1st problem: My idle became erratic, and the car would stall intermittently.
2nd problem: ABS codes. Sometimes the ABS will activate at lower speeds for no reason. ABS and brake light in dash on intermittent. I've reset this, it keeps returning.
TIA,
Dan
VIN 3VWHD81H2XM212591
TIA,
Dan
Sunday,15,November,2015,14:10:53:53806
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
Chassis Type: 1H - VW Golf/Vento III (1992 > 1999)
Scan: 01 02 03 08 12 15 25 41 56
Address 01: Engine Labels: 021-906-259-AAA.lbl
Part No: 021 906 259 N
Component: MOTRONIC M5.9 HS V03
Coding: 00000
Shop #: WSC 00066
VCID: 2041EE0DA011CD3E7D-4B18
17988 - Throttle Actuator (Bank 1)
P1580 - 35-10 - Malfunction - Intermittent
Address 03: ABS Brakes Labels: 3A0-907-379.lbl
Part No: 3A0 907 379 E
Component: ABS/EDS ITTAE 20 GI V00
Coding: 03704
VCID: 2C590A3DDCD9195ED1-4A9C
7 Faults Found:
35-10 - - - Intermittent
16-10 - Signal Outside Specifications - Intermittent
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 603 T
Component: AIRBAG VW3 - V04
Coding: 00084
Shop #: WSC 00066
VCID: 3A753C65268DB7EE53-4B00
Address 56: Radio Labels: None
Part No: 1JO 035 180
Component: RADIO 0002
Coding: 00401
Shop #: WSC 00066
VCID: 7BFBF96169374EE608-4B7C
00852 - Loudspeaker(s); Front
00853 - Loudspeaker(s); Rear
End-------------------------(Elapsed Time: 01:46)--------------------------
