Hello, yesterday, car suddenly lost power, check engine light and "workshop: came up on screen, ran codes today. Any advice much appreciated.
Wednesday,23,December,2015,11:10:48:22623
VCDS Version: 15.7.3.0
Data version: 20151216
VIN: 3VWRL71K99M065556 License Plate: MATTS JETTA
Mileage: 203540km-126473mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 65 72
VIN: 3VWRL71K99M065556 Mileage: 203540km-126473miles
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 016 N HW: 03L 906 022 J
Component: R4 2,0L EDC G000SG 8680
Revision: 12H01--- Serial number: VWX7Z0H824U00R
Coding: 0050072
VCID: 3D5FD7036429F1D65A-8068
006472 - Control Module 2 for Cooling Fan
P1948 - 000 - Output Short Circuit - Intermittent
Fault Frequency: 16
Mileage: 203233 km
Time: 03:53:36
RPM: 2530 /min
Speed: 89.0 km/h
Temperature: 26.1°C
Temperature: 90.0°C
Temperature: 12.6°C
Lambda: 13.4 %
Lambda: 0.0 %
006481 - Radiator Fan 2 (V177)
P1951 - 000 - Movement Restricted / Jammed - Intermittent
Fault Frequency: 10
Mileage: 203265 km
Time: 04:36:51
RPM: 1817 /min
Speed: 79.0 km/h
Temperature: 24.3°C
Temperature: 90.9°C
Temperature: 13.5°C
Lambda: 26.8 %
Lambda: 0.0 %
006480 - Radiator Fan (V7)
P1950 - 000 - Movement Restricted / Jammed - Intermittent
Mileage: 203238 km
Time: 04:05:23
RPM: 1334 /min
Speed: 34.0 km/h
Temperature: 29.7°C
Temperature: 84.6°C
Temperature: 13.5°C
Lambda: 9.5 %
Lambda: 0.0 %
000175 - Actuator Module for Turbocharger 1
P00AF - 000 - Stuck - MIL ON
Fault Status: 11100000
Mileage: 203500 km
Time: 03:44:52
RPM: 828 /min
Speed: 1.0 km/h
Load: 100.0 %
Lambda: 15.0 %
Absolute Pres.: 989.4 mbar
Temperature: 24.3°C
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 113B400D492800FF881002E9921F00423000
VCID: 74C93227D7E3709E65-8020
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
VCID: 78D106170B8B14FE49-802C
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000001089339
Coding: 14018E234004150007140000001400000008730B5C000120000000000000
VCID: 3245F43FAD773EAEB7-8066
Component: Wischer 091008 021 0501
Coding: 00038805
Shop #: WSC 00066
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0435814
Coding: 0000100
VCID: 334BF13B526D37A6BC-8066
Reset counter: 1
Mileage: 199773 km
Time: 11:43:31
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M074UYV
Coding: 0013889
VCID: 6CF92A474FD3A85EBD-8038
Subsystem 2 - Serial number: 6332MSME3E636421A
Subsystem 3 - Serial number: 6342MSME3E632D59R
Subsystem 4 - Serial number: 6351HSME181C1D317
Subsystem 5 - Serial number: 6361HSME18022E3FD
Subsystem 6 - Serial number: 63727SME18141820S
Subsystem 7 - Serial number: 63827SME177C083A9
Part No SW: 1K0 953 549 BS HW: 1K0 953 549 BS
Component: J0527 051 0101
Coding: 0002021
VCID: 042962E74743401E55-8050
Component: E0221 002 0010
Part No SW: 1K0 920 974 N HW: 1K0 920 974 N
Component: KOMBIINSTRUMENT 3HL 2418
Revision: V0003000 Serial number: VWX7Z0H824U00R
Coding: 0023203
VCID: 3957C3137001CDF676-806C
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 230808F2001817
Coding: E9807F070013021002
VCID: 354FCF235C19299692-8060
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0004
Revision: 00005000 Serial number: 1293324T3E9504
Coding: 0000003
Component: IMMO 3HL 2418
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000507188913
Coding: 0001205
VCID: 6FC33D4B7EC5534698-803A
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
VCID: 2A75EC5F85A7766E0F-807E
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DC00
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 00000028488830
Coding: 0001204
VCID: 70C13E3763FB4CBE81-8024
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Fault Status: 00101100
Fault Frequency: 20
Reset counter: 132
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7H2239917
Coding: 0010401
VCID: 2977135380A17D7606-807C
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003487709
Coding: 0001168
VCID: 76CD082F019F628E5B-8022
Component: RDK 0450
Coding: 0100101
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003537727
Coding: 0001168
VCID: 77D3052B06951B8640-8022
End-------------------------(Elapsed Time: 01:29)--------------------------
Address 01: DTCs cleared
