Got an 2016 Volkswagen Up! TSI and have two problems i'd like to solve.
Car has a lot of power so the traction control cuts all of the fun too soon. People here are unplugging the wheel ABS sensor to kill the ABS module so it wont interefere, but this also kills ABS and apart from being dangerous it's not a solution.
ABS module data:
SW:1S0-614-117-T
HW:1S0-614-117-T --- ABS Brakes
Component:EBC 460 MABS H26 0400
Coding:12DF24E32AF1105548A3240B54F90840580100
EV_Brake1ABSEBC460TRW 1003
EV_Brake1ABSEBC460TRW_SE12.rod
On the adaptation options for the module I got:
Engine drag torque control - activated
Roller test bench mode - activated
Starting vibration reduction - normal
Straight ahead brake stabilization - Front and rear axle activated
I suspect the Engine Drag Torque Control also plays a part on cutting the power. But when I try to disable it, the module asks me for a password wich I don't have. Tried every password I could find on google for VAG abs modules and none worked.
Also, I suspect the Traction control option is somewhere on long coding, but the helper has no data for this module. I suspect it would ask for a password too.
Any hints on what to do?
Thanks!
ABS module data:
SW:1S0-614-117-T
Thanks!
