Can someone help me to reset my cluster? Auto scan attached.
Thank
Thank
Sunday,11,October,2015,10:46:28:23801
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WVGZZZ5NZDW072782 License Plate:
Mileage: 16320km-10140mi Repair Order:
Chassis Type: 5N (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 42 44 46 52 53 56 61
62 72 77
VIN: WVGZZZ5NZDW072782 Mileage: 16320km-10140miles
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 FQ HW: 03L 907 309 AE
Component: R4 2,0L EDC H28 4573
Revision: 41H28--- Serial number: 00000000000000
Coding: 00250032042701080000
ASAM Dataset: EV_ECM20TDI01103L906018FQ 003011
ROD: EV_ECM20TDI01103L906018FQ_VW36.rod
VCID: 7EF3B636E1AB8CCE2F-802A
4815 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [167] - -
Mileage: 122155 km
Date: 2016.12.04
Time: 00:23:25
14413 - Implausible Data Received from ABS Control Module
U0415 00 [039] - -
Mileage: 122155 km
Date: 2016.12.04
Time: 00:23:21
5250 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 122155 km
Date: 2016.12.04
Time: 00:23:21
5523 - Engine Start Blocked by Immobilizer
P1570 00 [167] - -
Mileage: 16329 km
Date: 2015.10.11
Time: 00:00:31
Address 02: Auto Trans (J743) Labels: 0BH-927-711.clb
Part No SW: 0BH 300 011 S HW: 0BH 927 711 C
Component: DSG DQ500-7A H07 1806
Revision: 00H07V01
ROD: EV_TCMDQ500021_SE36.rod
VCID: 326B5206657398AE9B-8066
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 BC HW: 5N0 614 109 BC
Component: J104 C6 450M V4BF 0011
Revision: --H07--- Serial number: 00000006566726
Coding: 0010000
VCID: 6DD1817A74CD075686-8038
7 Faults Found:
Speed: 252.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 0.00 V
Bin. Bits: 00000000
Count: 216
Hex Value: 0x0000
03201 - Adaptation Overboost
00810 - Sensor 1/2 for Brake Pressure
01542 - Yaw Rate Sensor (G202)
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 GJ HW: 5K0 907 044 GJ
Component: Climatronic H19 1313
Revision: 00001004
Coding: 0010002003
VCID: 79F9A52AF885ABF61A-802C
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
Component: BCM PQ35 M 021 0068
Revision: BC021001
Coding: 46180A3B802518C0408800C0340081644B51AA88436D81606480C7000041
VCID: 3E737636A92B4CCE6F-806A
Subsystem 1 - Part No SW: 5N2 955 119 HW: Labels: 1KX-955-119.CLB
Component: Wischer 14011 013 0204
Coding: 009795
Component: RLS 110113 05 54 0403
Coding: 02304D
Reset counter: 231
Mileage: 122155 km
Date: 2016.12.04
Time: 00:17:50
Voltage: 14.05 V
Address 10: Park/Steer Assist (J791) Labels: 3AA-919-475.clb
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56231301606916
Coding: 049303
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000_SE36.rod
VCID: 448704DECFC7261E39-8010
13637393 - Databus
Reset counter: 191
Mileage: 122155 km
Date: 2016.12.04
Time: 00:17:24
13637392 - Databus
Reset counter: 191
Mileage: 122155 km
Date: 2016.12.04
Time: 00:17:24
13637395 - Databus
Reset counter: 191
Mileage: 122155 km
Date: 2016.12.04
Time: 00:17:24
13637396 - Databus
Reset counter: 191
Mileage: 122155 km
Date: 2016.12.04
Time: 00:17:28
13637397 - Databus
Fault Frequency: 9
Reset counter: 191
Mileage: 122155 km
Date: 2016.12.04
Time: 00:17:28
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__20B VW10 HI 2118
Revision: 25018000 Serial number: 003L7P0M3ZZM
Coding: 0012354
VCID: 7CF7BC3E3FB79EDE01-8028
Subsystem 1 - Serial number: 6332MTS688510073
Subsystem 2 - Serial number: 6342MTS647090073
Subsystem 3 - Serial number: 6351HTS6TP48JBKJ
Subsystem 4 - Serial number: 6361HTS61CU7JBKR
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: 90422MA70002J
Coding: 1882140000
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 76E3AE16C99BC48E77-8022
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0033
Serial number: 0430508
Coding: 820000
Part No SW: 5N0 920 873 C HW: 5N0 920 873 C
Component: KOMBI H04 0811
Coding: 711F00
VCID: 336557029A6991A690-8066
8 Faults Found:
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 231
Mileage: 16328 km
Date: 2015.10.11
Time: 17:49:09
12669184 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 231
Mileage: 16328 km
Date: 2015.10.11
Time: 18:21:33
12718592 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 39
Reset counter: 63
Mileage: 16328 km
Date: 2015.10.11
Time: 18:23:19
12658688 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 231
Mileage: 16328 km
Date: 2015.10.11
Time: 18:21:33
12671232 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 63
Mileage: 16328 km
Date: 2015.10.11
Time: 18:42:15
13631488 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 231
Mileage: 16328 km
Date: 2015.10.11
Time: 18:21:37
13635840 - Supply voltage
Reset counter: 40
Mileage: 16328 km
Date: 2015.10.11
Time: 18:43:32
13654544 - Databus
Reset counter: 231
Mileage: 16328 km
Date: 2015.10.11
Time: 17:51:16
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AG HW: 7N0 907 530 AG
Component: J533 Gateway H53 1634
Revision: H53 Serial number: 130113F1000968
Coding: 356003
VCID: 75E1A91ADC9DCF967E-8020
Reset counter: 231
Mileage: 122155 km
Date: 2016.12.04
Time: 00:35:17
01304 - Radio
Reset counter: 231
Mileage: 122155 km
Date: 2016.12.04
Time: 00:30:20
Part No SW: 0AY 907 554 E HW: 0AY 907 554 E
Component: Haldex 4Motion 0043
Coding: 0000005
VCID: 4D9121FAD48DE756E6-8018
00625 - Vehicle Speed Signal
Reset counter: 138
Mileage: 122155 km
Date: 2016.12.04
Time: 00:17:23
Component: IMMO H04 0811
VCID: 6ADB8A668D23106EE3-803E
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [009] - -
9456681 - Key
B104C 29 [009] - Implausible Signal
Mileage: 16329 km
Date: 2015.10.11
Time: 00:03:43
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664008761
Coding: 010100
VCID: 2A5B4A6645A3D06E23-807E
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 5N0 959 701 F HW: 3C0 959 793 B
Component: TUER-SG FT 002 0504
Revision: 13110009 Serial number: 0006199512
Coding: 0202BC
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 387F602E830F72FEA5-806C
Slave Driver:
Subsystem 1 - Part No SW: 5N0 959 704 F HW: 3C0 959 795 C
Component: J389__TSG-HR 008 1504
Serial number: 00000007500871
Coding: 000090
Part No: 5N0 909 144 P
Component: EPS_ZFLS Kl. 202 3305
Revision: 00H22000
Shop #: WSC 01324 785 00200
VCID: 3E737636692B4CCE6F-806A
Fault Status: 11100101
Mileage: 122155 km
Date: 2016.12.04
Time: 00:17:23
Battery Volts: 11.7 V
DD
Temperature: 24.0°C
Count: 3
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Fault Status: 11101101
Reset counter: 191
Mileage: 16329 km
Date: 2015.10.11
Time: 00:00:38
Voltage: 11.63 V
DD
Temperature: 24.0°C
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 5N0 959 702 F HW: 3C0 959 792 B
Component: TUER-SG BT 002 0504
Revision: 15110009 Serial number: 0006195742
Coding: 0202BC
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 3979652AB8056BF65A-806C
Slave Passenger:
Subsystem 1 - Part No SW: 5N0 959 703 F HW: 3C0 959 794 C
Component: J388__TSG-HL 008 1504
Serial number: 00000007506671
Coding: 000090
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000697498
Coding: 0010000
VCID: 36636E16411B848EB7-8062
Fault Status: 01110000
Reset counter: 191
Mileage: 16329 km
Date: 2015.10.11
Time: 00:03:44
Voltage: 9.00 V
Count: 98
Hex Value: 0x12C3
Hex Value: 0x0001
Hex Value: 0x1010
Reset counter: 191
Mileage: 16329 km
Date: 2015.10.11
Time: 00:03:44
Voltage: 9.00 V
Count: 41
Hex Value: 0x12C3
Hex Value: 0x0001
Hex Value: 0x1010
Fault Status: 01110101
Reset counter: 191
Mileage: 16329 km
Date: 2015.10.11
Time: 00:03:44
Voltage: 9.00 V
Count: 99
Hex Value: 0x12C3
Hex Value: 0x0001
Hex Value: 0x1010
Fault Status: 01111101
Reset counter: 191
Mileage: 122155 km
Date: 2016.12.04
Time: 00:17:24
Voltage: 11.60 V
Count: 69
Speed: 8.0 km/h
Hex Value: 0x1253
Hex Value: 0x0004
Hex Value: 0x1010
02845 - Function Display in Instrument Cluster (!)
Fault Status: 00101010
Reset counter: 231
Mileage: 122155 km
Date: 2016.12.04
Time: 00:35:13
Voltage: 11.70 V
Count: 77
Hex Value: 0x0853
Hex Value: 0x0088
Hex Value: 0x1010
Address 56: Radio
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AG
Component: Batt.regelung H53 1634
Coding: 230F1859
VCID: 71E99D0AA8F5E3B6A2-8024
Component: J367-BDM H07 0180
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664100636
Coding: 0A01000000010101
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
9457427 - Left audio channel for speech/telephone
B104F 13 [009] - Short to GND
Reset counter: 191
Mileage: 122155 km
Date: 2016.12.04
Time: 00:17:23
9457171 - Right audio channel for speech/telephone
B104E 13 [009] - Short to GND
Reset counter: 191
Mileage: 122155 km
Date: 2016.12.04
Time: 00:17:23
End-------------------------(Elapsed Time: 03:11)--------------------------
