Where can I log Boost (actual and specified) with VCDS 15.7 with Hex-Net
ReflexSilverMkVII
C?ID=256588
Hi everyone, I'm a new VCDS user and I'm having a hard time finding the ability to log "boost pressure - actual and specific) that I've been requested to log to possibly diagnose my car. I have a 2015 VW GTI 6MT (US), Hex-Net and VCDS 15.7 on a Windows PC. I can find "manifold charge pressure" but nothing labeled boost pressure. I want to see PSI or millibar output not BAR. Previous versions of VCDS have actual "boost pressure" log options. Can someone please help me?
Dana
Western PA, USA
This vehicle should use one of the latest UDS Protocol 01-Engine controllers so the good old days of Measuring Block group numbers are long gone and that isn't related to the version of VCDS you have installed. Please post the Auto-Scan so we can see which controller(s) are installed in this vehicle.
ReflexSilverMkVII
C?ID=256588
I'm not quite sure how to insert the file. The only options I see are URL links to websites.
Santos
no need to upload a file. Copy/paste the text into a post.
ReflexSilverMkVII
C?ID=256588
Self-Diagnosis Log
Monday,31,August,2015,19:55:14:42940
Page 2
VIN: License Plate: FLASH01
Address 01: Engine (J623-CXCA) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0004
Revision: --H13---
Coding: 091900322424002F1000
Shop #: WSC 00066 790 00218
ASAM Dataset: EV_ECM20TFS0205G0906259A 001006
ROD: EV_ECM20TFS0205G0906259A_VW37.rod
VCID: 2C44D22047AC8B5ED9-8078
23096 - Intake Air Temp. Sensor (G42)
P0113 00 [032] - Signal too High
15128 - Cylinder 2
P0302 00 [096] - Misfire Detected
Readiness: 0010 0001
Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
Component: ESC H31 0371
Revision: 00000000 Serial number: 51534000001317
Coding: 01FA6BA134210970007F020081C42980D62C9000408194B410430050C009
Shop #: WSC 01383 790 50316
ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
VCID: 44949A80CF3C631E31-8010
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 94
Mileage: 39475 km
Date: 2015.08.18
Time: 17:50:48
Self-Diagnosis Log
Page 3
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0335048292
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A68E478BDF825EE5B-806E
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5G0 907 426 R HW: 5G0 907 426 R
Component: AC Manuell H02 0907
Revision: 00001K06
Coding: 00020004200100000000000000000000
ROD: EV_ACManueBHBVW37X_SE37.rod
329220 - Motor for Air Distribution Flap
B109D 71 [008] - Actuator stuck
Reset counter: 97
Mileage: 38013 km
Date: 2015.08.05
Time: 16:34:06
Self-Diagnosis Log
Page 4
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 087 N HW: 5Q0 937 087 N
Component: BCM PQ37BOSCH 028 0106
Revision: -------- Serial number: 86581106140857
Coding: 00110A464041A26969E44000001407201800000000000000000000000000
Shop #: WSC 00066 790 07031
ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
ROD: EV_BCMBOSCH_AU37.rod
VCID: 46908088F900510E2F-8012
Slave 1:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 140628 043 0581
Serial number: 140711062715
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S3Y14M05D30H13M29S34
Coding: 00A8DD
Subsystem 3 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO2791279B
Coding: 181801
Fault Frequency: 44
Reset counter: 91
Mileage: 28141 km
Date: 2015.05.16
Time: 19:10:29
Self-Diagnosis Log
Page 5
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39331413602328
Coding: 0031151001
ROD: EV_EPHVA18AU3700000_SK48.rod
VCID: 3D62EF64ACD612D67E-8068
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H04 0303
Serial number: 09051476510265
Coding: 01000200280438
Shop #: WSC 00066 790 00194
ROD: EV_ACCMRRBoschVW372_AU37.rod
VCID: 386CFE7083F437FEAD-806C
Self-Diagnosis Log
Page 6
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM00ED9E
VCID: 51BAA3D4004E86B68A-8004
Seat occupant detection; front passenger side:
Subsystem 1 - Part No SW: 4M0 959 339 A HW: 4M0 959 339 A
Component: BF-Gewichtss. H05 0016
Serial number: IBH0000J140000X0ET0H
Coding: 303331
Subsystem 2 - Part No SW: ----------- HW: 480 000 705 14
Serial number: 3570000000099260CF0P
Subsystem 3 - Part No SW: ----------- HW: 480 002 304 14
Serial number: 3580000000061C356F0L
Subsystem 4 - Part No SW: ----------- HW: 480 402 205 14
Serial number: 3510002A915C4212902P
Subsystem 5 - Part No SW: ----------- HW: 480 402 205 14
Serial number: 3520002A315C4214524M
Subsystem 6 - Part No SW: ----------- HW: 480 401 905 14
Serial number: 3550002BF14D3E73534C
Subsystem 7 - Part No SW: ----------- HW: 480 401 905 14
Serial number: 3560002A314D3E708160
Self-Diagnosis Log
Page 7
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0155
Revision: FF028028 Serial number: 20140514500437
Coding: 0400
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB.rod
VCID: 04145A808FBCA31E71-8050
Part No SW: 5G1 920 856 HW: 5G1 920 856
Component: KOMBI 342 4270
Coding: 0BAD09122980CF0502886A011000000000000000
VCID: 6BC6113C82224C6690-803E
Self-Diagnosis Log
Page 8
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 10061410000131
Coding: 0101000820085900EF00002A080F00000001050000000000000000000000
Shop #: WSC 00066 790 00199
ROD: EV_GatewConti.rod
VCID: 42989C98D5286D2E03-8016
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q
Component: E221__MFL-DC1 H06 0101
Serial number: 29140000238540104095
Coding: 28FFFF
66052 - Infotainment CAN Bus (SAE Bus E)
U0065 00 [008] - Performance
Reset counter: 88
Mileage: 40268 km
Date: 2015.08.27
Time: 12:07:08
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000121814001
Coding: 5500000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 3474CA409F9CD39E81-8060
Self-Diagnosis Log
Page 9
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 2306140605026X
Coding: 003E13200000040000000000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 409C9690DB247F3E15-8014
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000002772313
Coding: 011000
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8102
ROD: EV_SteerAssisMQB.rod
VCID: 3572F74494E6CA96B6-8060
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 230614060500NY
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 3F9E956CA6DA00C66C-806A
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000002724240
Coding: 191000
Self-Diagnosis Log
Page 10
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 021A01010B000400
ROD: EV_HeadlRegulVWAFS_SE26.rod
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 014 0645
Serial number: V7B03005140674
Coding: 027300000000000021220002001800001F0203340100010002
ROD: EV_MUStd4CPASE_SK37.rod
VCID: 64D47A006FFC031ED1-8030
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H60 0030
Serial number: VWZ8Z9PS5008SD
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 HW: 5QE 035 285
Component: OCULowMQBUS 006 0528
Coding: 02730002C2823A017F1E06000000
ROD: EV_OCULowMQB.rod
VCID: 02185C9895A8AD2E43-8056
Self-Diagnosis Log
Page 11
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0013
Serial number: 140422201518
End-------------------------(Elapsed Time: 02:16)--------------------------
ReflexSilverMkVII
C?ID=256588
Does the scan I attach help pinpoint what I need to do to enable "boost pressure - specified and actual" or their equivalent?
VW ECUs have never shown "boost" (which is a pressure rise above ambient). They have always shown absolute pressures (where 0 is a hard vacuum). However, many people still incorrectly refer to this as "boost". Of course, you can calculate boost yourself by subtracting ambient air pressure from absolute manifold pressure, and ambient air pressure is also available.
These are German cars. They do not use arcane units like Pounds per Square Inch for pressure or furlongs per fortnight for speed. ;)
A BAR is just 1000 milibars. Figure 14.7 PSI / BAR.
Your ECU does show both:
Charge air pressure specified value
Charge air pressure actual value
These should be in positions 84 and 85 respectively in the current data set. And yes they are in BAR. Those are the units that the good Dr. Dipl. Ing.'s at Bosch/VW decided to show you and you VILL like it, Ja? :cool:
ReflexSilverMkVII
C?ID=256588
So can you explain what the difference between charge air pressure and manifold absolute pressure?
Not in detail, no. I believe the ECU provides manifold absolute pressure in generic OBD-II format (bear in mind that UDS is effectively a superset of the current generic OBD-II protocol) while charge air pressures (specified and actual) are provided in a proprietary format. If you wish to log and compare actual vs. specified, I would use the two proprietary ones in locations 84 and 85. However, it would be interesting (from an "academic" standpoint to compare the values shown in the proprietary actual charge air pressure with the generic OBD-II manifold absolute pressure.
Diagnosticated
C?ID=72030
Uwe...do the pressure value outputs not depend on the ecu file in use? Most edc ecu files have switches for absolute/relative pressure that can be changed in the file. Would this not change values read out by VCDS?
I have never seen a VAG ECU that reports "relative" pressure.
Zeilekd
C?ID=386344
Uwe,
I'm working on my 2015 Golf TDI and I can find "Charge Air Pressure: Specified Value" but there doesn't appear to be any value for "Charge Air Pressure: Actual Value" or even anything similar. Any suggestions? How does one go about diagnosing a boost issue without being able to see the Actual Value?
-Kurt
Please post an Auto-Scan so we can see exactly what ECU your car has and what ASAM data it's using.
khayward1973
C?ID=581
I would hazard a guess it's because the pressure measurements are not taken from the intake manifold. The MAP sensor is in the intercooler discharge pipe, which is your 'charge air'. There is no 'vacuum' reference in VAG GDI-T engines, not in MK5-MK7 at least. The minimum pressure you will see is 1000mb, or 1 bar. This causes a lot of confusion in some people. They see 2300mb or 2.3bar in their logs, and think that is the gauge pressure, when it's the absolute pressure, so 1000mb must be deducted to get your actual boost seen at the throttle plate.
