Enable High Beam Assist- 2016 VW GTI- USA w/DAP
   #21
bbelhumeur
C?ID=247313
Great!
I think there's an adaptation that controls urban detection mode. I think it detects ambient light and won't turn on or something like that. You can fiddle with the adaptations in A5.
   #22
elephantacos
C?ID=266521
So it automatically turns the brights on when you are in "normal" mode and leaves the brights on always in "bright" mode? That doesn't seem good. No way to disable bright lights.
So I think there might actually be three settings, but I couldnt figure it out exactly.
I was playing with the stock while driving and at one point, I managed to get it to turn into normal (i.e., how it was without programming) mode, and then switched it to Light Assist mode, then into high beam mode. But I couldnt get it to switch reliably. I need to see if theres documentation to see how it actually works.
It would typically either go from Light Assist into Highbeam, I don't know how I got it to go into normal mode. Hmm...
Edit: Found this thread after searching, it looks like you can turn it off by flicking the high beams. Ill have to experiment tomorrow.
Edit: Another thread with more info. How "hard" you push the stock might effect it.
   #23
nathan16mk7R
C?ID=264933
Oh ok cool. As long as there is a way to disable it. I look forward to hearing if you get the bugs worked out and get to do some fine tuning. I remember seeing some parameters for it in the adaptations. I'll hopefully enable this on mine this coming weekend.
   #24
elephantacos
C?ID=266521
Here is the autoscan as promised. I found two faults when doing it, at 09 Cent Electronics, and 5F Information Electronics, though. So Im worried I screwed something up. Anyone able to help?
Also, question about this screen: What is the difference between 01 and 02? Currently set to 02.
VCDS Version: Release 15.7.3 (x64) Running on Windows 10 x64
Data version: 20151216
Tuesday,05,January,2016,20:04:38:35799
Chassis Type: AU (5Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 52 55 5F
          75 A5 A9
VIN: WVWUF7AU5GW181873   Mileage: 1506km-935miles
Address 01: Engine (J623-CYFB)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 H    HW: 06K 907 425 E
   Revision: --H13---
   Coding: 091900122446000E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
   ROD: EV_ECM20TFS0208V0906259H_VW37.rod
   VCID: 45AFAA42C42A311602-8010
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 62875000000913
   Coding: 01FA6BA15428096D057F030741C66980D62A90A0C08296B7144050D4C088
   VCID: 79D716B2F85285F636-802C
   Revision: 00021000    Serial number: 0385177120
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 3A55C9BEBDD44EEE7F-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00020004200100000105004012111402
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 6AF539FE8DF43E6ECF-803E
   Part No SW: 5Q0 937 085 AJ    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061530600193
   Coding: 00010B46C041A2E169E44000091C07201800000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 01277E529082DD367E-8054
   Slave 1:
   Component: WWS    151013  043 0551
   Serial number:         151031030940
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S5Y15M11D16H08M45S58
   Coding: 96A8DD
534549 - Databus
                    Reset counter: 94
                    Mileage: 1323 km
                    Date: 2016.01.03
                    Time: 17:40:43
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Revision: --------    Serial number: 39391531308190
   Coding: 0071155001
   ROD: EV_EPHVA18AU3700000_SK48.rod
   VCID: 43ABB45ACA1E0F262C-8016
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 29081503271114
   Coding: 01004700FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 13101541350136
   ROD: EV_DRCONTITEMIC.rod
   VCID: 3753D08A8EC6538680-8062
   Serial number: 003GCR03VDH-
   VCID: 47B3A04AFE262306F0-8012
   Seat occupant detection; front passenger side:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH000000000003EMNXC
   Coding: 30324E
   Subsystem 2 - Part No SW: -----------    HW: 480 002 910 15
   Serial number: 35700000000C4898371O
   Subsystem 3 - Part No SW: -----------    HW: 480 002 910 15
   Serial number: 35800000000760146715
   Subsystem 4 - Part No SW: -----------    HW: 480 400 511 15
   Serial number: 3510002C71D73C63A2AB
   Subsystem 5 - Part No SW: -----------    HW: 480 400 511 15
   Serial number: 3520002C91D73C61412/
   Subsystem 6 - Part No SW: -----------    HW: 480 400 311 15
   Serial number: 3550002A11D3F98291EF
   Subsystem 7 - Part No SW: -----------    HW: 480 400 311 15
   Serial number: 3560002BB1D25F03C3CI
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 20101504220616
   Coding: 0C00
   ASAM Dataset: EV_SMLSKLOMQB 020001
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 09376672A8B2957626-805C
   Part No SW: 5G1 920 858 A    HW: 5G1 920 858 A
   Component: KOMBI         303 6420
   Coding: 0BAD08127F88CF0502886A0B5400000000000000
   VCID: 2E7DF5EE719C924ED3-807A
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 27101510800040
   Coding: 0101000838085900FB00023A880F00000001050000000000000000000000
   ROD: EV_GatewConti.rod
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S
   Serial number: 29150002053110065423
   Coding: 34FFFF
Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
   Serial number: HA1-00016.09.15
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 4AB5997EED34DE6EEF-801E
   Revision: 00000000    Serial number: 15000241648005
   Coding: 5500000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 3449E7869FB0B89EA5-8060
Address 3C: Lane Change (J1086)       Labels: None
   Component: HRE_Master    H11 0071
   Serial number: 0385121932
   Coding: 02011103
   ROD: EV_HREntryHella_SK37.rod
   VCID: 3C59CFA6B7E070DE6D-8068
   Lane Change Assistant 2:
   Serial number: 040815BH206036
   Coding: 003E13208000040000000000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811
   Serial number: 00000000000007924757
   Coding: 111000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 9102
   ROD: EV_SteerAssisMQB.rod
   VCID: 3957D6B2B8D245F676-806C
   Serial number: 070815BH520135
   Coding: 003E13208C00040000800000
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 42A5B15ED504062E27-8016
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812
   Serial number: 00000000000007971269
   Coding: 091000
   Coding: 022202010B000400
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   VCID: 40A1BB56DB08143E31-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 876     HW: 3Q0 035 876
   Component: MU-S-NS-US    H25 0245
   Serial number: VWZAZ2R0489341
   Coding: 027300020000000051220002001808001F0207F401200105C6
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 71C72E92A022CDB68E-8024
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
   Component: ABT_Std-2_Nav  H52 1028
   Serial number: VWZ8Z9RFC009L8
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 3G0 919 866 R    HW: -----------
   Component: NAR 2016  --- 0321
6678 - Digital sound System control module
          U106A 00 [008] - No Communication
                    Reset counter: 102
                    Mileage: 1502 km
                    Date: 2016.01.05
                    Time: 16:34:14
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0568
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000456059
   Coding: 0100010000020306000400010100000100
   ROD: EV_MFKBoschAU370_AU37.rod
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 151016201451
   VCID: 2F43E8EA76969B46D8-807A
End-------------------------(Elapsed Time: 04:18)--------------------------
   #25
bbelhumeur
C?ID=247313
Not sure about the errors. I'm sorry to see that you have an R, and while our A5 modules are the same our 09 modules are different.
I thought the correct setting was 01 Light/High Beam Assist in the A5 unit. 02 looks like it's for Dynamic Light Assist, which you don't have the hardware for, but it may be for a different mode of HBA as well as DLA. It isn't clear. But my guess is 01.
I thought Light Assist (LA) and High Beam Assist (FLA) were different marketing terms for the same thing, but maybe not. Dynamic Light Assist (DLA) is defintely a separate technology requires shutters in your headlights.
Thanks for the scan.
   #26
elephantacos
C?ID=266521
Oops. Typo. Mine is set to 01!
   #27
andyvee
Rossendale, Lancashire, UK
C?ID=159389
You can also change the LUX settings for the sensitivity on A5
On an Octavia 3 the defaults are
Night vehicle detection activation brightness - 3 lux
Night vehicle detection deactivation brightness - 20 lux
I have reduced mine to 2 lux and 15 lux - it comes on a little later and goes off a little earlier like that.
You can also change the urban area detection setting, high beams will then come on in areas with street lights
   #28
bbelhumeur
C?ID=247313
   #29
dmc
Toronto, Canada
C?ID=8335
Those faults look similar to the ones I got when trying to activate the same tweak on my car (Canadian MY16 NAR 7R with DAP). Except in my case, I wasn't able to get it to work as you and the other U.S. guy on Vortex have reported.
Thanks for posting the scan. I will try to figure out what's going on with my Canadian car.
This is how I understand it: Light Assist (LA) and High Beam Assist are the same thing. LA is just the VW term for the technology (i.e. using a forward-facing camera to switch between dipped and high beams in the presence of other cars.)
Dynamic Light Assist (DLA) adds a side-shutter to the light, allowing it to remain on high beams for oncoming traffic, but only masking off a side portion to avoid dazzling the driver. I doubt our lights have the hardware to do this.
By this notion, we should only be setting byte 2 to 01. But who knows—I haven't been able to get it to work on my end yet!
   #30
dmc
Toronto, Canada
C?ID=8335
Thanks for posting that scan. We seem to largely have the same car (no surprise), except for a few small coding differences. You have a 75 telematics (Car-Net) module that I don't, and I have a different 5Q (Discover Pro). The controller part numbers that I thought should matter (09, A5) are identical.
You also have a newer CAN Gateway (19) than me (5Q0 907 530 AF versus AJ). I wonder if that has anything to do with it.
I will do a bit more playing this weekend and report back.
   #31
bbelhumeur
C?ID=247313
I n=know that the Canadian Golfs and GTIs with DAP have Light Assist by default and it isn't offered with the R (DAP). Maybe there's a hardware reason.
   #32
ABQ
C?ID=281382
I tried several times today on my US-Spec 2016 GTI with DAP to get this working today, and could not get past the Fault upon activation. Tried resetting to default and then redoing the changes in different orders, etc, to no avail.
Whoever figures out how to reliably code this gets the gold star. I just don't know enough about this stuff to do more than follow directions, and I'm afraid to mess up my DD by poking around too much. Here's my auto-scan, for what it's worth.
Thursday,18,August,2016,17:57:29:27545
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: xxx License Plate:
Mileage: 1542km-958mi   Repair Order:
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 32 3C 42 44 47 52
          55 5F 75 A5 A9
VIN: xxx Mileage: 1542km-958miles
Address 01: Engine (J623-CXCB)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00324464002F1000
   Shop #: WSC 00066 790 00218
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
   ROD: EV_ECM20TFS0205G0906259D.rod
   VCID: 2F43EE497676D53A09-807A
Readiness: 1110 1101
   Part No SW: 0D9 300 020 J    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H53 4902
   Revision: 06253104    Serial number: TFK01511271369
   ROD: EV_TCMDQ250021.rod
   VCID: 1C19298517C05EA25C-8048
   Revision: 00000000    Serial number: 63505000002062
   Coding: 01FA6BA15425096D007A020441C36880D62A9000408216B6164350D3C089
   Shop #: WSC 01383 790 50316
   VCID: 7AD50F1DFDB4C092EE-802E
   Revision: 00021000    Serial number: 0382118408
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_VW37.rod
   VCID: 3A55CF1DBD340092AE-806E
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 00020014200100000105004012111402
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: 42A5B7FDD5E44852F6-8016
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 86581212150294
   Coding: 00111A464041A2E969E44000001407201800000000000000000000000000
   Shop #: WSC 00066 790 00228
   ROD: EV_BCMBOSCH_VW37.rod
   Component: WWS    150814  043 0581
   Serial number:         160219145307
   Coding: 0E4DFD
   Serial number: S3Y15M12D18H17M28S42
   Coding: 90A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591
   Component: J245 PS60.036  H06 0150
   Serial number: 03691613941508151346
   Coding: 181803
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0054
   Revision: --------    Serial number: 39491533100437
   Coding: 0031165011
   ASAM Dataset: EV_EPHVA2CAU3700000 003021
   ROD: EV_EPHVA2CAU3700000_VW37.rod
   VCID: 47B3A6E9FEC66D7A21-8012
   Serial number: 15081503210253
   Coding: 01045600FE0739
   Serial number: 15121541350377
   VCID: 3753D6298E261DFA51-8062
   Serial number: 003GCR03Z6HX
   Occupant Detection:
   Component: BF-Gewichtss.  H12 0021
   Serial number: IBH00000000000476AK7
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 000 212 15
   Serial number: 35700000000E47101818
   Subsystem 3 - Part No SW: -----------    HW: 480 000 212 15
   Serial number: 35800000000DAC29181T
   Subsystem 4 - Part No SW: -----------    HW: 480 403 011 15
   Serial number: 3510002C71E24312214L
   Subsystem 5 - Part No SW: -----------    HW: 480 400 412 15
   Serial number: 3520002BF1E3EA9141CL
   Subsystem 6 - Part No SW: -----------    HW: 480 401 012 15
   Serial number: 3550002AF1E3EAA1F33S
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 012 15
   Serial number: 3560002AF1E3EAA5024I
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20151218400063
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 73CB2239DADEB1DAAD-8026
   Part No SW: 5G1 920 856 A    HW: 5G1 920 856 A
   Component: KOMBI         342 6420
   Coding: 0BAD091AFD98CF0502887A0B5000000000000000
   VCID: 2C79F9454760AE222C-8078
   Revision: --------    Serial number: 10121510802491
   Coding: 0101000830085900FB00023B9C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07030
   VCID: 79D71011F8B2CB8AE7-802C
   Component: E221__MFL-DC1  H10 0040
   Serial number: 29150001362380105282
   Coding: 35FFFF
   Revision: 00000000    Serial number: 15000236326005
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_VW37.rod
   VCID: 3449E1259F50F6E274-8060
Address 32: Differential Locks (J492)       Labels: 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00021.10.15
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   Serial number: 0389558252
   Coding: 02011103
   ROD: EV_HREntryHella.rod
   VCID: 3C59C905B7003EA2BC-8068
   Serial number: 260116060500YQ
   Coding: 003E13200000020000000000
   VCID: 43ABB2F9CAFE415AFD-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 D    HW: 5Q4 959 811 D
   Serial number: 00000000000011189113
   Coding: 011000
   Coding: 9302
   VCID: 3957D011B8320B8AA7-806C
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H20 0130
   Revision: 00000001    Serial number: VWZ8Z1FBA019Z7F
   Coding: 2200000000AAAAAA000000000000
   ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 6DFF3441BCFA672A7B-8038
   Serial number: 25011606050793
   Coding: 003E13200600020000000000
   Subsystem 1 - Part No SW: 5Q4 959 812 D    HW: 5Q4 959 812 D
   Serial number: 00000000000011434541
   Coding: 091000
   Coding: 021203010B000400
   VCID: 40A1BDF5DBE85A42E0-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Component: MU-S-NS-US    820 0613
   Coding: 027300020000000051220002001808001F0203F401200105C6
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 71C72831A0C283CA5F-8024
   Component: ABT_Std-2_Nav  H53 1031
   Serial number: VWZ8Z9RJX001WH
          B11CF 53 [009] - Deactivated
                    Reset counter: 67
                    Mileage: 838 km
                    Date: 2016.07.31
                    Time: 12:27:52
                    Voltage terminal 30: 12.0 V
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 133 mA
                    SDARS_tuner_status_2-Reception quality: good_signal
                    SDARS_tuner_status_2-Tuner für Satellitenradio: Status der Voraktivierung: 07
                    SDARS_tuner_status_2-Tuner für Satellitenradio: Wert der Voraktivierung: 07
6691 - Local Data Bus
          U10BA 00 [008] - No Communication
                    Reset counter: 138
                    Mileage: 1114 km
                    Date: 2016.08.06
                    Time: 09:41:45
                    Voltage terminal 30: 13.9 V
                    Network diagnosis-Status: not enabled
   Coding: 02730002C2823A017F1E06000000
13636864 - Mobile Online Services
          B149A F0 [008] - Vehicle Condition Report
                    Reset counter: 105
                    Mileage: 773 km
                    Date: 2016.07.29
                    Time: 15:32:46
   Serial number: 10000468099
   Coding: 0100000000020306000400010100000100
   ROD: EV_MFKBoschAU370.rod
   Serial number: 151204200580
   VCID: 6BFB3A5982EE691A65-803E
End-------------------------(Elapsed Time: 04:32)--------------------------
nathan16mk7R
C?ID=264933
          55 5F 75 A5 A9
   Revision: --H13---
   Coding: 030C0C
   Revision: 00001K01
   Coding: 0E4DFD
   Coding: 90A8DD
   Sun Roof:
   Coding: 181803
   Coding: 0031165011
   Occupant Detection:
   Coding: 303131
   Coding: 0C10
   Coding: 35FFFF
   Coding: 0001
   Coding: 02011103
   Coding: 011000
   Coding: 9302
   Coding: 091000
   Coding: 2E0000
   Coding: 2E0000
                    Reset counter: 67
                    Mileage: 838 km
                    Date: 2016.07.31
                    Time: 12:27:52
                    Reset counter: 138
                    Mileage: 1114 km
                    Date: 2016.08.06
                    Time: 09:41:45
                    Reset counter: 105
                    Mileage: 773 km
                    Date: 2016.07.29
                    Time: 15:32:46
For mine I had to go into the headlight adjustment mode to get rid of the error. Just go into the adjustment mode and then say they are aimed. Then I never got the error again.
http://www.ross-tech.com/vag-com/cars/xenonalignment.html
Reactions: ABQ
   #34
DV52
C?ID=194404
Nathan: I can't comment on your suggested fix, but I believe that the pertinent instructions for aiming the headlights on HID fittings for a mk7 are HERE (I think your link might be for an earlier model)
   #35
nathan16mk7R
C?ID=264933
Ah, yes, that is correct. Thanks as always Don!
Reactions: ABQ
   #36
ABQ
C?ID=281382
As promised...
Iq51eHLeAw1JVIwAurvKks8wbDPKAEjavIVahjSMGF4ByMJ2xFS_JRN-6YUCpsAvZzoRMT9QSPvUjsr_knOECAIaJHLZnbYH1yaPMvKY1d2DAP73aUYp_vcD7ofhUh3OqXHsINvWhC4BcfEKu_cfZHueBUU8p_om7GqqwFFwXEriN1j9hkZHMeJ3KtW3outqEU_VRjlUXM8rO3TA2tcy183wY-2pheuSTdp-bxeApfEBfB7aGboJykxY3Cp9-BvP3oL4xprGsiP-lS8qy0BNyQ1GHzkwkVK6HCv0zVuSNQr4rx33sNG8GrIc07zSDGblun7UzxanOG2PgyyVGLBnKHoNpbtb45CdXQ_zR5FGtJzVBWIkYRUuBXSBrVomb5SfAehqJylcj-uO2wZcuWpPYClredAiTblPos-IGLPjgFg7-mXmznE_vPLLAzslX9o3B9g6pWz1IaAcMm4_GvtRER_U00Z7bLFdYryrTQvB9sD0jP-v1MUaefv8UeBTpjL6p4QMOPAYzwt1z2usxPc2lRMjPr7wQVpXXq2bMke4aXYoou94oihDp10F0AO7-QO9X04WaoQmC2vfZ_usKKXpCu6CBNHhRIo=s324-no
Entering and exiting the headlight-adjustment mode did the trick - no more fault in the MFD! Many thanks to you both, Nathan and Don.
Curiously, when doing this tweak, the option for Xenon headlights did not appear in the pull-down for Byte 2 in the BCM long coder:
EEvCC05sOmU0o_RbnOlMCHAkicHEZLVs76q2-KqwozkOqriactQLfBhh-JkAyYnWnBib6eP-3-4v0yb1fI12R67uMAfyXQqA39lbyyHBTfgX-gNDYH6h9QykppNb4LXUu3qoCvVkvzOlWvSms6KMOkcc-0s8r_PpwsGRRzq5FcH742YFRSDRaC9wXD-H_EzecsouOh-mbBZv47Nee0f9E3kPgURaRdu8Ybx0mFP97QV8MAtkC6m1gEPWokkE0ahfIO4qvz8FxmPU4hmY4g7j05lh1sB_w5ZID54hRO9tpyQpQyesmpoQa5Z4O8kAEkL7bSG5o46VD9YbX1KrzNNBQmY2BTctRJtFQ7xGvoJxz1HCmBMSeON_HggRKEvmYPzRO6NbfakNy0GPveElxJRAH-LXKISwI2aiyrvLnnHYBdpeIkZ-N7FUjiOAJ7ide6tLWKzrDZvyzeWofQGBrJUCw7FCr5i2VfkoGwBA9jM7_N-A7Vj415OVsl0_HRgYk4_CgJpbub3O0DHE0A2bAozPsuUX2ZASu4NSsJj336t5YNbplKjIVfyawvv2giNAlz0Ub8-9GFQSpn4UANfaM6iu88oo3fI8sPo=w1068-h458-no
So I just changed bit 0 manually from a '0' to a '1.' This step was critical, as the menu option for "Light Assist" would not show in the head unit menu if I did not make this change:
iuDbkazW2o969Hfmz40FMC2G2JtMW4o_zwyKwY4mTLIOb4gyOhcS4PDqBUqA1bBCx0z7N6SgE0Splh6pvdqaJDwApi89JjSCkIxfJ0IaKn3FXC9aX6Z67nV2Tdqjk3B8JP5mBawLLGHNHJQn-Lt91RRLATh9tLZM2pWlfKxawmEsBx_OZDm4mQFB4pVigHPA0ImwZC9aLgtfgyAQ3VZ1_OKusRfVsXCdvjJeFJps4OLvSzMqvtmGMXvuakf8LwneqAhj1M6BQay401uY_mG06JZF1Dw5kTLbyJQ5Rn06TGnT6d_M6lyiZOsnoR7pCw4hqbpgywRK9vs96VTe8F0tF2f7NfX7RQ_LQgbpk8S1Y0hEHTT7X85q6CUZgUshWJxrDeMfhb9hFRvIDQrJoyJxe968Q9v2cYiDSRCwHllKc3lQUmVTT8ulzy346JPoDf869RSnSKPWxqzLWAO3eV_61ABE-nRFs8N_zopEZVAq7n8RgFndcaFJNfSLLbq1S2IZzXongtkgRrVTR-zDAbW-obKPEsbo80ftlKjZao-AtYi3IR6IGQ4kgWsjNVbc6_MWxkjxOQbHfhxWEMXfBEyOg8BisbTgDPM=w1069-h458-no
Here is a link to the complete process I followed, with the addition of entering the headlight-adjustment program as suggested by Nathan. It's post #29 on the page, and proper credit is given in the post:
http://www.briskoda.net/forums/topic/299424-octavia-iii-vcds-adaptations-tried-and-tested/#entry3821291
Now, I just need to test the system's functionality. I will report back here with positive/negative results. Thanks again, everyone!
   #37
ABQ
C?ID=281382
Just reporting back with the results of enabling High Beam Assist on my 2016 NAR GTI w/DAP...
I finally got a chance to do some night driving outside the city last night, and the High Beam Assist works very well. As reported by others, there are times when the lights do not dip as quickly as I feel they should, but for the most part, they do dip very quickly as soon as another vehicle's headlights come into view.
Very happy with this mod. Thanks again to all who helped make it possible.
McSpiffy
Oswego, IL
C?ID=224526
ZY7P2Z
Greetings: I attempted the High Beam Assist on my 2016 NAR Golf Sportwagen TSI SEL but ran into an issue when I followed the directions from post #29; it appears that the only option for headlight styles following this is the halogen whereas I have the bi-xenon. I did get the correct sub-menu to pop up in my MMI but each time I attempted to activate it, an error code would be thrown. I included the twelve different options under "Assistance Light Functions". Attempting the "IDE08786-ENG116637-Assistance light functions-Menueesteuerung Fernlichtassistent" will not provide an option for bi-xenon. Any insight would be appreciated!
e8eabcac9
McSpiffy
Oswego, IL
C?ID=224526
Attempted High Beam Assist tweak, not realizing my power was getting too low - errors
Thursday,22,June,2017,12:46:33:06278
VCDS Version: 17.6.0.2 (x64)  HEX-NET CB: 0.4341.4
Data version: 20170602 DS274
VIN: 3VWC17AU4GM501532   License Plate: V93 8607
Mileage: 29169km-18124mi   Repair Order: 062217B
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 47 52 55 5F
          75 A5
VIN: 3VWC17AU4GM501532   Mileage: 29169km-18124miles
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 F    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 091A00322464002F1000
   Shop #: WSC 00066 790 00221
   ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
   ROD: EV_ECM18TFS0208V0906264F.rod
   VCID: 3FCE8369A6653ABFF8-806A
15186 - Park/Neutral Switch Input Circuit
          P0851 00 [100] - Short to Ground
                    Mileage: 29160 km
                    Date: 2017.06.21
                    Time: 09:29:16
                    Coolant temperature: 20 ∞C
                    Intake air temperature: 23 ∞C
                    Voltage terminal 30: 7.285 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 98 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 16.015625 %
                    FUP_H_SAE: 2520.0 kPa
   Part No SW: 09G 927 749 AP    HW: 09G 927 749 AP
   Component: AISIN AG6 G3  129 2943
   Coding: 010200000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW25.rod
   VCID: 075E5B89BE35B27F80-8052
   Revision: 00000000    Serial number: 61255000000354
   Coding: 04FA6AA12420096D007C020381C5292056249000408194B416435052C082
   VCID: 7AB8327DFDC7DF978F-802E
0128 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 98
                    Mileage: 29160 km
                    Date: 2017.06.21
                    Time: 09:29:02
   Revision: 00021000    Serial number: 0367374266
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3A38F27DBD471F97CF-806E
   Revision: 00001K01
   Coding: 02020024200100000105000012111402
   VCID: 42C88A9DD597575797-8016
          B10CD 00 [008] -  -
                    Reset counter: 99
                    Mileage: 29169 km
                    Date: 2017.06.22
                    Time: 12:21:58
                    Voltage terminal 30: 11.0 V
   Revision: --------    Serial number: 86581605150679
   Coding: 00511A464041A2E969E44000001407001800000000000000000000000000
   Shop #: WSC 00066 790 00211
   ROD: EV_BCMBOSCH_015_VW37.rod
   Component: WWS    150430  043 0581
   Serial number:         150628095715
   Serial number: S5Y15M05D11H20M57S08
   Coding: 90A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H03 0004
   Serial number: 0000FST0009CPKU00000
   Coding: 191800
   Roof Blind:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H03 0004
   Serial number: 0000FST0009CQ2D00000
   Coding: 191800
131586 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 98
                    Mileage: 29160 km
                    Date: 2017.06.21
                    Time: 09:28:56
563221 - Databus
787212 - Windshield Washer Pump
          B1261 01 [008] - Electrical Failure
204546 - Remote key 2
          B147A 18 [008] - Current Too Low
                    Fault Frequency: 60
                    Reset counter: 95
                    Mileage: 11210 km
                    Date: 2016.07.27
                    Time: 09:04:47
   Revision: --------    Serial number: 39431513200575
   Coding: 0031165011
   ROD: EV_EPHVA2CAU3700000_003_VW37.rod
   VCID: 47DE9B89FEB5727F40-8012
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 D
   Serial number: 13031503210237
   Coding: 01045400FE0739
0077 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 98
                    Mileage: 29160 km
                    Date: 2017.06.21
                    Time: 10:29:10
                    Control Module temperature: 22 ∞C
                    Voltage terminal 15: 10.4 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s≤
   Serial number: 003GCR01Y1DL
   Occupant Detection:
   Serial number: IBH0000J1500031ZIL0K
   Coding: 303137
   Subsystem 2 - Part No SW: -----------    HW: 480 002 305 15
   Serial number: 357000000000A560A418
   Subsystem 3 - Part No SW: -----------    HW: 480 002 205 15
   Serial number: 358000000000D0B06418
   Subsystem 4 - Part No SW: -----------    HW: 480 402 704 15
   Serial number: 3510002C91A91E714070
   Subsystem 5 - Part No SW: -----------    HW: 480 402 804 15
   Serial number: 35200029B1A87872711+
   Subsystem 6 - Part No SW: -----------    HW: 480 400 505 15
   Serial number: 3550002AF1A8787292DL
   Subsystem 7 - Part No SW: -----------    HW: 480 400 505 15
   Serial number: 3560002B31A878729376
   Revision: FF032032    Serial number: 20150328500718
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB_VW37.rod
   VCID: 73A61F59DAADAEDFCC-8026
   Part No SW: 5G1 920 840 A    HW: 5G1 920 840 A
   Component: KOMBI         242 6420
   Coding: 0BA4111AED98CF0502886A0B5000000000000000
   Shop #: WSC 00066 790 00194
   VCID: 2502310124F9806F92-8070
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 22051510000845
   Coding: 0901000830085900FB00021A1C0F00000001050000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 75A22141D4D9B0EFE2-8020
   Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150000641010105136
   Coding: 35FFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0071941
   Revision: 00000000    Serial number: 15000127554002
   Shop #: WSC 00066 790 07025
   ROD: EV_ELVMarquMQB_004_VW37.rod
   VCID: 3424DC459F23E9E715-8060
          U1400 00 [008] - -
                    Reset counter: 98
                    Mileage: 29160 km
                    Date: 2017.06.21
                    Time: 09:28:55
                    ELV State: 04
                    Information Clamps: 77 60
                    CoCo State: A0 01
                    WFS State: 00 06
                    Vehicle speed: 0.00 km/h
                    Voltage: 4C
                    AD-Value H-bridge: 25
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 00
Address 3C: Lane Change (J1086)       Labels:* None
   Serial number: 0368374670
   Coding: 02011103
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3C34F465B77321A7DD-8068
   Serial number: 0506150605043U
   Coding: 003A13200000040000000000
   VCID: 43C68F99CA8D5E5F9C-8016
   Serial number: 00000000000001360106
   Coding: 011000
589829 - Window Regulator; Rear Driver side
          B131F F5 [008] - Supply Voltage too Low
                    Reset counter: 98
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 1302
   Component: MIB2_lite_amp H20 0110
   Revision: 00000001    Serial number: VWZ8Z1FBA00BE4Z
   VCID: 6D920921BC89782F1A-8038
1539 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 98
                    Mileage: 29160 km
                    Date: 2017.06.21
                    Time: 09:29:01
                    Voltage terminal 30: 8.4 V
   Serial number: 170615060504TQ
   Serial number: 00000000000001369331
   Coding: 091000
589845 - Window Regulator; Front Passenger side
          B1320 F5 [008] - Supply Voltage too Low
                    Reset counter: 98
                    Mileage: 29160 km
                    Date: 2017.06.21
                    Time: 09:29:09
   Coding: 061A00010B000400
   VCID: 40CC8095DB9B454781-8014
   Coding: 2E0000
   Coding: 2E0000
   Component: MU-S-NS-US    H25 0241
   Serial number: VWZAZ2R0154122
   Coding: 027302020000000051220002001808001F0100F401200105C6
   VCID: 71AA1551A0B19CCF3E-8024
   Serial number: VWZ8Z9RFC000K0
   Subsystem 2 - Part No SW: 3G0 919 866 B    HW: -----------
   Component: NAR 2015/16  --- 0220
          U1400 00 [008] - -
                    Reset counter: 98
                    Mileage: 29160 km
                    Date: 2017.06.21
                    Time: 09:29:02
                    Voltage terminal 30: 8.3 V
   Component: OCULowMQBUS   007 0564
   Coding: 02730202C2823A017F1E06000000
   Shop #: WSC 00066 790 00323
   ROD: EV_OCULowMQB_VW37.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Serial number: 10000355732
End----------(Elapsed Time: 01:47, VBatt start/end: 13.7V/13.7V)-----------
   #40
McSpiffy
Oswego, IL
C?ID=224526
New scan after clearing all the DHPs
I didn't realize all the issues I caused until two hours into our four hour trip to Des Moines, IA for a family reunion. It suddenly became quite warm in the car despite it being set to 66F; when I went to adjust the fan there was no response! The only resolve was to stop and shut down the car - it appears a momentary wait and restart cleared the issue. The problem arose again on our trip home. I'll see if I actually cleared it with my eight hour trip to Arkansas to visit my parents . . . yes, I'm a glutton for punishment! Here is the latest scan:
Tuesday,27,June,2017,20:16:52:06278
Mileage: 30204km-18767mi   Repair Order: 062717C
          75 A5
VIN: 3VWC17AU4GM501532   Mileage: 30204km-18767miles
   Revision: --H13---
Readiness: 1010 1101
   Coding: 030C0C
   Revision: 00001K01
   Coding: 00511B464041A2E969E44000001407001800000000000000000000000000
   Coding: 90A8DD
   Sun Roof:
   Coding: 191800
   Roof Blind:
   Coding: 191800
534549 - Databus
                    Reset counter: 65
                    Mileage: 30204 km
                    Date: 2017.06.27
                    Time: 20:10:25
   Coding: 0031165011
   Occupant Detection:
   Coding: 303137
   Coding: 0C10
   Coding: 35FFFF
   Coding: 02011103
   Coding: 011000
   Coding: 1302
   Coding: 091000
   Coding: 2E0000
   Coding: 2E0000
End----------(Elapsed Time: 01:45, VBatt start/end: 13.7V/13.7V)-----------
