ST?ID=65143
2011 Jetta, a lot of exterior lights not working, codes to match:
No wiring harness issues found. All fuses checked out good when back probed. But not all fuse failures are the same... the root cause was this:
For testing purposes, another fuse was installed and with that, the exterior lights started to work again. Fuse box will be replaced.
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 E HW: 5K0 937 084 E
Component: BCM PQ35 B 011 0035
Revision: BG011001
Coding: 25380E1F902F3EC4008800816000004401000086535D8560648020000040
VCID: 3467EAF797E5329EA5-8060
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 08111 21 0512
Coding: 009795
16 Faults Found:
Reset counter: 40
Mileage: 150141 km
Date: 2016.01.13
Time: 14:22:29
Term 15 Off
Voltage: 16.05 V
00927 - Terminal 30 (Right)
Fault Status: 00101011
Reset counter: 40
Mileage: 150141 km
Date: 2016.01.13
Time: 14:14:45
Voltage: 12.10 V
Fault Status: 00101010
Reset counter: 42
Mileage: 150141 km
Date: 2016.01.13
Time: 14:15:06
Voltage: 12.00 V
00985 - Right Tail Light (M2)
Fault Frequency: 7
Reset counter: 42
Mileage: 150141 km
Date: 2016.01.13
Time: 14:14:46
Voltage: 12.00 V
Reset counter: 42
Mileage: 150141 km
Date: 2016.01.13
Time: 14:13:55
Voltage: 12.20 V
Reset counter: 42
Mileage: 150141 km
Date: 2016.01.13
Time: 14:13:55
Voltage: 12.20 V
Fault Status: 01101010
Reset counter: 2
Mileage: 150175 km
Date: 2016.01.15
Time: 19:30:39
Voltage: 12.95 V
01501 - Bulb for Blinkers; Rear Left (M6)
Reset counter: 42
Mileage: 150141 km
Date: 2016.01.13
Time: 14:13:55
Voltage: 12.20 V
01503 - Bulb for 3rd Brake Light (M25)
Fault Frequency: 35
Reset counter: 42
Mileage: 150141 km
Date: 2016.01.13
Time: 14:14:27
Voltage: 12.15 V
Fault Frequency: 7
Reset counter: 42
Mileage: 150141 km
Date: 2016.01.13
Time: 14:13:55
Voltage: 12.20 V
01516 - Terminal 30; Left
Reset counter: 40
Mileage: 150141 km
Date: 2016.01.13
Time: 14:22:36
Term 15 Off
Voltage: 12.50 V
Reset counter: 42
Mileage: 150141 km
Date: 2016.01.13
Time: 14:14:34
Voltage: 12.10 V
02391 - Terminal 30 Reference
Reset counter: 40
Mileage: 150141 km
Date: 2016.01.13
Time: 14:22:36
Term 15 Off
Voltage: 12.50 V
Reset counter: 42
Mileage: 150141 km
Date: 2016.01.13
Time: 14:13:56
Voltage: 12.20 V
Fault Frequency: 23
Reset counter: 42
Mileage: 150141 km
Date: 2016.01.13
Time: 14:14:24
Voltage: 12.15 V
03384 - Windshield Washer Jet Heating
Reset counter: 42
Mileage: 150175 km
Date: 2016.01.15
Time: 19:30:39
Voltage: 13.65 V
