Results 1 to 5 of 5
Thread: Issue with coding rear lead lamps golf mk6 retrofit
    Oct 2015
    Hi, we are new to this forum and are an independent Volkswagen Audi repairer in the southeast of the UK.
    He have a small issue which I'm sure somebody may be able to help with. We have a 2009 VW Golf, it has standard halogen headlights fitted, front fog lamps and we have just fitted rear led tail lamps to it. Everything work as it should but the bulb failure light comes on and shows a fault with the rear fog lamp. Have tried coding to 04 and 15 but no luck there.
    Can anybody help out.
    Here is a scan:
    Wednesday,14,October,2015,15:40:44:45214
    VCDS Version: 15.7.0.1 (x64)
    Data version: 20150729
    Dealer/Shop Name: AVIT
    VIN: WVWZZZ1KZ9W467753   License Plate: JAWAU
    Mileage: 116250km-72234mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZ9W467753   Mileage: 116250km-72234miles
    Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 LA    HW: 03L 906 022 G
       Component: R4 2,0L EDC G000SG  3893
       Revision: 13H01---    Serial number:
       Coding: 0001072
       VCID: 6FE72FDC7E2D9246BF-803A
    Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
       Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0106
       Revision: 00H35001
       Coding: 163B400D09280001681202E9901C00823400
       VCID: 74ED20B0D70BB19E42-8020
       Part No SW: 3C8 907 336     HW: 3C8 907 336
       Component: Climatic      120 0102
       Revision: 00004001
       Coding: 0000000000
       ASAM Dataset: EV_Climatic A01001
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 6AD13EC88DCF776EE8-803E
       Part No SW: 1K0 937 086     HW: 1K0 937 086
       Component: BCM PQ35  M   020 0358
       Revision: 00020000
       Coding: 48180A3A9825F1C044080080140081E041510488536D8960648000000002
       VCID: 6DDB35D4B42160568D-8038
       Component: Wischer 21110  21  0501
       Coding: 009795
       Component: RLS 121208 05  54  0402
       Coding: 0330AD
       Subsystem 4 - Part No: 1K0 951 605 D
       Component: LIN BACKUP HO  H08 9001
    01506 - Bulb for Rear Fog; Right (L47)
                        Reset counter: 13
                        Mileage: 116255 km
                        Date: 2010.03.06
                        Time: 15:08:53
                        Voltage: 11.80 V
                            Term 50 Off
                        Reset counter: 13
                        Mileage: 116255 km
                        Date: 2010.03.06
                        Time: 15:09:11
                        Voltage: 11.80 V
                            Term 50 Off
    Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
       Part No SW: 5K0 919 475     HW: 5K0 919 475
       Component: PARKHILFE 8K  H07 0002
       Revision: --------    Serial number: 60630830402573
       Coding: 100001
       VCID: 73EF23ACD205B6A65B-8026
       Part No SW: 5K0 959 655     HW: 5K0 959 655
       Component: AirbagVW10    022 0507
       Serial number: 003C2D06RRUY
       Coding: 00003136
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01003
       ROD: EV_AirbaVW10SMEVW360_SE36.rod
       VCID: 77F717BCCE7DDA8667-8022
       Component: S.Sens.Fahr.V  U01 ----
       Serial number: 12076443ZZZZZZZZZZZZ
       Component: S.Sens.Beif.V  U01 ----
       Serial number: 582D0240ZZZZZZZZZZZZ
       Serial number: 14311E38ZZZZZZZZZZZZ
       Serial number: 1A471576ZZZZZZZZZZZZ
       Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
       Coding: 0000532
       VCID: 78F514800B63D5FE6E-802C
       Subsystem 1 - Part No: 3C8 959 537 B
       Component: E221__MFL-TAP   H4 0021
       Coding: 00000226
       Part No SW: 5K0 920 970 E    HW: 5K0 920 970 E
       Component: KOMBI         H21 0029
       Coding: 470B00
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
       VCID: 3065ECA06B93CDBEE6-8064
    Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
       Revision:   H07 01    Serial number: 281108F2001417
       Coding: E9A07F06000212000003
       VCID: 3777D7BC46FD1A86A7-8062
       Component: IMMO          H21 0029
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
       Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
       Component: SG EXT.PLAYER H13 0084
       Revision: A1001003    Serial number: 7667323980
       VCID: 26490AF85157930E0C-8072
       Part No SW: 1K0 959 701 AM    HW: 1K0 959 701 AM
       Component: Tuer-SG         008 2016
       Coding: 0000692
       VCID: 79F311843069CCF611-802C
       Part No: 1K0 909 144 E
       Component: EPS_ZFLS Kl. 70     2501
       Revision: 00H15000
       Shop #: WSC 01324 785 00200
       VCID: 2C5DF8D08FBBA95EDA-8078
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
       Part No SW: 1K0 959 702 AG    HW: 1K0 959 702 AG
       Component: Tuer-SG         008 2034
       Coding: 0000948
       VCID: 74ED20B0170BB19E42-8020
    Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 3C8 035 195     HW: 3C8 035 195
       Component: Radio RCD510  040 0144
       Revision: 00000001    Serial number: VWZ1Z3I5417306
       Coding: 0500040004
       Shop #: WSC 05314 000 00000
       VCID: 65CB4DF46CD15816C5-8030
    03138 - Input AUX IN
                        Reset counter: 88
                        Mileage: 264866 km
                        Time: 07:36:07
       Part No SW: 1K0 959 703 AL    HW: 1K0 959 703 AL
       Component: Tuer-SG         007 2009
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       VCID: 7AF10E88356FC7EE18-802E
       Part No SW: 1K0 959 704 AL    HW: 1K0 959 704 AL
       Coding: 0000144
       VCID: 7BFF0B8C3A55FEE603-802E
    End-------------------------(Elapsed Time: 02:21)--------------------------
    This BCM has a really early SWL so the original value, which I suspect was HEX 02, might have been shown from the factory. Either way I would try that to see what happens since 04 and 15 failed. If you still have the same issue I'm pretty sure the rear fog was an incandescent bulb so you can check it - but is the rear fog on the proper (right) side of the car?
  3. Likes Uwe liked this post
    Oct 2015
    Hi Dana, thanks for the info and help. Yes you are correct it was originally 02 but this flagged faults with every lamp on the rear. The fog lamp bulb itself is an led bulb and part of the bulb holder/cluster. It is on the right hand side of the car, i.e behind driver. Coding to 15 did work and showed no faults but the inner lamps on the tailgate would did work as taillights and only as brake lights.
  5. Likes Dana liked this post
  6. #4
    Hmm OK. If the fog worked with Hex 15 I would assume it is a good lamp and the right side (as opposed to a LHD light setup which would require you to rewire at the BCM) is correct.
    Hex 04 shoulda worked. This list is dated (2010-2012 NAR) but please let us know if any alternative values work:
    Early 1K0 SWL (0536 and lower) modules:
    04 - 1 Rear fog / 1 Reverse light
    20 - 2 Reverse lights / No rear fog
    Newer 1K0 SWL (0572 and higher ) modules:
    15 - 1 Rear fog / 1 Reverse light
    22 - 1 Rear fog / 1 Reverse light (possible RHD car)
    43 - 1 Rear fog / 1 Reverse light (with tails on with front DRLs)
    45 - Row 1 Rear Fog / 1 Reverse light (with tails on with front DRLs) see note
    > note: Hex 43 did not work on a Netherlands vehicle but 45 did in a LED tail retrofit situation?
    21 - 2 Reverse lights / No rear fog
    1F - 2 Reverse lights / No rear fog
    All SWL with conventional bulbs, No LED:
    02 - RoW default, 1 Rear fog / 1 Reverse light
    03 - NAR default, 2 Reverse lights / No rear fog - up to SWL 0615 M.Y. '10 > '11 stock
    42 - RoW default, 1 Rear fog / 1 Reverse light
    20 - NAR default, 2 Reverse lights / No rear fog - from SWL 0651 M.Y. 2012 stock
  7. Likes Uwe liked this post
  8. #5
    Feb 2018
    Did you manage to solve this i am having the same issue
