Wee fault here with a polo just before I do A belt/chain change was wondering is it worth checking out the sensor or is it a common problem for a stretched chain or poor chain tensioner to give these symptoms.
VCDS Version: Release 15.7.3 (x64) Running on Windows 10 x64
Data version: 20151216
Tuesday,09,February,2016,13:24:03:42761
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: ****ZZ9NZ****2988 Mileage: 135620km-84270miles
Address 01: Engine Labels: None
Part No: 06A 906 032 TL
Component: 1.8l R4/5VT 0040
Coding: 11500
Shop #: WSC 02629
VCID: 7BF27B4C694269E624-515C
WVWZZZ9NZ6Y232988 VWZ7Z0F3507256
16705 - Engine Speed Sensor (G28)
P0321 - 35-10 - Implausible Signal - Intermittent
16395 - Bank 1: Camshaft A (Intake)
P0011 - 35-10 - Retard Setpoint not Reached (Over-Advanced) - Intermittent
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP80.lbl
Part No SW: 6Q0 907 379 AR HW: 6Q0 907 379 AR
Component: ESP 8.0 front H02 0002
Coding: 0000269
Shop #: WSC 00788 785 00200
VCID: 0D16259417F657560A-515C
02214 - Tire Pressure Warning
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Q0 820 045
Component: Klimaanlage X0840
VCID: 6ADC4E0816D8E06ECF-515C
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-00 - Open or Short to Plus
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 00BK BN-SG. 1S34
Coding: 25742
Shop #: WSC 00788
VCID: 3C70B8502CCCAEDE6D-517A
01598 - Drive Battery Voltage
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 K
Component: 16 AIRBAG VW51 0N 0009
Coding: 12598
Shop #: WSC 00788
VCID: 2C508810DCAC3E5EFD-515C
Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
Part No: 6Q0 920 923 F
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 01444
VCID: 3664AA7812E0748E9B-517A
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 0B7L GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 00788
VCID: 70E85C6030041ABE81-517A
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10120
Shop #: WSC 00788
VCID: 6FEA5F1C2D3A054698-515C
Address 45: Inter. Monitor Labels: 6Q0-951-171.lbl
Part No: 6Q0 951 171 C
Component: Innenraumueberw. 0020
VCID: 326C9668FE8868AEB7-517A
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 63 Komfortgerát 0002
Coding: 00016
Shop #: WSC 00788
VCID: 3D76B55437D6A7D65A-4B38
Part No SW: 6Q0 035 152 E HW: 6Q0 035 152 E
Component: Radio 9NK 0004
Revision: 00001000 Serial number: VWZ4Z4H9240327
Coding: 0040402
Shop #: WSC 00012 210 71232
VCID: 2C5088108CAC3E5EFD-515C
End-------------------------(Elapsed Time: 02:52)--------------------------
