Hello guys. I am working with colleagues car Seat Ibiza Mk3 6l 2003 1.2 which has a problem with remote control and I can't find what's wrong with the car. Car owner said that remote control stopped working after battery has been changed, so I was thinking that I just need to adapt the key. I watched a video how to adapt the key for 6L chassis and tried to do that with genuine vcds but something is wrong and I can't adapt the key. Firstly, I am going to 01-Engine later 46-Central Convenience. I type 00 and pressed save to delete all existing keys. Then I press UP to 01 and 1 key is already there. I pressed 2(New value) just in case and pressed save button. After that, i press unlock button and I can hear that some kind of relay clicks, i press second time and i can hear that relay clicks again. If i type new value 4 keys, relay clicks 4 times. I press done and i leave Central Convenience. After all procedure, I try remote control and it's not working. Sometimes I can hear relay click once just after programming the key, but it's not unlocking or locking the car.
PS. there is no confirmation from the car that key is recognised like in the ross tech video, but I can hear some kind of relay instead as I already said above.
Thank you guys for your time reading this.
Auto-scan before clearing dtc:
Tuesday,05,January,2016,11:51:02:15269
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: VSSZZZ6LZ3R197868 License Plate: AY03DWD
Mileage: 127660km-79324mi Repair Order:
Chassis Type: 6L (6L - Seat Ibiza/Cordoba (2002 > 2009))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
VIN: VSSZZZ6LZ3R197868 Mileage: 127660km-79324miles
Address 01: Engine Labels: 03E-906-033-AZQ.lbl
Part No: 03E 906 033 P
Component: 1.2l/4V SIMOS3 00HS4729
Coding: 00061
Shop #: WSC 06402
VCID: 2D5680BAE72A9B56EA-5164
VSSZZZ6LZ3R197868 SEZ7Z0C1943379
17925 - Power Supply Relay for ECU
P1517 - 35-10 - Electrical Malfunction - Intermittent
17511 - Oxygen (Lambda) Sensor Heating; B1 S1
P1103 - 35-10 - Performance too Low - Intermittent
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6L0 820 045
Component: Klimaanlage X0840
VCID: 65C6389AFF5A6316E2-5164
8 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
01596 - Motor for Outside/Recirculated Air Flap (V154)
29-10 - Short to Ground - Intermittent
28-10 - Short to Plus - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 16396
Shop #: WSC 06402
VCID: 3B72BEE2295E05E664-5164
00906 - Horn (H1)
01598 - Drive Battery Voltage
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 R
Component: 09 AIRBAG VW5 0007
Coding: 12345
Shop #: WSC 06441
VCID: 4684DF16629C480E0B-5164
00532 - Supply Voltage B+
Address 17: Instruments Labels: 6L0-920-xx0-17.lbl
Part No: 6L0 920 901
Component: KOMBI+WEGFAHRSP VDO V10
Coding: 00437
VCID: 67DA329205567106D0-5164
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 63 GATEWAY CAN 1S33
Coding: 00012
Shop #: WSC 06402
VCID: 70E859CE3098B6BE81-5164
Part No: 6Q0 423 156 Q
Component: LenkhilfeTRW V250
Coding: 10111
Shop #: WSC 06402
VCID: 3D76B0FA374A0BD65A-5164
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: J3 Komfortgerát 0002
Coding: 00066
Shop #: WSC 06402
VCID: 3D76B0FA374A0BD65A-4B26
Subsystem 1 - Part No: 6Q1959801A
Component: J3 Tõrsteuer.FS KLO 0002
Subsystem 2 - Part No: 6Q1959802A
Component: J3 Tõrsteuer.BF KLO 0001
01179 - Incorrect Key Programming
35-00 - -
End-------------------------(Elapsed Time: 02:51)--------------------------
