I bought a lemony S6 C6 4F 2006 (see my newbie post). Current worst problem (there are more) is flashing ABS warning lights and "drive carefully to your nearest cash grabber". Any advice on how to fix them will be gratefully received.
I have replaced the EPB switch (cos Unit20 suggested it) with no effect. I did that while I was replacing the Airbag ECU as original one had "no communication" with VCDS. That was followed by a passenger side airbag igniter low resistance error, which was due to a tiny (1mm) broken off bit of yellow plastic in the floor connection preventing the plug going 100% home.
I have searched forums and re-coding the ABS module seems to be a common solution; which requires a specific code for the car. Even though I have not replaced the ABS module that doesn't mean previous owner didn't. So, here's the inevitable VCDS log:
Thank you in anticipation.
Wednesday,05,August,2015,12:44:03:27526
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
Dealer/Shop Name: RicDavies
VIN: WAUZZZ4F37N004960 License Plate: S6VGT
Mileage: 74281mi-Abagfixed+TestDrive Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 19 36 37 42
46 47 4F 52 53 55 56 57 61 62 6D 72 76 77
VIN: WAUZZZ4F37N004960 Mileage: 119510km-74260miles
06-Seat Mem. Pass -- Status: Cannot be reached 1100
Part No SW: 4F1 910 552 C HW: 4F1 907 552
Component: 5.2L V10/4V FSI ª0060
Revision: 59H09--- Serial number:
Coding: 010D0003190F0260
Shop #: WSC 00763 210 91830
VCID: 2447AADCE7B0791E12-8070
000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0030 - 004 - Malfunction / Open Circuit - MIL ON
Fault Status: 11100100
Mileage: 119504 km
Date: 2005.09.20
Time: 12:16:57
RPM: 648 /min
Load: 17.6 %
Temperature: 93.0°C
Temperature: 42.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.351 V
Readiness: 0010 1001
Part No SW: 4F2 910 156 M HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI RdW 0010
Revision: --H01--- Serial number: 0085607
Shop #: WSC 02325 785 00200
VCID: 2F6D55F0BE76CA46FF-807A
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 P HW: 4F0 614 517 P
Component: ESP 8.0 quattro H05 0070
Coding: 0020920
VCID: 31695388A842DCB6E9-8064
Fault Status: 11100000
Reset counter: 106
Mileage: 119504 km
Date: 2015.08.04
Time: 12:06:11
Hex Value: 0x0000
Hex Value: 0x47A2
Hex Value: 0x0014
Hex Value: 0x309B
Hex Value: 0x00FF
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 -
Reset counter: 106
Mileage: 119504 km
Date: 2015.08.04
Time: 12:06:11
Hex Value: 0x0000
Hex Value: 0x47A2
Hex Value: 0x0014
Hex Value: 0x239B
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601000434043
Coding: 0000147
Shop #: WSC 00976 210 82617
VCID: 63C5E9C0A23E3E262B-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Component: FBSAUDIC6 IDG H01 0040
Address 06: Seat Mem. Pass
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F1 910 732 E HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 351EN067518046
Coding: 0011002
Shop #: WSC 02335 785 00200
VCID: 2643B0D4918C8B0E0C-8072
Component: Bedienteil MMIC6H02 0060
Subsystem 2 - Serial number: 00000000424828
Subsystem 3 - Serial number: 0123.05.060000000100010533ÿ
Subsystem 4 - Serial number: 010533ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F2 820 043 N
Component: KLIMABETAETIGUNGH20 0170
Revision: 00000030 Serial number: 00000000266593
Coding: 0525578
VCID: 5BB5D1209A4E06E663-800E
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Coding: 0015121
Subsystem 1 - Part No: 4F2 910 113 A
Component: Wischer AudiC6 H04 0190
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH12 0090
Coding: 00146221
Shop #: WSC 02335
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8113747
VCID: 1C37923CDFC041DEAA-8048
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276U7301399
Shop #: WSC 02323 785 00200
Address 11: Engine II Labels: Redir Fail!
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4F0 910 561 B HW: 4F0 907 561 A
Component: ABSTANDSREGELUNGH05 0060
Revision: -------- Serial number: 00000000000000
Coding: 0041158
VCID: 224BACC4FDA4772E60-8076
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 106
Mileage: 119504 km
Date: 2005.09.20
Time: 12:24:04
Temperature: 39.0°C
Voltage: 14.21 V
Bin. Bits: 00000
Hex Value: 0x2513
Hex Value: 0x0002
Lateral Accel.: 0.00 m/s^2
02002 - Heater for Distance Regulation Sensor (Z47)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 106
Mileage: 119504 km
Date: 2015.08.04
Time: 12:06:42
Temperature: 39.0°C
Voltage: 13.70 V
Bin. Bits: 00000
Hex Value: 0x2A11
Hex Value: 0x0002
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4E AIRBAG AUDI8RH29 0260
Revision: 07H29000 Serial number: 0037LD0B36T7
Coding: 0013381
VCID: 2959BBE88092A47621-807C
Subsystem 1 - Serial number: 6332CSME0F2E147CG
Subsystem 2 - Serial number: 6342CSME11287E634
Subsystem 3 - Serial number: 6352QSME0E27352FP
Subsystem 4 - Serial number: 6362QSME10277665C
Subsystem 5 - Serial number: 63734SME0C6E467BI
Subsystem 6 - Serial number: 63834SME0E62532F6
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90054061240139
Coding: 0102152
VCID: 66C3F0D4510C4B0ECC-8032
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 980 R
Component: KOMBIINSTR. M73 H17 0070
Revision: 00500000 Serial number: 59L370956
Coding: 2177443
Shop #: WSC 00282 067 57207
VCID: 2345A9C0E2BE7E266B-8076
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 E
Component: Gateway H11 0070
Revision: 11 Serial number: 12009061288056
Coding: EEFEF3DC1B3D06
Shop #: WSC 00551 210 91539
VCID: 275DBDD09686920637-8072
00461 - Control Module for Seat Memory; Passenger (J521)
Reset counter: 106
Mileage: 119504 km
Date: 2005.09.20
Time: 12:18:56
VCID: 55A1C718BC6AD09655-FFFE
No Faults Found
Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
Component: MNS ECE H47 1060
Revision: 00000000 Serial number: 364EP067561262
VCID: 3B7571A07A0E26E643-806E
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: Uga
Coding: 0003834
Shop #: WSC 02327 785 00200
VCID: 2C5742FC8F60B15EDA-8078
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 B HW: 4F0 907 289 B
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01013198330000
Coding: 3285755
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H09 0240
Revision: PROD_01 Serial number: 00000000000587
Coding: 0000117
VCID: 2541B7D8EC8A801605-8070
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000237286
Coding: 0011104
VCID: 5EB3D834895C13CE04-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00000000 Serial number: &Eb
Coding: 0003834
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
Component: EPB CB4C0060 H04 0060
Revision: --H04---
Coding: 0008021
Shop #: WSC 02324 785 00200
VCID: 1F4DA530CED65AC64F-804A
Fault Status: 00101101
Fault Frequency: 22
Reset counter: 146
Mileage: 119504 km
Date: 2015.08.04
Time: 12:13:22
Voltage: 13.46 V
Count: 236
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Coding: 0000003
VCID: 3D717FB8641A28D67D-8068
Part No SW: 4E0 910 541 T HW: 4F0 035 541 H
Revision: 00000000 Serial number: 394EU067644253
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 E HW: 4E0 919 148
Component: R0078 TVhybridT 0470
Revision: R0H05000 Serial number: 76300700297602
Coding: 0000303
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000035546
Shop #: WSC 00976 210 67853
Component: von VA0 2605170495
Coding: 344630393135313035442056413032363035313730343935
Shop #: WSC 00000 384 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0003114
VCID: 2E5348F4B97CC34EF4-807A
Address 6D: Trunk Elect. Labels: Redir Fail!
Part No SW: 4F9 910 591 HW: 4F9 827 851 D
Component: ValeoHeckdeckel H20 0280
Revision: --H20001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD782FC4FE0715E9A-8038
Subsystem 1 - Part No: 4F9 910 592
Subsystem 3 - Serial number: RD12.05.06--H20001001B0193ÿ
Subsystem 4 - Serial number: 1B0193ÿ
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0003114
Part No SW: 4F0 910 283 D HW: 4F0 919 283 D
Component: Parkhilfe 4-Kan H09 0040
Revision: 00H09000 Serial number: 11720613103500
Coding: 0001116
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H10 1130
Revision: 00000000 Serial number: 00000007549036
Coding: 0010900
