- Joined
- Apr 28, 2014
- Messages
- 52
- Reaction score
- 31
- Location
- New Zealand
- VCDS Serial number
- C?ID=213797
Hi All
Got this one from another garage, The have had glow plug issues and it has a brand new set of glow plugs in. On refitting everything, there is no output to the glow plugs. Fuses ok, they have put another glow control relay in and still no good, auto scan below. I haven't dealt with TDI's at all before so some help would be appreciated. As far as I can tell from wiring diagrams, we have all the correct inputs to the relay, but no signal from the ECU. What conditions need to be met for this to all work?
Cheers
Cheers
Tuesday,15,December,2015,15:45:01:55685
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
VIN: WAUZZZ8E26A011020 License Plate: HFK883
Mileage: 146960km-91316mi Repair Order:
67 69 75 76 77
VIN: WAUZZZ8E26A011020 Mileage: 146960km-91316miles
Address 01: Engine Labels: 03G-906-016-BLB.clb
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC G000SG 9880
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 00198 210 75874
VCID: 75E1F3AF1C18B39648-8020
19794 - Control Circuit for Glow Plug Controller 1
P3338 - 000 - Electrical Malfunction - Intermittent
Torque: 74.0 Nm
Voltage: 11.86 V
Bin. Bits: 00101100
Temperature: 32.4°C
Bin. Bits: 01010000
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK
Component: ESP8 front H04 0120
Coding: 0004401
Shop #: WSC 06325 000 00000
VCID: 285FEADB9B2A9E7E03-807C
Fault Frequency: 24
Reset counter: 37
Hex Value: 0x0000
Hex Value: 0x0222
Hex Value: 0x0024
Hex Value: 0x018F
Hex Value: 0x0001
00493 - ESP-Sensor Unit (G419)
Reset counter: 37
Hex Value: 0x0200
Hex Value: 0x4202
Hex Value: 0x001B
Hex Value: 0x34AF
Hex Value: 0x0001
Part No: 8E0 820 043 AK
Component: A4 Klimaautomat 2831
Coding: 00000
VCID: 6ADBD0D316A66C6ED5-5124
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0504
Coding: 10001
Shop #: WSC 06325
VCID: 3B75259729BC25E67E-4B00
02396 - Parking Light Rear Left (M4)
30-00 - Open or Short to Plus
02738 - Bulb for Tail/Brake Light; Left
01501 - Bulb for Blinkers; Rear Left (M6)
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H11 3530
Revision: 91H1135 Serial number: 0036M004X11R
Coding: 0033622
VCID: 3B7525977ABC25E67E-806E
Subsystem 1 - Serial number: 6332DRB4015A109AJ
Subsystem 2 - Serial number: 6342DRB40190872DO
Subsystem 3 - Serial number: 6352ARB4006900D7H
Subsystem 4 - Serial number: 6362ARB4006AEBCF8
Subsystem 5 - Serial number: 63729RB4007500D3B
Subsystem 6 - Serial number: 63829RB40074FEAA1
00532 - Supply Voltage B+
Fault Frequency: 10
Reset counter: 39
01221 - Crash Sensor Side Airbag; Driver Side (G179)
Fault Status: 00101011
Reset counter: 39
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 04042
Shop #: WSC 06325
VCID: 4189577F4B504F3624-4B00
01301 - Control Module for Voice Recognition (J507)
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 951 E HW: 8E0 920 951 E
Component: KOMBI+WFS 4 H12 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0006441
Shop #: WSC 00999 444 64523
VCID: 2C5716CB8CD2B25EE7-5124
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006441
VCID: 2C5716CB8CD2B25EE7-5140
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
VCID: 6BD5D5D7195C7566AE-515E
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CA
Component: Komfortgerát T3B 3332
Coding: 07167
Shop #: WSC 06325
VCID: 72EBC8B33E76A4AE6D-4B00
Subsystem 1 - Part No: 8E2959802F
Component: Tõrsteuer.FS BRM 0406
Subsystem 2 - Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
01134 - Alarm Horn (H12)
37-10 - Faulty - Intermittent
01370 - Alarm triggered by Interior Monitoring
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
35-10 - - - Intermittent
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 D
Component: concert II GRO 0004
Coding: 01065
Shop #: WSC 06325
VCID: 285FEADBC82A9E7E03-4B00
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 C HW: 8E0 919 283 C
Component: Parkhilfe 8-Kan H06 0020
Revision: 00H06000 Serial number: 00067802120511
Coding: 0000014
VCID: 306F02BBA0FAD6BEDB-5140
Fault Status: 00101001
Fault Frequency: 116
Reset counter: 167
Date: 2000.01.01
Time: 00:00:00
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
Fault Status: 01101001
Fault Frequency: 97
Reset counter: 125
Date: 2000.01.01
Time: 00:00:00
01629 - Sensor for Parking-Aid; Front Left (G255)
Fault Frequency: 145
Reset counter: 167
Date: 2000.01.01
Time: 00:00:00
Part No SW: 8P0 862 335 C HW: 8P0 862 335 C
Component: FSE_255x BT H18 0160
Revision: 00000001 Serial number: 00000000236973
Coding: 0001622
VCID: 366334A3429EF88E81-5124
End-------------------------(Elapsed Time: 07:39)--------------------------
