Results 1 to 10 of 12
Thread: MB different from BS
    Alexandria/fairfax county VA
    I read on the VCDS demo that the info displayed in the Basic settings screen matches data in measuring blocks.
    seems like this is not quite 100% accurate, (or I made an error someplace)
    units for the MB 78, 1-4: RPM, (no units), Pressure, Lambda
    units for the BS 78, 1-4: mbar, [blank], mbar, C
    here are a couple segments of my logs:
    first from measuring blocks:
    Wednesday 23 September 2015 13:27:06:51928-VCID:3FA390536EB764C664-806A VCDS Version: Release 15.7.1 (x64)
    03L 997 016 P R4 2.0L EDC G000AG 8681
    Group A: '078
    RPM (no units) Pressure Lambda
    TIME
    Marker STAMP /min mbar %
    0.17 828 20.4 0 99.4
    0.56 828 25.5 0 99.4
    0.95 828 25.5 0 99.4
    1.34 828 25.5 0 99.4
    1.71 828 25.5 0 99.4
    2.1 828 25.5 0 99.4
    2.49 828 25.5 0 99.4
    and from basic settings:
    Saturday 26 September 2015 10:59:51:51928-VCID:3FA390536EB764C664-806A VCDS Version: Release 15.7.1 (x64)
    at idle 820 rpm, basic settings 78 before pressing on/off/next (my added comment)
    Group A: '078
    TIME
    Marker STAMP mbar mbar C
    0.04 3 20.4 -3 282
    0.17 3 20.4 -3 282
    0.28 3 20.4 -3 282
    0.39 3 20.4 -3 282
    0.51 3 20.4 -3 282
    0.62 3 20.4 -3 282
    0.75 3 20.4 -3 282
    0.87 3 20.4 -3 282
    also from basic settings:
    Saturday 26 September 2015 11:00:13:51928-VCID:3FA390536EB764C664-806A VCDS Version: Release 15.7.1 (x64)
    1320 rpm or so basic settings 78 after pressing on/off/next (also my inserted comment)
    Group A: '078
    TIME
    0.04 85 45.9 -3 282
    0.16 85 51 -3 282
    0.28 85 45.9 -3 282
    0.39 85 45.9 -3 282
    0.51 85 45.9 -3 282
    0.62 85 45.9 -3 282
    0.73 85 45.9 -3 282
    0.84 87 45.9 -3 282
    Is there some place the various measuring blocks are spelled out, or is it all hidden on the VW corporate network someplace?
    a little birdie told me that the basic settings 78 reveal the LP EGR filter health, and that the difference between field 1 and 3 when basic settings on/off/next selected should be under 100
    I wanted to run a log of the egr filter pressure on a drive but now am confused. (there seems to be a lot of that going around)
    Sounds like the manual needs updating. It does indeed state that,
    Basic Settings Mode is very similar to Measuring Blocks, and the contents of each display group is the same.
    I think that was true when the manual was originally written way back when, but it isn't necessarily true today. The data shown in some groups of Basic Settings in some modules is indeed quite different than the data shown in the corresponding Measuring Block Group. Please understand, it's the module that's in control of the data (and units) that are displayed in each group, not VCDS.
    I feel your pain
    Magdeburg, Germany
    Scratching my head, what basic setting are you running in Block 078?
    // Update 1: Nevermind, missed your comment on that. I'll do some digging and see if I can find additional details on this.
    // Update 2: This is the layout for the regular meas. values...
    MVB 078/1 = Engine RPM
    MVB 078/2 = Mass Air Flow Sensor (actual)
    MVB 078/3 = Differential Pressure Sensor (G450)
    MVB 078/4 = Exhaust Flap (actual)
    Nichts erweitert das eigene Wissen mehr,
    als die Meinung eines Andersdenkenden.
  5. Likes Uwe, mikeme liked this post
    Do you maybe have the same measurement values from MWB 067 to 076 ?
    Please make 2 controller maps, 1 with Ignition ON and 1 in idle.
    Important Basic settings are in 067 068 and 078
    It is my understanding that you can only test the EGR filter pressure, by doing the Basic setting 078.
    Temperature reading below 200C !
    Quote Originally Posted by mikeme View Post
    Correct
  7. Likes Uwe, Sebastian, mikeme liked this post
    Thanks Sebastian!
    don't suppose you have a full list of the MVB nomenclature, do you?
    perhaps one that reports the Low Pressure Exhaust Gas Recirculation (EGR) Pressure
    Sensor
    I can get a log with MVB 67 and 76 later today.
    will post.
    thought the temp for the basic settings 78 difference was for temp above 200C. have to read it again.
  10. #8
    Correct
    I must not quite understand. how would I get the controller map?
    I logged some MVB for 67 and 76, and there is no values for my car for 76
    Wednesday,30,September,2015,15:06:45:51928-VCID:3FA390536EB764C664-806A,VCDS Version: Release 15.7.1 (x64),Data version: 20150904
    03L 997 016 P,,R4 2.0L EDC G000AG 8681,
    ,Group A:,'067,,,,Group B:,'076,,,,Group C:, Not Running
    ,,RPM,Load,Lambda,Lambda,, , , , ,,,,,
    ,TIME,,,,,TIME,,,,,TIME,,,,
    Marker,STAMP, /min, %, %, %,STAMP,,,,,STAMP,,,,
    ,0.11,0,100.0,100.2,0.0,0.24, , , , ,,,,,
    ,0.36,0,100.0,100.2,0.0,0.49, , , , ,,,,,
    ,0.63,0,100.0,100.2,0.0,0.75, , , , ,,,,,
    ,0.88,0,100.0,100.2,0.0,1.00, , , , ,,,,,
    ,1.14,0,100.0,100.2,0.0,1.27, , , , ,,,,,
    ,1.39,0,100.0,100.2,0.0,1.52, , , , ,,,,,
    ,1.66,0,100.0,100.2,0.0,1.78, , , , ,,,,,
    ,1.91,0,100.0,100.2,0.0,2.03, , , , ,,,,,
    ,2.17,0,100.0,100.2,0.0,2.30, , , , ,,,,,
    after starting:
    ,20.19,805,100.0,99.4,12.6,20.31, , , , ,,,,,
    ,20.44,828,100.0,99.4,12.6,20.56, , , , ,,,,,
    ,20.71,805,100.0,99.4,12.6,20.83, , , , ,,,,,
    ,20.95,828,100.0,99.4,12.6,21.08, , , , ,,,,,
    ,21.21,805,100.0,99.4,12.6,21.34, , , , ,,,,,
    ,21.47,828,100.0,99.4,12.6,21.59, , , , ,,,,,
    ,21.73,828,100.0,99.4,12.6,21.86, , , , ,,,,,
    ,21.98,828,100.0,99.4,12.6,22.11, , , , ,,,,,
  11. #9
    Wednesday,30,September,2015,15:08:32:51928-VCID:3FA390536EB764C664-806A,VCDS Version: Release 15.7.1 (x64),Data version: 20150904
    ,Group A:,'078,,,,Group B:,'104,,,,Group C:,'099
    ,,RPM,(no units),Pressure,Lambda,,0xFF02=Done,Hex Value,Bin. Bits,Bin. Bits,,Engine Speed,Temperature prior,Temperature prior,Temperature after
    ,TIME,,,,,TIME,,,,,TIME,(G28),Turbo Charger,Particle Filter,Particle Filter
    Marker,STAMP, /min,, mbar, %,STAMP,,,,,STAMP, /min,C,C,C
    ,0.32,828,25.5,0,99.4,0.06,0xFF01,0xFF21,00000000,00000000,0.19,828,186.0,108.0,72.0
    ,0.71,828,25.5,0,99.4,0.44,0xFF01,0xFF21,00000000,00000000,0.57,828,186.0,108.0,72.0
    ,1.08,828,25.5,0,99.4,0.83,0xFF01,0xFF21,00000000,00000000,0.95,828,186.0,108.0,72.0
    ,1.47,828,25.5,0,99.4,1.22,0xFF01,0xFF21,00000000,00000000,1.34,828,186.0,108.0,72.0
    ,1.86,828,25.5,0,99.4,1.60,0xFF01,0xFF21,00000000,00000000,1.74,828,186.0,108.0,72.0
    ,2.25,828,25.5,0,100.2,1.98,0xFF01,0xFF21,00000000,00000000,2.11,828,186.0,108.0,72.0
    ,2.63,828,25.5,0,99.4,2.37,0xFF01,0xFF21,00000000,00000000,2.50,805,186.0,108.0,72.0
    ,3.02,828,25.5,0,99.4,2.76,0xFF01,0xFF21,00000000,00000000,2.89,828,186.0,108.0,72.0
    ,3.41,828,25.5,0,99.4,3.14,0xFF01,0xFF21,00000000,00000000,3.28,828,186.0,108.0,72.0
    ,3.79,805,25.5,0,99.4,3.53,0xFF01,0xFF21,00000000,00000000,3.65,828,186.0,114.0,72.0
    ,4.17,805,25.5,0,99.4,3.92,0xFF01,0xFF21,00000000,00000000,4.05,805,186.0,114.0,72.0
    ,4.56,805,25.5,0,99.4,4.31,0xFF01,0xFF21,00000000,00000000,4.44,805,186.0,114.0,72.0
    ,4.95,805,25.5,0,99.4,4.68,0xFF01,0xFF21,00000000,00000000,4.82,805,186.0,114.0,72.0
    ,5.34,805,25.5,0,99.4,5.08,0xFF01,0xFF21,00000000,00000000,5.20,805,192.0,114.0,72.0
    ,5.71,805,25.5,0,99.4,5.46,0xFF01,0xFF21,00000000,00000000,5.59,805,192.0,114.0,72.0
    ,6.11,782,35.7,0,99.4,5.86,0xFF01,0xFF21,00000000,00000000,5.98,782,192.0,114.0,72.0
    ,6.49,828,30.6,3,99.4,6.23,0xFF01,0xFF21,00000000,00000000,6.37,805,192.0,114.0,72.0
    ,6.89,828,30.6,3,99.4,6.62,0xFF01,0xFF21,00000000,00000000,6.75,828,198.0,114.0,78.0
    ,7.26,828,30.6,0,99.4,7.01,0xFF01,0xFF21,00000000,00000000,7.13,828,204.0,114.0,78.0
    ,7.65,805,30.6,3,99.4,7.40,0xFF01,0xFF21,00000000,00000000,7.53,805,204.0,114.0,78.0
    ,8.04,851,30.6,3,99.4,7.77,0xFF01,0xFF21,00000000,00000000,7.91,828,210.0,114.0,78.0
    ,8.43,851,25.5,0,99.4,8.17,0xFF01,0xFF21,00000000,00000000,8.29,851,210.0,114.0,78.0
    ,8.80,828,25.5,0,99.4,8.55,0xFF01,0xFF21,00000000,00000000,8.68,828,210.0,114.0,78.0
    ,9.19,828,30.6,0,99.4,8.94,0xFF01,0xFF21,00000000,00000000,9.07,828,216.0,114.0,78.0
    ,9.58,828,25.5,0,99.4,9.32,0xFF01,0xFF21,00000000,00000000,9.46,828,216.0,114.0,78.0
    ,9.97,828,25.5,0,99.4,9.71,0xFF01,0xFF21,00000000,00000000,9.83,828,216.0,114.0,78.0
    and later
    ,284.46,1472,35.7,23,14.2,284.20,0xFF01,0xFF10,00000000,00000000,284.34,1495,294.0,306.0,270.0
    ,284.85,1495,40.8,23,25.3,284.59,0xFF01,0xFF10,00000000,00000000,284.72,1495,276.0,306.0,270.0
    ,285.23,1472,56.1,21,30.8,284.98,0xFF01,0xFF10,00000000,00000000,285.10,1495,270.0,300.0,270.0
    ,285.63,1495,71.4,23,37.1,285.37,0xFF01,0xFF10,00000000,00000000,285.50,1495,270.0,300.0,276.0
    ,286.01,1495,76.5,23,27.6,285.74,0xFF10,0xFF12,00000000,00000000,285.88,1495,270.0,300.0,276.0
    ,286.40,1495,71.4,33,26.0,286.13,0xFF10,0xFF12,00000000,00000000,286.25,1495,270.0,300.0,276.0
    ,286.77,1495,76.5,44,26.0,286.52,0xFF10,0xFF12,00000000,00000000,286.65,1495,282.0,294.0,276.0
    ,287.16,1495,81.6,51,25.3,286.91,0xFF10,0xFF12,00000000,00000000,287.04,1495,288.0,294.0,282.0
    ,287.55,1518,76.5,56,28.4,287.29,0xFF10,0xFF12,00000000,00000000,287.43,1495,300.0,294.0,282.0
    ,287.94,1495,81.6,51,31.6,287.68,0xFF10,0xFF12,00000000,00000000,287.80,1495,312.0,300.0,282.0
    ,288.32,1495,81.6,49,31.6,288.07,0xFF10,0xFF12,00000000,00000000,288.19,1495,342.0,300.0,282.0
    ,288.71,1518,86.7,46,33.1,288.46,0xFF10,0xFF12,00000000,00000000,288.58,1518,372.0,306.0,282.0
    ,289.10,1518,86.7,46,33.1,288.83,0xFF10,0xFF12,00000000,00000000,288.97,1518,390.0,306.0,282.0
    ,289.49,1541,102.0,49,37.1,289.22,0xFF10,0xFF12,00000000,00000000,289.35,1541,420.0,312.0,288.0
    ,289.86,1564,102.0,51,37.1,289.61,0xFF10,0xFF12,00000000,00000000,289.74,1541,450.0,312.0,288.0
    ,290.25,1564,102.0,56,33.9,290.00,0xFF10,0xFF12,00000000,00000000,290.13,1564,474.0,318.0,288.0
    ,290.64,1587,96.9,56,33.9,290.38,0xFF10,0xFF12,00000000,00000000,290.52,1587,504.0,324.0,288.0
    ,291.03,1587,96.9,56,33.1,290.77,0xFF10,0xFF12,00000000,00000000,290.89,1587,522.0,324.0,288.0
    ,291.41,1587,91.8,54,33.1,291.15,0xFF10,0xFF12,00000000,00000000,291.28,1587,546.0,330.0,294.0
    ,291.79,1633,102.0,54,37.9,291.55,0xFF10,0xFF12,00000000,00000000,291.67,1610,558.0,336.0,294.0
    ,292.19,1633,117.3,59,40.2,291.92,0xFF10,0xFF12,00000000,00000000,292.06,1633,576.0,336.0,294.0
    ,292.58,1656,122.4,64,41.0,292.31,0xFF10,0xFF12,00000000,00000000,292.44,1656,594.0,342.0,294.0
    ,292.95,1679,122.4,69,41.0,292.70,0xFF10,0xFF12,00000000,00000000,292.83,1679,606.0,342.0,294.0
    ,293.34,1702,132.6,74,47.3,293.09,0xFF10,0xFF12,00000000,00000000,293.22,1702,612.0,348.0,300.0
    ,293.73,1725,158.1,69,83.6,293.47,0xFF10,0xFF12,00000000,00000000,293.61,1725,618.0,348.0,300.0
    ,294.12,1794,153.0,64,92.3,293.85,0xFF10,0xFF12,00000000,00000000,293.98,1771,618.0,354.0,300.0
    ,294.50,1840,158.1,64,91.5,294.24,0xFF10,0xFF12,00000000,00000000,294.37,1817,618.0,354.0,300.0
    ,294.88,1863,163.2,64,91.5,294.63,0xFF01,0xFF10,00000000,00000000,294.76,1863,630.0,360.0,306.0
    ,295.28,1932,183.6,72,52.9,295.01,0xFF01,0xFF10,00000000,00000000,295.15,1909,642.0,366.0,306.0
    ,295.67,1955,198.9,79,89.2,295.40,0xFF01,0xFF10,00000000,00000000,295.53,1955,654.0,372.0,306.0
    ,296.04,2001,204.0,85,78.9,295.79,0xFF10,0xFF12,00000000,00000000,295.91,2001,648.0,372.0,312.0
    ,296.43,2070,219.3,90,92.3,296.18,0xFF10,0xFF12,00000000,00000000,296.31,2047,630.0,372.0,312.0
    ,296.82,2116,198.9,92,92.3,296.55,0xFF10,0xFF12,00000000,00000000,296.70,2093,624.0,372.0,318.0
    ,297.21,2162,198.9,95,92.3,296.94,0xFF10,0xFF12,00000000,00000000,297.07,2139,624.0,372.0,318.0
    ,297.59,2185,198.9,95,92.3,297.33,0xFF01,0xFF10,00000000,00000000,297.46,2185,624.0,378.0,318.0
    ,297.97,2047,198.9,108,52.1,297.73,0xFF01,0xFF10,00000000,00000000,297.85,2208,624.0,378.0,324.0
    ,298.37,1840,153.0,92,89.2,298.10,0xFF01,0xFF10,00000000,00000000,298.24,1840,624.0,384.0,324.0
    ,298.75,1794,142.8,77,90.0,298.49,0xFF01,0xFF10,00000000,00000000,298.61,1817,600.0,378.0,330.0
    ,299.13,1725,147.9,64,89.2,298.88,0xFF01,0xFF10,00000000,00000000,299.00,1725,576.0,378.0,330.0
    that MVB 78/4 is listed as lambda in %. and it seems to dance around more that I would think a motor driven flap would.
    I logged these looking for more validation of my guess that the MVB 104/1 value of 0xFF10 is associated with an NOX regen.
  12. #10
    Control Module Maps are explained here: http://wiki.ross-tech.com/wiki/index...ol_Module_Maps
    You can open them in Notepad and wrap them in [Code] like the text logs above. Jef's R32 post here may be helpful for example.
