Hi !
Just upgraded my licence plate bulbs with LED ones ( 1K8943021B ) and even though i know what coding i need to change, i cannot seem to be able to do that
the info i found says that i need to change
-> Controller 09 - Central Electronics
-> 16 - Security Access - enter 31347
-> 10 - Adaptations
Change the 2 channels as:
(1)-Leuchte25KZL HA59-Lasttyp 25 - set to 43 - allgemeine LED
(6) Leuchte25KZL HA59 - Dimmwert AB 25 - set to 127
i use the latest VCDS release ( 15.7.4 ) and i can't seem to find the 2 correct adaptation groups.
They should be 481 Light configuration Lasttyp 25 and Dimmwert AB 25, but adaptation does not work.
When i try to change Lasttyp 25 i get stored value unknown, and if i try to change Dimmwert AB 25 it will not save the new value.
Any ideas ?
-> 10 - Adaptations
Any ideas ?
Chassis Type: 5F (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F A9
VIN: VSSZZZ5FZER111008 Mileage: 29948km-18608miles
Address 01: Engine (J623-CUPA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 EL HW: 04L 907 309 D
Component: R4 2,0L EDC H22 8150
Revision: 83H22---
Coding: 01190012032401080000
Shop #: WSC 00049 770 00129
ASAM Dataset: EV_ECM20TDI01104L906021EL 002009
ROD: EV_ECM20TDI01104L906021EL_SE37.rod
VCID: 73E58A1DDAADCAA67C-8026
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 6077400000065C
Coding: 20EE62923421096D0077060041CB2904462C9000608294F400 610060C003
Shop #: WSC 00049 770 00107
ROD: EV_Brake1UDSContiMK100ESP_SE37.rod
VCID: 4B9532FDE2DDF266D4-801E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5F0 907 044 E HW: 5F0 907 044 E
Component: Climatronic H03 0705
Revision: 00001K07
Coding: 00000104202100011005000000101000
ROD: EV_ACClimaBHBVW37X_SE37.rod
VCID: 285FAD7153EBF97E19-807C
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011407600324
Coding: 08000846C24102FB4BE44000401C0728100000000000000000 0000000000
ROD: EV_BCMBOSCH_SE37.rod
VCID: 7BF5A23DF2FD82E624-802E
Slave 1:
Subsystem 1 - Part No SW: 5F1 955 119 HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 140227 041 0574
Serial number: 140228144659
Coding: 0BC5FD
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y14M03D13H21M08S56S9
Coding: 00885D
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 012 0189
Revision: -------- Serial number: 003P4P6ARGD0
Coding: 98CCC000000000005C0000CC000800000065
ROD: EV_AirbaVW20TS6VW48X_SE37.rod
VCID: 7F0D562DE6E59EC608-802A
Subsystem 1 - Part No SW: ----------- HW: 454 002 203 14
Serial number: 3576U000000D90013F06
Subsystem 2 - Part No SW: ----------- HW: 454 002 103 14
Serial number: 3586U0000004D8613F0G
Subsystem 3 - Part No SW: ----------- HW: 454 801 003 14
Component: SideSensor_Dr 111 0148
Serial number: 3516RDB132303000000Z
Subsystem 4 - Part No SW: ----------- HW: 454 800 803 14
Component: SideSensor_Pr 111 0148
Serial number: 3526RF0C12403000000.
Subsystem 5 - Part No SW: ----------- HW: 454 800 603 14
Component: FrontSensor_D 114 0149
Serial number: 3556VB5901E030000007
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AC HW: 5Q0 953 549
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 19031404220211
Coding: 1400
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 77FDBE0DCED5A68640-8022
Part No SW: 5F0 920 861 A HW: 5F0 920 861 A
Component: KOMBI 203 2210
Coding: 07A501002180000800082A00000000
ROD: EV_DashBoardVDDMQBAB_SE37.rod
VCID: 2643A34959FFEF0E2B-8072
Part No SW: 5Q0 907 530 P HW: 5Q0 907 530 E
Component: GW MQB Mid 124 1164
Revision: -------- Serial number: 0001824285
Coding: 030100F40B087300EF0002E8080F0001000100000000000000 0000000000
ROD: EV_GatewLear.rod
VCID: 3E736B29A16F57CE43-806A
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H03 0120
Serial number: 000000000A0338040314
Coding: 002000
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 0826212803
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000095302000
Coding: 00100320DE00040000001000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 448719C1CF833D1E15-8010
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000002046826
Coding: 310000
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Coding: 8103
ROD: EV_SteerAssisMQB.rod
VCID: 418910D5D09128363E-8014
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000095084967
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 43851ADDCA8D3A262C-8016
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000002149769
Coding: 290000
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 5F0 035 869 A HW: 5F0 035 869 A
Component: MU-E--ER 180 0148
Revision: -------- Serial number: 000091733500000
Coding: 04730000FF00000011110001000000002F0007840000010000
ASAM Dataset: EV_MUEnt4CCONT 004052
ROD: EV_MUEnt4CCONT_SE37.rod
VCID: 2B55527D421DD266F4-807E
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5F0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0001
Serial number: 140228200636
VCID: 6ADB97798D670B6ECF-803E
