cant get park steering assist to work on Audi A6 2012
Ronc
C?ID=122818
i want to install automatic parking in my Audi A6 3.0 from 2012.
The car already had park assist from the factory with 8 sensors and backup camera.
I fitted the 4 extra sensors and installed the new control module (4H0919475R).
I coded the new parking module and some others (44: steering assist).
The module and the sensors seem to work OK.
I see the extra sensors in the backup screen on the MMI and they give accurate readings.
There are no errors at all in any module.
But the automatic parking does not work.
When i press the button i immediately get the message "Park system not available"
Is it maybe because some coding for park assist needs to be done in the ABS module?
If so can anyone please help me with the information to achieve this?
I also found that the engine module can be coded for park steering assist. But the module does not accept this code.
Can this also be relevant?
Any help appreciated very much.
Groet, Ron
Scan from my car:
Friday,22,January,2016,17:36:33:31113
VCDS Version: 15.7.3.0
Data version: 20151216
VIN: WAUZZZ4G2CN036446   License Plate:
Mileage: 177149km-110075mi   Repair Order:
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 18 19 28 34 36 3B 3C
          42 44 46 47 52 53 55 56 5F 62 6C 6D 72 85 88 89 8B 8E 8F 90
VIN: WAUZZZ4G2CN036446   Mileage: 177149km-110075miles
Address 01: Engine (J623-CDUC)       Labels: 059-907-401-V2.clb
   Part No SW: 4G0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0004
   Revision: 53H37---
   Coding: 1225401C056601020000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
   ROD: EV_ECM30TDI0114G0907401F.rod
   VCID: 26490BD3599E840E2B-8072
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 4G1 927 156 B    HW: 0B5 927 156 F
   Component: 0B5 30 TDIRdW H10 0001
   Revision: --H10---    Serial number: 0000001522
   Coding: 000001
   ROD: EV_TCMDL501.rod
   VCID: 2C5DF9FB4772BE5EFD-8078
Address 03: ABS Brakes (J104)       Labels: 4G0-907-379-V1.clb
   Part No SW: 4G0 907 379 G    HW: 4G0 907 379 G
   Component: ESP PREMIUM   H09 0250
   Coding: 27A6C701E465E380DB00
   ASAM Dataset: EV_ESPPremiAU57X 004017
   ROD: EV_ESPPremiAU57X_AU57.rod
   VCID: 356BDC9F9438FF9692-8060
   Part No SW: 4H0 907 064 BP    HW: 4H0 907 064 BP
   Component: BCM2 2.0      H31 0330
   Coding: 05A92F06000000000000
   VCID: 78F515ABCBAAC2FE49-802C
   Part No SW: 4G8 959 760 B    HW: 4G8 959 760 B
   Component: MEM-BFS       H04 0153
   Revision: AA000000    Serial number: 00000006287554
   Coding: 0018320000006201000001010101112030303333283333
   VCID: 3973D0AFB0201BF676-806C
Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-4Z.clb
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H11 0062
   Serial number: 01081100040772
   Coding: 361200B82C
   ASAM Dataset: EV_AirCondiComfoUDS 002033
   ROD: EV_AirCondiComfoUDS.rod
   VCID: 275706D75E949D0610-8072
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 BF    HW: 4H0 907 063 F
   Component: BCM1 2.0      H12 0100
   Revision: 20012002    Serial number: 00000000991808
   Coding: 0200201050B49FE2C9810083A0001908CF9CC7082E080101000008402101
   VCID: 6DDB34FFB4E87756AA-8038
   Component: WWS57X 110702  H35 0051
   Coding: 0045F7
   Component: RLS  H04 0003
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 E    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0190
   Revision: AA001001
   VCID: 224117C33DB6782E47-8076
Address 10: Park/Steer Assist (J791)       Labels: 4H0-919-475-7X5.clb
   Part No SW: 4H0 919 475 AF    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0050
   Coding: 382B07
   Shop #: WSC 06443 128 28888
   ASAM Dataset: EV_EPHVA2CAU57X0000 002011
   ROD: EV_EPHVA2CAU57X0000.rod
   VCID: 76E91B93C9BEB48E5B-8022
Address 13: Auto Dist. Reg (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4G0 907 561     HW: 4G0 907 561
   Component: ACC3          H15 0160
   Coding: 3E04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 001003
   ROD: EV_AdaptCruisContrAU57X.rod
   VCID: 67D746D79E145D06D0-8032
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG003HJ2-
   Coding: 30323436313330303335554A304C34473053
   VCID: 3669DB93893EF48E9B-8062
   Serial number: 3575HRB405T0JR9Q21B-
   Serial number: 3585HRB405D0IRE22GHM
   Serial number: 3515JRB404T0M38E70I8
   Serial number: 3525JRB40610LMIQ7HE-
   Serial number: 3554VRB40550LMIQFP7J
   Serial number: 3564VRB40510LMIQEPPX
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
   Revision: --------    Serial number: 90372KG90015G
   Coding: 0000DD
   VCID: 3777D69786340D8680-8062
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H07 0009
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 931 J    HW: 4G8 920 931 J
   Component: TDieRdwAcc    H71 0375
   Revision: 26181114    Serial number: 658300711593022
   Coding: 138F11005F0500080D0000
   ASAM Dataset: EV_RBD4K 004040
   ROD: EV_RBD4K.rod
Address 18: Aux. Heat (J364)       Labels: 8R0-265-105.clb
   Part No SW: 4H0 265 105 E    HW: 4H0 265 105 E
   Component: Standheizung  H24 0260
   Revision: 66006006    Serial number: 20130125001805
   Coding: 5D3F01
   VCID: 244D11DB27A2761E35-8070
   Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000208261
   Coding: 00CD077D00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 3261E7836556E8AEB7-8066
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650864290
   Voltage stabilizer:
Address 28: HVAC, Rear (E265)       Labels: 4G0-919-158.clb
   Part No SW: 4G0 919 158 D    HW: 4G0 919 158 D
   Component: KLIMA FOND    H07 0056
   Serial number: 24071100040533
   Coding: 01
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
   ROD: EV_ClimaContrUnitRearUDS.rod
   VCID: 3065ED8B6B5ADABEC1-8064
Address 34: Level Control (J197)       Labels: 4G0-907-553.clb
   Part No SW: 4G0 907 553 C    HW: 4G0 907 553
   Component: LUFE-DAEMPFER H17 0779
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003022
   ROD: EV_AirSuspe_AU57.rod
   VCID: 2B5FFAE7427CB966F4-807E
   Component: MEM-FS        H04 0153
   Revision: AA000000    Serial number: 00000006289628
   Coding: 00183B0000016201000001010101112030303333203333
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA4201K12O0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA.rod
   VCID: 2D5BF4FF7C68B756EA-8078
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH01 0020
   Revision: 00H01000    Serial number: 6PZ 010 287-03
   Coding: 0000102
   VCID: 3065ED8BA35ADABEC1-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H01 0020
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F27.07.1100H010003CF20574ÿ
   Subsystem 4 - Serial number: F20574ÿ
   Part No SW: 4G8 959 793 D    HW: 4G8 959 793
   Component: TSG FA        H05 0212
   Coding: 011F16205E00628202080013
   VCID: 4183B84FD8F043363E-8014
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Component: RCEPS         H33 0010
   Revision: 00001000    Serial number: 0024125814
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS.rod
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0155035822
   Coding: 01000E2020B93495832009840E0304000000000000000000000000000000
   Subsystem 1 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J245 PS20.006  H02 0007
   Coding: 001F00
   Subsystem 2 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
   Subsystem 3 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J394 PS20.006  H02 0007
   Coding: 001F00
   Subsystem 4 - Part No SW: 3AA 962 243     HW: 3AA 962 243
   Component: GEB.F.Heckoef  H11 0709
   Revision: CJ007000    Serial number: 00000000015201
   Coding: 030000
   Shop #: WSC 48034 000 1048576
   VCID: 1D3B243F04C847D67A-8048
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   Coding: 011F16205E00628202080002
   Revision: --------    Serial number: 00000000117750
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 2A51FFE34D86A06E0F-807E
Address 55: Headlight Range (J431)       Labels: 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0012
   Serial number: 110725-0004-000
   Coding: 11226F33F91AEB00
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
H02 0008
   Coding: 1D0000
H02 0008
   Coding: 1D0000
   Part No SW: 4G1 035 053 E    HW: 4G1 035 053
   Component: Radio U Basic H41 0093
   Revision: AB001007    Serial number: 049G.0BB010828
   Coding: 010003010000000001
   VCID: 214318CF38B063365E-8074
   Part No SW: 4G0 035 670 G    HW: 4G0 035 670
   Component: H-BNT-EU      H47 0484
   Revision: --------    Serial number: 428GY0B7520094
   Coding: 050100010003FBFF7D30DF3E00000003000001000100000002
   Shop #: WSC 78191 143 106667
   VCID: 275706D756949D0610-8072
   Subsystem 1 - Part No: 8R0 060 884 AH
   Component: EUR 2012  1308
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 A
   Component: E380 BDT C7  H08 0204
   Component: CD-Database  3371
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F14204000628202080002
   VCID: 448DB15BC7E2561E15-8010
   Part No SW: 4G0 907 441 C    HW: 4H0 907 441 B
   Component: SG Rueckfahrkamera  0161
   Revision: --H05---    Serial number: 525 PA8J1ZG049
   Coding: 1080005
   VCID: 275706D796949D0610-8072
Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
   Part No SW: 4G9 959 107 A    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0139
   Revision: 14003001    Serial number: 190100155
   Coding: 097205C010
   ASAM Dataset: EV_HDSGAu572 001001
   ROD: EV_HDSGAu571.rod
   VCID: 346DE19B9F42E69EA5-8060
   Component: TSG HR        H04 0212
Address 85: On Board Cam. (J852)       Labels: None
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0034
   Coding: EE060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 65CB4CDF64184F16E2-8030
Address 88: Multicont. Seat Driver (J873)       Labels: None
   Serial number: 00000964216401
   Coding: 662FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2F67EEF77664C546D8-807A
Address 89: Multicont. Seat Pass. (J872)       Labels: None
   Serial number: 00000964218101
   Coding: 262FF2
Address 8B: Adaptive Cruise 2 (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4G0 907 541     HW: 4G0 907 541
   Coding: 3E04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
   ROD: EV_AdaptCruisContr2AU57X.rod
Address 8E: Image Processing (J851)       Labels: 4G0-907-107.clb
   Part No SW: 4G0 907 107 B    HW: 4H0 907 107
   Component: BV-SG         H29 0034
   Serial number: 000040181907117
   Coding: 04C0BB181111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 254B0CDF24988F1622-8070
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 0066E608031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 6FE72EF7B6E4854698-803A
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70E52D8BABDA9ABE81-8024
End-------------------------(Elapsed Time: 07:45)--------------------------
Keithuk
Stoke on Trent, England
C?ID=122432
Welcome to the forum Ron.
When posting a full AutoScan please put the code on between
 tags as it takes up less room and it saves Uwe editing posts. ;)
 [CODE] Full AutoScan [/CODE]
This is not a tweak; tweaks don't involve adding hardware. This is a retrofit. Moving to that section. ;)
LN-TAL
Norway
C?ID=13729
Hi there,
I do not have any inputs at this time, but if you want to compare, my car has a working parking system (2012 A6 3.0TDi), and the autoscan is below:
Thursday,10,December,2015,17:43:54:62006
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
VIN: WAUZZZ4GXCNxxxxxx   License Plate: xxxxxxx
Mileage:   Repair Order:
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 20 28 34 3B 3C 42 44
          46 47 52 53 55 56 5F 62 69 72 82 85 8B 8E 8F 90
VIN: WAUZZZ4GXCN057142   Mileage: 89948km-55891miles
   Component: 3.0TDI EDC17  H37 0006
   Revision: 53H37---
   Coding: 1225401A057601020000
   Shop #: WSC 74565 000 00000
   ASAM Dataset: EV_ECM30TDI0114G0907401F 001006
   VCID: 264959B959153B0E31-8072
   Component: 0B5 30 TDIRdW H10 0004
   Revision: --H10---    Serial number: 0000000313
   Coding: 000001
   ASAM Dataset: EV_TCMDL501 A02196
   VCID: 2C5DAB9147F9015EE7-8078
   Coding: 27A6C701E465E380EB00
   Shop #: WSC 09667 001 1048576
   VCID: 356B8EF594B3409688-8060
   Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
   Coding: 01A93006000000000000
   VCID: 76E949F9C1350B8E41-8022
00955 - Key 1
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 214
                    Mileage: 89948 km
                    Date: 2015.12.10
                    Time: 17:27:00
   Serial number: 15091100040250
   Coding: 361200783C
   VCID: 275754BD5E1F22060A-8072
   Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001213626
   Coding: 0907A01109749FE28981008300001800CF9CE7082E080101000108542F01
   VCID: 6ED96199B965334E89-803A
   Component: WWS57X 110830  H35 0051
   Coding: 0045F7
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 G    HW: 4G0 941 531 G
   Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Coding: 110000
   Coding: 110000
   Part No SW: 4H0 919 475 P    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0030
   Revision: --------    Serial number: 56261122100635
   Coding: 992B08
   ASAM Dataset: EV_EPHVA2CAU57X0000 002008
   VCID: 3F87ECDDA68F8AC652-806A
   Coding: 3F04010202
   VCID: 67D714BD9E9FE206CA-8032
   Revision: --------    Serial number: 003JG0046NF0
   Coding: 30323436313330303339554A304C34473053
   VCID: 366989F989B54B8E81-8062
   Serial number: 3575HRB405T0OPMG6G6D
   Serial number: 3585HRB40650Q3SKG1AN
   Serial number: 3515JRB40690NHDIDHO0
   Serial number: 3525JRB40530NHDGFHBO
   Serial number: 3554VRB405D0NI3IC0DN
   Serial number: 3564VRB405D0NI3I4HH.
   Revision: --------    Serial number: 90372KIG0017A
   Coding: 0000FD
   VCID: 377784FD86BFB2869A-8062
   Component: E221 - MFL  H08 0009
   Component: TDieRdwAcc    H79 0375
   Revision: 26181120    Serial number: 658200911593034
   Coding: 138611001F150008000000
   ROD: EV_RBD4K.rod
   Component: Standheizung  H24 0250
   Revision: 66006006    Serial number: 20110804225306
   Coding: 5D3B00
   VCID: 244D43B12729C91E2F-8070
   Revision: --------    Serial number: 00000000244812
   Coding: 00CD077D00
   VCID: 3261B5E965DD57AEAD-8066
   Serial number: 00000000005650457450
   Voltage stabilizer:
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
   Revision: AA001002
   Coding: 04018264747464545425363E
   VCID: 336FB0ED92C75EA6A6-8066
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0062
   Serial number: 13091100040404
   Coding: 01
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002015
   VCID: 2F67BC9D76EF7A46C2-807A
   Coding: 008003
   VCID: 2B5FA88D42F70666EE-807E
   Revision: --------    Serial number: EJ1BPA42021N8Y0
   ROD: EV_SARA.rod
   VCID: 2D5BA6957CE30856F0-8078
   Component: J769  SWA MasterH02 0060
   Revision: 00H02000    Serial number: 6PZ 010 287-03
   Coding: 0010102
   VCID: 3065BFE1A3D165BEDB-8064
   Component: J770  SWA Slave H01 0060
   Subsystem 3 - Serial number: 5F21.09.1100H010003CF20338ˇ
   Subsystem 4 - Serial number: F20338ˇ
   Coding: 011F16205000628002080013
   Shop #: WSC 02312 785 00200
   VCID: 4183EA25D87BFC3624-8014
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0006160872
   Coding: 101101010000
   ROD: EV_RCEPS.rod
   Revision: 00002001    Serial number: 0159077062
   Coding: 0100062020B90494832009042E0104000000000000000000000000000000
   Coding: 001F00
   Subsystem 2 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Coding: 180800
   Revision: CJ007000    Serial number: 00000000023539
   Coding: 030000
   Shop #: WSC 09670 001 1048576
   VCID: 1D3B76550443F8D660-8048
   Coding: 011F16205000628002080002
   Revision: --------    Serial number: 00000000141261
   VCID: 2A51AD894D0D1F6E15-807E
Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
   Serial number: 110927-0002-072
   Coding: 11226F601002A300
   ROD: EV_HeadlRegulBasic.rod
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 049IY0BB023405
   VCID: 264959B951153B0E31-8072
   Part No SW: 4G0 035 666 J    HW: 4G0 035 666
   Component: H-BN-EU       H47 0798
   Revision: --------    Serial number: 426I00B7613577
   Coding: 050100010003FFED3D30EB3E00000003E80101020000000000
   Shop #: WSC 40890 001 1048576
   VCID: 2F67BC9D7EEF7A46C2-807A
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Coding: 010F14204000628002080002
   VCID: 448DE331C769E91E0F-8010
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Component: Anhaenger     H07 0072
   Revision: 5G001002    Serial number: 00000133243781
   Coding: 0109080000000000
   VCID: 71E37AE5A85B2CB694-8024
Address 82: Heads Up Display (J898)       Labels: 4G0-919-604.clb
   Part No SW: 4G0 919 604 G    HW: 4G0 919 604 G
   Component: HeadUpDisplay 005 0112
   Coding: 470000
   ASAM Dataset: EV_HUDContiC7 001023
   ROD: EV_HUDContiC7.rod
   Component: DPC-SG        H24 0036
   Coding: EA060000
   VCID: 65CB1EB56493F016F8-8030
   Coding: 3F04010202
   Serial number: 000040182408117
   Coding: 04C0BB1C1111
   ROD: EV_BC7.rod
   VCID: 254B5EB52413301638-8070
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   ROD: EV_RGS_L.rod
   VCID: 3163BAE560DB6CB6D4-8064
   ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 06:04)--------------------------
Ronc
C?ID=122818
Hi, thanks a lot for this information.
The coding of the ABS module is exactly the same as mine.
Do you have the park assist that steers itself? (dont know the correct word in english for it)
If you do, then that means that no coding needs to be done at all to my ABS module.
But then the question is: what else is causing that my system does not work?
LN-TAL
Norway
C?ID=13729
Sorry for the late respons.
Hmm, is not the idea with a park assist that it turns the steering wheel ? :) Yes it does, it turns the steering wheel after you have engaged the system and it finds a parking spot. But you have to drive and revers yourself.
chips
Guatemala
UC157487
Hi, I don't kwow if this works for an Audi A6 I suppose it does.
I have a GTI MK6 2013 and I retrofit park assist to my car. It comes with 8 sensors (rear and front) from factory and I added 4 more (2 in the front and 2 the rear), the LPA 2.0 module an I have to change my two ABS sensors in the rear wheels.
When I activated in VCDS I have to activate in 44. Steering Assist and then in 03. ABS Brakes. This works for my GTI and it parks just fine.
This link will help you:
http://www.golfmk6.com/forums/showpost.php?p=1819154&postcount=30
Mrclopec
Nipomo, CA, USA
C?ID=149231
Im going to venture a guess. Someone please correct me if I'm wrong. Byte 1, Bit 4.
44-Steering Assist
Coding: 101101010001
NEtech
C?ID=56995
I agree on that, all (4G) with PR-code 7X5 have Byte 01 Bit 1 and 4 active.
Models with 7X2 have Byte 01 Bit 4 active.
I have checked many ABS coding, I don't think there is an coding for 7X5 in ABS.
Ronc
C?ID=122818
Hi guys,
YES you are right! I made those changes and it works!
I already found out by comparing in detail alle codes from LN-TAL with my own. (Thanks again)
I found the differences in 10 park/steer assist (changed from 382B07 to 982B07)
and in 44 steering assist (changed from 101001010001 to 101101010001).
Both are not documented completely in VCDS so i wouldnt have found them myself.
I dont know if both changes are necessary because i didnt try them seperately.
If anyone can comment on bit 7 on and bit 5 off in byte 0 of module 10 i would be interested.
But it works now and i am very happy.
And to be complete: no changing ABS sensors or coding in the ABS module are necessary in an A6 4G.
Thanks a lot to you guys on this forum!
Getting such good advice so quickly makes retrofitting your car even more fun.
Groet, Ron
