First of all I'm happy to be part of your comunity.
Any of you know what's the story with these fault codes, see 01 engine & 09 Cent Elect.
The fault code found in the 01 engine, the dealer can't see it at all (no MIL on the dash either) and regarding the second code from 09 they are telling me that is something ''normal'' on MQB Platform (previously they changed the heater element and the module).
FYI, the dealer confirmed that they scan in ''agressive mode'' as well.
Everything is working fine, is just annoying to see these fault codes.
Thank you
Thank you
Wednesday,30,December,2015,19:55:10:17348
VCDS Version: 15.7.3.0
Data version: 20151216
VIN: License Plate: Mileage:
Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 03 05 08 09 13 15 16 17 19 20 2B 42 44 52 55 5F A9
VIN: Mileage:
Address 01: Engine (J623-CXCA) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0006
Revision: --H13---
Coding: 091900122424002F1000
Shop #: WSC 00066 790 00218
ASAM Dataset: EV_ECM20TFS0205G0906259A 001008
ROD: EV_ECM20TFS0205G0906259A_VW37.rod
VCID: 2C573D204748F35EFD-8078
23651 - Heater Support Pump
P16C6 00 [032] - Running Dry
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 50625000000722
Coding: 01FA6BA13428096F007E020981C52980D62C9000408194B410430050C009
Shop #: WSC 01383 790 50316
ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
VCID: 479D628CFEEE3006F0-8012
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0360003591
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A7B0B78BD1C5DEE7F-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5GM 907 044 A HW: 5GM 907 044 A
Component: Climatronic H03 1001
Revision: 00001K01
Coding: 00020014200100010005000000101400
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 428B7398D5CC152E27-8016
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 087 R HW: 5Q0 937 087 R
Component: BCM PQ37BOSCH 028 0145
Revision: -------- Serial number: 86580402151136
Coding: 00110B464041A2E949E44000091407201800000000000000000000000000
Shop #: WSC 00066 790 00195
ROD: EV_BCMBOSCH_AU37.rod
VCID: 4A9B5BB8EDFCCD6EEF-801E
Slave 1:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels:
5QX-955-119-V1.CLB
Component: WWS 140824 043 0581
Serial number: 150318132505
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A
Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y15M02D06H11M05S34
Coding: 90A8DD
Subsystem 3 - Part No SW: 5GD 959 591 HW: 5GD 959 591
Component: J245 PS60.036 H06 0150
Serial number: 03694807441901150251
Coding: 181803
Fault Frequency: 12
Reset counter: 168
Mileage: 11721 km
Date: 2015.10.28
Time: 16:18:38
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0304
Serial number: 21011503212255
Coding: 01000200280438
ROD: EV_ACCMRRBoschVW372_AU37.rod
VCID: 387F117083104FFE89-806C
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM01YX03
VCID: 51A94CD400AAFEB6AE-8004
Seat occupant detection; front passenger side:
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J150002DZ510+
Coding: 30305A
Subsystem 2 - Part No SW: ----------- HW: 480 003 001 15
Serial number: 3570000000037DC4521J
Subsystem 3 - Part No SW: ----------- HW: 480 003 001 15
Serial number: 358000000003C9E4521N
Subsystem 4 - Part No SW: ----------- HW: 480 402 901 15
Serial number: 3510002C51901D91B32Z
Subsystem 5 - Part No SW: ----------- HW: 480 402 901 15
Serial number: 3520002A91901D9621E1
Subsystem 6 - Part No SW: ----------- HW: 480 402 901 15
Serial number: 3550002C11901D93A29%
Subsystem 7 - Part No SW: ----------- HW: 480 402 901 15
Serial number: 3560002BD192BC71A35F
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150215500248
Coding: 0400
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB.rod
VCID: 0407B5808F58DB1E55-8050
Part No SW: 5G1 920 756 HW: 5G1 920 756
Component: KOMBI 342 4270
Coding: 0BAD09122980880902886A011000000000000000
VCID: 6ADBFB388D3C2D6ECF-803E
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 23021510000750
Coding: 0101000820085900EF00022A080F00000001050000000000000000000000
Shop #: WSC 00066 790 07025
ROD: EV_GatewConti.rod
VCID: 72EBE358A5ECE5AE77-8026
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q
Component: E221__MFL-DC1 H10 0101
Serial number: 29150000465370055104
Coding: 30FFFF
Address 20: High Beam Assist. (J844) Labels: 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511 D
Component: FLA H05 0002
Revision: AA001001
Coding: 02018864727264565625393E01
VCID: 2B553E3C4246F466F4-807E
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000041604004
Coding: 5500000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 346725409F78AB9EA5-8060
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 100215060504HE
Coding: 003E13200000040000000000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 408F7990DBC0073E31-8014
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D
Serial number: 00000000000000845819
Coding: 011000
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 8102
ROD: EV_SteerAssisMQB.rod
VCID: 377D124C8E0E408680-8062
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 220215060506WU
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 3F8D7A6CA63E78C648-806A
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D
Serial number: 00000000000000726942
Coding: 091000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 021A01010B000400
ROD: EV_HeadlRegulVWAFS_SE26.rod
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels:
3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels:
3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIBSTD1.
clb
Part No SW: 5G0 035 876 HW: 5G0 035 876
Component: MU-S-NS-US 014 0655
Serial number: V7B01302153858
Coding: 027300020000000021220002001800001F0203340100010546
ROD: EV_MUStd4CPASE_SK37.rod
VCID: 69D98434883A2676C6-803C
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 605 K HW: 5G0 919 605 K
Component: ABT_Std_Nav H60 0030
Serial number: VWZ8Z9PS600HAZ
Engine Control Module 2:
Subsystem 2 - Part No SW: 5G0 919 866 S HW: -----------
Component: NAR 2015 --- 0022
B11CF 53 [009] - Deactivated
Reset counter: 46
Mileage: 11489 km
Date: 2015.10.15
Time: 19:25:05
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 150204200115
VCID: 6BD5FE3C82C63466B4-803E
End-------------------------(Elapsed Time: 04:31)--------------------------
