00001K01
Coding: 00020014200100000105000012111402
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: C2C80646555FD22EA8-8096
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Revision: -------- Serial number: 86582705151847
Coding: 00111A464041A2E969E44000001407201800000000000000000000000000
Shop #: WSC 00066 790 00224
ROD: EV_BCMBOSCH_AU37.rod
Slave 1:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150515 043 0581
Serial number: 150711202536
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S5Y15M06D02H17M37S05
Coding: 90A8DD
Subsystem 3 - Part No SW: 5GD 959 591 HW: 5GD 959 591
Component: J245 PS60.036 H06 0150
Serial number: 03694817012302150844
Coding: 181803
563221 - Databus
206085 - Remote Control
B1311 54 [008] - Missing Calibration / Basic Setting
Fault Frequency: 56
Reset counter: 139
Mileage: 358 km
Date: 2015.10.17
Time: 16:30:02
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39491514905317
Coding: 0031165011
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_VW37.rod
VCID: C7DE17527E7DF7067F-8092
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0400
Serial number: 23041503272350
Coding: 01045600FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
ROD: EV_ACCMRRBoschVW372_AU37.rod
1542 - Sensor for Automatic Distance Control
Reset counter: 139
Mileage: 7205 km
Date: 2016.02.28
Time: 14:01:00
Component: AirbagVW20 009 0825
Serial number: 003GCR024YR$
Seat occupant detection; front passenger side:
Component: BF-Gewichtss. H11 0021
Serial number: IBH0000J15000356XM0B
Coding: 303131
Subsystem 2 - Part No SW: ----------- HW: 480 001 206 15
Serial number: 3570000000087A61641F
Subsystem 3 - Part No SW: ----------- HW: 480 000 206 15
Serial number: 358000000002A2547418
Subsystem 4 - Part No SW: ----------- HW: 480 402 005 15
Serial number: 3510002A51B0CB32215V
Subsystem 5 - Part No SW: ----------- HW: 480 401 805 15
Serial number: 3520002A31A2DCD54087
Subsystem 6 - Part No SW: ----------- HW: 480 400 206 15
Serial number: 3550002B11B41484B1F1
Subsystem 7 - Part No SW: ----------- HW: 480 400 206 15
Serial number: 3560002AF1B4148482EC
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150602400171
Coding: 0C10
ROD: EV_SMLSVALEOMQB.rod
VCID: F3A693825A652BA6F3-80A6
Part No SW: 5G1 920 856 A HW: 5G1 920 856 A
Component: KOMBI 342 6420
Coding: 0BAD091AED98CF0502886A0B5000000000000000
VCID: AC1448FEC7DB345E72-80F8
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2223
Revision: -------- Serial number: 17061510002329
Coding: 0101000830085900FB00023B1C0F00000001050000000000000000000000
Shop #: WSC 00066 790 07027
ROD: EV_GatewConti.rod
VCID: F5A2AD9A54113596DD-80A0
Subsystem 2 - Part No SW: 5G0 959 442 S HW: 5G0 959 442 S
Component: E221__MFL-DC1 H10 0040
Serial number: 29150000495270015124
Coding: 35FFFF
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000144912004
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: B424509E1FEB6C9E2A-80E0
Address 32: Differential Locks (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 E HW: 0CQ 907 554 E
Component: Quersperre H52 8042
Serial number: HA1-00031.03.15
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
Address 3C: Lane Change (J1086) Labels: None
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H11 0071
Serial number: 0369530774
Coding: 02011103
ROD: EV_HREntryHella_SK37.rod
VCID: BC3478BE37BBA4DEE2-80E8
Lane Change Assistant 2:
Component: TSG FS 020 0041
Serial number: 240615060505EE
Coding: 003E13200000040000000000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: C3C603424A45DB26A3-8096
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D
Serial number: 00000000000001577080
Coding: 011000
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 9302
ROD: EV_SteerAssisMQB.rod
VCID: B73E67920E9D87860F-80E2
Component: TSG BFS 020 0041
Serial number: 180615060505OT
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D
Serial number: 00000000000001495696
Coding: 091000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 021A01010B000400
ROD: EV_HeadlRegulVWAFS_SE26.rod
VCID: C0CC0C4E5B53C03EBE-8094
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 876 HW: 3Q0 035 876
Component: MU-S-NS-US H25 0241
Serial number: VWZAZ2R0232806
Coding: 027300020000000051220002001808001F0203F401200105C6
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: F1AA998A207919B601-80A4
Media Player Position 1:
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H52 1028
Serial number: VWZ8Z9RFC001PD
Engine Control Module 2:
Subsystem 2 - Part No SW: 3G0 919 866 B HW: -----------
Component: NAR 2015/16 --- 0220
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0564
Coding: 02730002C2823A017F1E06000000
Shop #: WSC 00066 790 00322
ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 00000345370
Coding: 0100000000020306000400010100000100
ROD: EV_MFKBoschAU370_AU37.rod
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 150523201780
VCID: EB968BE20255F3663B-80BE
End-------------------------(Elapsed Time: 02:50)--------------------------
