- Joined
- May 7, 2014
- Messages
- 14
- Reaction score
- 6
- VCDS Serial number
- C?ID=186457
I am attempting to retrofit VW Genuine Euro Spec bi-xenon headlights. My car originally came with b-xenons so the harness plugged right it. I was told that these would be plug and play but I am quickly learning that this is not the case as least with a vcds coding respect.
It looks like the marker lights are causing the bulb out errors and I was told that marker lights can be disabled to remove the monitoring from these lights.
Here is my autoscan. Any help would be greatly appreciated.
VCDS Version: Release 12.12.2
Data version: 20140212
Friday,16,May,2014,09:04:20:56121
Chassis Type: AJ (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 4C 4F
52 55 56 62 72
VIN: 3VW467AJ7DM426929
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 06J 906 027 FH HW: 06J 907 309 A
Component: MED17.5.2 TFSI 2 07 4351
Revision: P3H07--- Serial number:
Coding: 0403010A1C070160
VCID: 76CD0632011C04AEB1B-8023
Readiness: 1110 0101
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 058 N HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3519
Revision: 05651213 Serial number: 00001211202272
VCID: 256F117EEC3A3F36C81-8070
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: A14B600C49248000851406E692220141B71C00
Shop #: WSC 20312 444 85794
VCID: 7DDF191EE42A57F6F01-8028
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 086 1101
Revision: 00086000 Serial number: 0194478623
Coding: 030C0C
ROD: EV_KESSYPQ35G.rod
VCID: 3449FC3A9FE056BE4FF-8061
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3AA 907 044 AN HW: 3AA 907 044 AN
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0010001002
Shop #: WSC 00066 123 00122
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 7CD9141AF7305EFEC7F-8029
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 T HW: 5K0 937 087 T
Component: BCM PQ35 H 021 0068
Revision: BK021001
Coding: 6F200ABF942F0EC400880083000009E44705B40856808DB2E4866004A040
VCID: 46ADB6F2F17CD42EE1B-8013
01049 - Supply Voltage Term 50
Reset counter: 130
Mileage: 19117 km
Date: 2014.14.03
Time: 08:58:40
Voltage: 12.30 V
03188 - Bulb for Side Marker Light; Front Left
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 130
Mileage: 19117 km
Date: 2014.14.03
Time: 08:59:10
Voltage: 14.15 V
03189 - Bulb for Side Marker Light; Front Right
Reset counter: 130
Mileage: 19117 km
Date: 2014.14.03
Time: 08:59:10
Voltage: 14.10 V
Part No SW: 5C0 959 655 Q HW: 5C0 959 655 Q
Component: AirbagVW10G 013 0851
Serial number: 003LKM0373B4
Coding: 00004A34
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 40A1A0EADB58FA1EDB7-8015
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y130000PP0U08
Coding: 303041
Serial number: 3572MSME74227475ZZZV
Serial number: 3582MSME61117576ZZZS
Serial number: 3516KSME7E4A6721ZZZ/
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME0B4B6B21ZZZ-
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME6D0D1720ZZZ-
Crash sensor for front airbag; passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME711A1720ZZZO
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Component: LENKS.MODUL 016 0140
Revision: FF010041 Serial number: 20121203301222
Coding: 001A140000
Shop #: WSC 00066 000 00208
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DDF191EEC2A57F6F01-8028
Subsystem 1 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H30 0032
Coding: 830000
Part No SW: 5C6 920 972 B HW: 5C6 920 972 B
Component: KOMBI H07 0705
Coding: 171E01
Shop #: WSC 00066 000 00122
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 2D7FE95E7CCA0776001-8078
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
Component: J533 Gateway H50 1634
Revision: H50 Serial number: 03011303290567
Coding: 351002
VCID: 76CD0632C11C04AEB1B-8023
Component: IMMO H07 0705
Coding: 000007
Shop #: WSC 45681 000 1048576
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EAF5A2420DA4504EA53-80BF
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000015995002
Coding: 4900000000000000
Shop #: WSC 00066 790 50316
ROD: EV_ELVMarquMPVW36X.rod
VCID: 3041F02A6BF86A9E2B7-8065
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7663998420
Coding: 020100
VCID: 2A75E2424524104EE53-807F
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 D HW: 1K0 035 274 D
Component: RNS315-NAR H58 0319
Serial number: VWZAZ2M0026352
Coding: 04090041010000000000100A
Shop #: WSC 01383 790 50316
ROD: EV_RNS315NARV2UDS.rod
VCID: 256F117E243A3F36C81-8070
Component: NAR_V3_(0037) 0037
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0515
Revision: 13110009 Serial number: 0006017539
Coding: 0004B5
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: DB9BF786D2FE39C62E5-808E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 008 1508
Serial number: 00000007405495
Coding: 000490
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
VCID: 3753CB364696BDA66AD-8062
Address 47: Sound System (R12) Labels: 3T0-035-456.clb
Part No: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: -------- Serial number: EAA098A0016988
VCID: 266D1672593C342EC1B-8073
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AH
Component: EZE_2 H50 1634
Coding: 01030100
VCID: EFC3B3563E46B566F2D-80BA
Subsystem 1 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H10 0007
Coding: 180000
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0515
Revision: 15110009 Serial number: 0006059175
Coding: 0004B4
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: DC99F49AD7F03EFE27F-8089
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 B HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 008 1508
Serial number: 00000007440636
Coding: 000490
Address 55: Xenon Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 081000000A000200
Shop #: WSC 00066 123 12345
ROD: EV_HeadlRegulVWAFSPt.rod
VCID: 3753CB368E96BDA66AD-8062
Subsystem 1 - Part No SW: 4H0 941 329 HW: 4H0 941 329
Component: LeiMo links H02 0010
Coding: 860000
Subsystem 2 - Part No SW: 4H0 941 329 HW: 4H0 941 329
Component: LeiMo rechts H02 0010
Coding: 860000
End ---------------------------------------------------------------------
