Hallo everybody. I need help. I have audi A6 3.0tdi ,2006 quattro. I have to change Electronic Control Module of Electric Steering Lock.
How can I program it?
Autoscan
This is OLD original ECM (Pin Code: 41204):
This is NEW but used ECM (I have no Pin Code of this ECM):
Thanks !
Autoscan
Friday,27,November,2015,15:57:53:51262
VCDS Version: 15.7.0.1
Data version: 20150729
VIN: WAUZZZ4F16N004602 License Plate: RRR
Mileage: 312850km-194395mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
56 61 62 67 72 77
VIN: WAUZZZ4F16N004602 Mileage: 312850km-194395miles
Part No SW: 4F0 910 402 L HW: 4F0 907 401 B
Component: 3.0L V6TDI G000AG 0010
Revision: --H01--- Serial number:
Coding: 0011372
Shop #: WSC 21599 142 80702
VCID: 2647C643912F330E0C-8072
004120 - Intake Manifold Runner (Bank 2)
P1018 - 001 - Lower limit not reached - Intermittent
Fault Status: 00100001
Fault Frequency: 74
Mileage: 312070 km
Date: 2015.11.23
Time: 20:00:27
RPM: 1008 /min
Torque: 132.6 Nm
Voltage: 13.91 V
Duty Cycle: 80.9 %
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
013128 - Control Circuit for Controller for Turbocharger 1 (J724)
P3348 - 005 - Electrical Malfunction - Intermittent
Fault Status: 00100101
Mileage: 312070 km
Date: 2015.11.27
Time: 12:54:04
Torque: 0.0 Nm
Temperature: -3.6°C
Duty Cycle: 80.9 %
Voltage: 11.70 V
Duty Cycle: 88.8 %
P3348 - 008 - Electrical Malfunction - Intermittent
Mileage: 312070 km
Date: 2015.11.27
Time: 12:54:04
Torque: 0.0 Nm
Temperature: -3.6°C
Duty Cycle: 80.9 %
Voltage: 11.70 V
Duty Cycle: 88.8 %
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 -
Fault Status: 01100010
Mileage: 312858 km
Date: 2015.12.22
Time: 14:19:33
Torque: 0.0 Nm
Duty Cycle: 1.0 %
Voltage: 11.55 V
Bin. Bits: 00101100
Torque: 93.6 Nm
Readiness: 0 2 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 B HW: 09L 927 156 A
Component: AG6 09L 3.0lTDI RdW 0030
Revision: --H01--- Serial number: 4004797
Shop #: WSC 02325 785 00200
VCID: 2341DF57E21DC6266B-8076
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Coding: 0020872
VCID: 2D55396FB4D90056CD-8078
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0220
Revision: 31050601 Serial number: 10600300138001
Coding: 0000131
Shop #: WSC 21636 142 85916
VCID: 63C19F57A29D86262B-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H44 0070
Component: FBSAUDIC6 IDG H38 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 732 J HW: 4E0 035 729
Component: Interfacebox H43 3460
Revision: 00000000 Serial number: 392CM057510753
Coding: 0001001
Shop #: WSC 21636 142 01412
VCID: 2A5F32738537176E28-807E
Subsystem 1 - Part No: 4F0 910 609 B
Component: Bedienteil MMIC6H07 0010
Subsystem 2 - Serial number: 00000000119306
Subsystem 3 - Serial number: 0103.03.050000000100010458ÿ
Subsystem 4 - Serial number: 010458ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 G
Component: KLIMABETAETIGUNGH04 0150
Revision: 00000024 Serial number: 00000000121667
Coding: 0000278
VCID: 5BB1A7B79AEDBEE663-800E
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Coding: 0012121
Shop #: WSC 02335 785 00200
VCID: 66C7864351AFF30ECC-8032
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Coding: 00141886
Shop #: WSC 02335
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7128882
VCID: 1C33E4ABDF63F9DEAA-8048
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 C HW: 4F0 959 655 B
Component: 33 AIRBAG AUDI8RH29 0230
Revision: 05H29000 Serial number: 0037LD05MU8N
Coding: 0013107
VCID: 2759CB4796252A0637-8072
Subsystem 1 - Serial number: 6332CSME07683A432
Subsystem 2 - Serial number: 6342CSME08161B11Y
Subsystem 3 - Serial number: 6351HSME06541D1A7
Subsystem 4 - Serial number: 6361HSME0632581D6
Subsystem 5 - Serial number: 6371VSME064C6024H
Subsystem 6 - Serial number: 6381VSME0640494FQ
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026050440360
Coding: 0002042
Shop #: WSC 02323 785 00200
Component: Lenkradmodul H06 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 A HW: 4F0 920 931 F
Component: KOMBIINSTR. M73 H15 0670
Revision: 00600000 Serial number: 4PV572135
Coding: 3073001
Shop #: WSC 00011 888 96745
VCID: 214DD55FF801D43679-8074
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H10 0060
Revision: 10 Serial number: 120080522002CF
Coding: 6CFE73C41B7104
Part No SW: 4E0 910 887 L HW: 4E0 919 887 C
Component: MNS ECE H44 0690
Revision: 00000000 Serial number: 305CH057574240
VCID: 36671603418F438EBC-8062
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H11 0040
Revision: 00-00000
Coding: 0001642
Shop #: WSC 02327 785 00200
VCID: 295DCD7F80311C7621-807C
Reset counter: 249
Mileage: 312858 km
Date: 2015.12.22
Time: 15:58:28
Reset counter: 249
Mileage: 312858 km
Date: 2015.12.22
Time: 15:58:28
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H18 0120
Revision: 01200018 Serial number: 01003111560000
Coding: 0139909
VCID: 2E573E63B9DF7B4EF4-807A
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 G HW: 4F0 035 223
Component: Amp.-ASK H09 0350
Revision: 19S00001 Serial number: 02802050070179
Coding: 0000118
VCID: 224FDA53FD07CF2E60-8076
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000043908
Coding: 0001003
VCID: 5EB7AEA389FFABCE04-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H11 0040
Revision: 00-00000
Coding: 0001642
Reset counter: 249
Mileage: 312858 km
Date: 2015.12.22
Time: 15:58:28
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000321
Shop #: WSC 02334 785 00200
VCID: 5DB5A9AF84F9B0D61D-8008
Part No: 8P0 907 357 C
Coding: 0000003
VCID: 3A7F02337597A7EE58-806E
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 B
Revision: 00000000 Serial number: 394CW057523766
Reset counter: 33
Mileage: 274560 km
Date: 2014.02.06
Time: 15:54:33
00856 - Radio Antenna
Fault Status: 00101011
Reset counter: 33
Mileage: 312821 km
Date: 2015.12.10
Time: 13:27:36
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000030607
Shop #: WSC 21636 142 01523
Component: von VA0 1502240673
Coding: 344630393135313035442056413031353032323430363733
Shop #: WSC 12345 384 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H11 0030
Coding: 0001066
VCID: 69DD8D7F40B1DC76E1-803C
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 R HW: 4E0 035 753 A
Component: SDS 3500 DE H45 0630
Revision: 00000000 Serial number: 00000502110055
Shop #: WSC 12336 024 394758
VCID: 3565110F5C894896B5-8060
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H11 0030
Coding: 0001066
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0 862 333 C
Component: TELEFONMODUL EU 0770
Revision: 00000006 Serial number: T2AUDX0505HMD5
Coding: 0000007
End-------------------------(Elapsed Time: 02:53)--------------------------
Thanks !
