2003-2004 MK4 Golf Service Reset
Telboy
Verified VCDS-Lite User
UK, Crawley
C?ID=250830
Hi bit of a silly question but how can I reset the service light with VCD Lite.
I have seen links for 1999-2000 but not for my model.
I own 2003-2004 Mk4 Golf 180psi and I have just done a full service and used longlife oil.
A simple reset should just be:
[Select]
[17-Instruments]
[Adaptation]
Channel 02 -> Make it 0.
Telboy
UK, Crawley
C?ID=250830
Thanks for the Very quick reply. But will that set the longlife oil too?
It won't change whatever the cluster is currently set to. That's why it's a "simple reset".
If you want more info than that, please post an Auto-Scan so we can see what cluster you have.
Telboy
UK, Crawley
C?ID=250830
On thread Error 01176 on this forum is a Autoscan from my car. yet can post a updated one if requested
Monday, 23 November 2015, 13:50:04:29282
Chassis Type: 01 - My Golf
Scan: 01,03,08,15,17,19,46,56
Address 01: Engine       Labels: 06A-906-032-AJQ.LBL
   Controller: 06A 906 032 MJ
   Component: 1.8L R4/5VT         0003
   Coding: 11510
   Shop #: WSC 01266
   VCID: 72972BA92DB7
   WVWZZZ1JZ4W112895     VWZ6Z0C0133447
Address 03: ABS Brakes       Labels: None
   Controller: 1C0 907 379 M
   Coding: 0019970
   Shop #: WSC 01266
   VCID: 341BEDB11723
Address 08: Auto HVAC       Labels: 3Bx-907-044.LBL
   Controller: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 01266
   VCID: 213514E5B8D1
Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
   Controller: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   0008
   Coding: 12855
   Shop #: WSC 01266
   VCID: 22371BE9BDD7
Address 17: Instruments       Labels: 1J0-920-xx5-17.LBL
   Controller: 1J0 920 926 A
   Component: KOMBI+WEGFAHRS. RB8 V29
   Coding: 05414
   VCID: 282309C1DBEB
01176 -  Key
            07-10 -  Signal too Low - Intermittent
Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
   Controller: 6N0 909 901
   Coding: 00006
   Shop #: WSC 01266
   VCID: F093A1A1A3BB
Address 46: Central Conv.       Labels: 1C0-959-799.LBL
   Controller: 1C0 959 799 B
   Component: 1X Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 54146
   VCID: 361FD7B9015F
Address 56: Radio       Labels: 1J0-035-18x-56.LBL
   Controller: 1J0 035 186 D
   Component:  RADIO SON         0004
   Coding: 01403
   Shop #: WSC 01266
   VCID: 263F07F9D1FF
End   --------------------------------------------------------------------------------------------------
OK, your cluster appears to be coded for Flexible (Long Life) service intervals.
If you have more questions, please look at Adaptation Channels 40 - 44 and tell us the Stored Value in each one.
Telboy
UK, Crawley
C?ID=250830
ok i looked at channels 40-44. channel 40 set to 0, 41 set to 0, 42 set to 15, 43 set to 15, 44 set to 365
so 42+43 set to 30, 44 set to 730?
Telboy
UK, Crawley
C?ID=250830
I'll take that as a yes.
I also notice a pop up, saying I need to do edit the channels in a order?
Pardon me for taking some time away from my computer on a Sunday. ;)
40 is Distance since Service (in hundreds of km)
41 is Time since Service (in days)
42 is Minimum Distance to Service (in thousands of km)
43 is Maximum Distance to Service (in thousands of km)
44 is Maximum Time to Service (in days)
For Flexible intervals on a Petrol engine, standard values would be:
42 = 15
43 = 30
44 = 730
Telboy
UK, Crawley
C?ID=250830
I was shocked I got a reply in the first place as it was a sunday. Thanks Uwe. I would be lost with out you. :)
NEtech
C?ID=56995
Also check channel 45, if change for flexible service.
Telboy
UK, Crawley
C?ID=250830
45 is set to 1 at moment
Telboy
UK, Crawley
C?ID=250830
I know its been some time but was wondering on my last question, as you asked to check channel 45 as i said it was set to 1 do i need to change this?
