Diagnosing fuel pressure problem in Audi Q7 - P2294 code
dsnads
C?ID=77857&TC=1
Hi, I am diagnose a fuel pressure problem in 2009 3.6L Gas Audi Q7.
The car starts and runs but has a lot less power than normal. and the P2294 code triggers the check engine light.
Occasionally I also get codes that show random misfires in the cylinders.
I have run the car with the VCDS connected and in the Engine section looked at Groups 103, 140 and 141.
Below is a link to a screenshot with the car running:
http://imgur.com/J62lg6o
My understanding is that the spec for the high pressure is between 25 bar and over 100 bar.
On my car it varies between 6.4 and 6.9 bar, but never goes higher than that. The first 2 fields in Group 141 are at a value of 0.
I have replaced both the fuel sensor on the fuel rail (high pressure) and also the fuel sensor near the firewall and above the HPFP (low pressure).
Is there a way to be absolutely sure what is causing this problem? I have read that sometimes the HPFP needs to be completely replaced as does the cam follower.
But I am reluctant to do that without a certain diagnosis, since it will be over $1000 to do.
Please post a complete auto-scan........
I would measure lift pump PSI and volume first seeing that it is properly regulated.
Visual inspection of HPP cam follower is always advised and costs time to inspect which is cheap.
dsnads
C?ID=77857&TC=1
Thank you Jack. Here is the complete Auto-Scan as you asked (hope ok to post right here) -
Thursday,30,July,2015,12:44:56:61551
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: WA1AY74L49D004238   License Plate: AUDI Q7
Mileage: 108540km-67443mi   Repair Order:
Chassis Type: 4L (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4F
          52 56 62 65 6C 6D 6F 72 76 77
VIN: WA1AY74L49D004238   Mileage: 108540km-67443miles
Address 01: Engine (BHK)       Labels: 03H-906-032-BLV.lbl
   Part No SW: 03H 906 032 DA    HW: 03H 906 032 G
   Component: Q7 3.6-FSI-LEV2 G   3234
   Revision: 5CH05---    Serial number:
   Coding: 0001175
   Shop #: WSC 31414 790 00001
   VCID: 64C76CF3A7ABD001EA7-8031
008852 - Fuel Pressure Regulator Valve (N276)
               P2294 - 004 - Open Circuit - Intermittent - MIL ON
                    Fault Status: 10100100
                    Mileage: 108540 km
                    Date: 2015.07.30
                    Time: 07:04:22
                    RPM: 690 /min
                    Load: 29.0 %
                    Temperature: 69.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.224 V
Readiness: 0010 0101
   Part No SW: 4L0 910 156 E    HW: 0AT 927 156
   Component: AG6 0AT 3,6 FSI USA 0020
   Revision: --H04---    Serial number:        4044598
   VCID: 2B55C7CF8AF55F79EBD-807E
Address 03: ABS Brakes        Labels: 4L0-910-517-V2.clb
   Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
   Component: ESP ALLRAD MK25E1   0010
   Revision: 00H30001
   Coding: 0099345
   VCID: 29593DC780094D69191-807C
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Component: FBSAUDIC6 ELV   H05 0090
   Revision: 00H05000    Serial number: 10602401090978
   Coding: 0000131
   Shop #: WSC 01126 444 100627
   VCID: 254131F7EC1169093D9-8070
   Subsystem 1 - Part No: 4F0 910 132 J
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H01 0040
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.lbl
   Part No SW: 4L0 910 732 R    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 354FN087540900
   Coding: 0002003
   VCID: 387FE8834BA3E4E196F-806D
   Component: E0380 BedienteilH01 0060
   Subsystem 2 - Serial number: 00000001082363
   Subsystem 3 - Serial number: 0127.05.080000000100010505ÿ
   Subsystem 4 - Serial number: 010505ÿ
   Part No SW: 4L0 910 043 B    HW: 4L0 820 043 L
   Component: KLIMABETAETIGUNGH07 0040
   Revision: 00---013    Serial number: 00000030096878
   Coding: 0524326
   VCID: 23452FEFE225973953D-8076
   Part No SW: 4F0 910 279 N    HW: 4F0 907 279
   Component: ILM Fahrer      H21 0310
   Coding: 0010123
   Shop #: WSC 08216 444 04789
   VCID: 3467DCB357CB0081BA7-8061
   Component: Wischer AU716   H15 0100
   Coding: 00064792
   Shop #: WSC 08216
   Coding: 00150059
   Shop #: WSC 08216
   Part No SW: 4L0 910 110 B    HW: 4L0 035 110
   Component: MP3-Changer     H45 0390
   Revision: 00045002    Serial number: AUZ5ZBH8447362
   VCID: 1E331E1BC947BAD17C3-804B
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 M    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7H0330933
   Coding: 0000100
   VCID: 3169D5A7A8D935A9D11-8064
   Component: 73 AIRBAG AUDI8RH43 0230
   Revision: 07H43000    Serial number: 0038QD090CTE
   Coding: 0014131
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME7116274DG
   Subsystem 3 - Serial number: 6342QSME71147A3FO
   Subsystem 4 - Serial number: 6352QSME6A720E05L
   Subsystem 5 - Serial number: 6362QSME71782747L
   Subsystem 6 - Serial number: 63734SME670D29331
   Subsystem 7 - Serial number: 63834SME66132251S
   Revision: 00H03000    Serial number: 90055081420197
   Coding: 0002042
   VCID: 275D3BFF961D7B190F5-8072
Address 17: Instruments (J285)       Labels: 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 981 S    HW: 4L0 920 981 S
   Component: KOMBIINSTR.   H06 0131
   Revision: 00000000    Serial number: 8NJ212468
   Coding: 8B9663040100D705020201
   VCID: 408F8063D373AC212EF-8015
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 84
                    Mileage: 57214 km
                    Date: 2012.10.29
                    Time: 13:43:30
00438 - Fuel Supply Sensor 2 (G169)
                    Fault Status: 00101010
                    Reset counter: 23
                    Mileage: 107677 km
                    Date: 2015.06.28
                    Time: 12:33:14
Address 19: CAN Gateway (J533)       Labels: 4F0-907-468.clb
   Part No SW: 4F0 907 468 F    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0022
   Revision: LA602018    Serial number: 1800L0852580BF
   Coding: 000003
   VCID: 326BDAAB6DDF0EB1A8B-8067
   Component: J367-BDM  H06 0080
Address 1E: Media Player 2 (R199)       Labels: 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H15 0850
   Revision: 00000000
   VCID: 2B55C7CF4AF55F79EBD-807E
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00001001094813
   Coding: 00581300000011110000
   VCID: 3169D5A768D935A9D11-8064
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
   Component: MNS US          H51 1100
   Revision: 00000000    Serial number: 313EL087539212
Address 42: Door Elect, Driver (J386)       Labels: 4F0-959-793.clb
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000100037039
   Coding: 010D07205E40440004
   VCID: 4683967BF1578211143-8013
Address 46: Central Conv.        Labels: 4L0-910-289.lbl
   Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
   Component: Komfortgeraet   H08 0060
   Revision: 0060 ---    Serial number: 01119150460000
   Coding: 7632925
   VCID: 3365DFAF52C507B9A3D-8066
Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
   Part No SW: 4L0 910 223 G    HW: 4L0 035 223 D
   Component: DSP-High AU716  H03 0150
   Revision: PROD_01     Serial number: 00000000066627
   Coding: 0000016
   VCID: 285F38C39B03746106F-807D
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000037107
   Coding: 0012001
   VCID: 5EB35E1B89C7FAD13C3-800B
Address 52: Door Elect, Pass. (J387)       Labels: 4F0-959-792.clb
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000100037236
   VCID: 45819177CC5189091D9-8010
   Part No SW: 4E0 910 541 T    HW: 4E0 035 542
   Revision: 00000000    Serial number: 304EL087622921
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
   Revision:             Serial number: 0000100035151
   Coding: 010C07204040230004
   VCID: 43858F6FC265B73933D-8016
   Revision: 00050100    Serial number: 00000900074914
   Coding: 0062424
   VCID: 224B2AEBFD3F9E3158B-8077
   Part No SW: 4L0 910 441 A    HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J844282
   Coding: 1020101
   VCID: 24472CF3E72B90012A7-8071
   Part No SW: 4L0 910 945     HW: 4L0 827 851 C
   Component: ValeoHeckdeckel H25 0290
   Revision: --H25001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CD704D34F7B9841A27-8039
   Subsystem 3 - Serial number: RD05.06.08--H25001001C0202ÿ
   Subsystem 4 - Serial number: 1C0202ÿ
Address 6F: Centr. Conv. II        Labels: 4L0-910-290.lbl
   Revision: AAH05061    Serial number: 003707177-----
   Coding: 0003595
   VCID: 264336FB91176211343-8073
   Component: J_245_EE16_SKB09H10 0200
   Component: J_394_EE16_SKB09H10 0200
   Component: J_392_EE16_SKB09H10 0200
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Revision:             Serial number: 0000100035134
   Part No SW: 4F0 910 283 K    HW: 4F0 919 283 K
   Component: Parkhilfe 8-Kan H12 0100
   Revision: 00H12000    Serial number: 69820815002347
   Coding: 0221246
   VCID: 2C57C4D38FFB5841E27-8079
   Part No SW: 4F0 910 336 G    HW: 4E0 862 335
   Component: Handyvorb2      H20 1120
   Revision: 00000000    Serial number: 00000005042136
   Coding: 0010900
End-------------------------(Elapsed Time: 03:44)--------------------------
(N276)
Now this is an open circuit and I would trace the tracks with WD back to controller......Inspect wiring and connector at N 276
FYI These regulator valves fail frequently.........
Dana
Western PA, USA
I agree with Jack here but do make sure that N276 (or N290 in a wiring diagram) isn't getting power from a relay that could be malfunctioning or a spliced connection in the harness. I'm not in a diagram for this vehicle at the moment but most HPFPs are powered by a J757 relay.
dsnads
C?ID=77857&TC=1
Thank you Jack and Dana for your posts! I am determined to figure this out (famous last words).
Jack,
The wiring is all new looking and wrapped, but I will re-inspect it.
When you say the regulator valves fail regularly do you mean the High Pressure Fuel Pump or a replaceable component of this?
Dana,
Where can I find the J757 relay though on the Q7, any way to help me with that on the WD for this 2009 Q7?
Also, I noticed these faults in the Auto-Scan, do they help us troubleshoot?
Reset counter: 84
Mileage: 57214 km
Date: 2012.10.29
Time: 13:43:30
Reset counter: 23
Mileage: 107677 km
Date: 2015.06.28
Time: 12:33:14
Most importantly see how the auto-scan displayed this information changing your diagnostic path to take now verse PSI bullshit?
Correct Dana N290 if looking at WD because no N276 exists I see in there.
Looks like maybe Typo maybe in VCDS for BHK or typo in WD.
Looks like D117 to D112 from stargate Track 131/194 splits to Fuse S13 15 amp which must be inspected!
Through aforementioned fuse to stargate 166/196 track to D108 via J757 ( 2/87 )
Now the split aforementioned should also be investigated for stargate 192/192 to V144 Fuel diagnostic pump.
Now for the CURVE ball!!!!!!!!!!
......at fuse S14 via D108 goes to stargate 168/168 and is connected to ( OXS ) Oxygen sensor heater circuits.
It is possible to get a flaky bad OXS heater .............that doesn't blow fuse but causes a disruption to power as brown out for N290 or N276.........
dsnads
C?ID=77857&TC=1
Hi Jack, thanks again!
Do I need access to the WD to follow your suggestions, if so is there a site online I can look?
I have just now inspected all 4 15A fuses under the plastic cover drivers side firewall area. All these are fine.
See picture what I am referring to:
http://imgur.com/gRjf1sm
Is one of these relays for the HPFP, or do I need to go into the area to the right and unscrew those torx bolts to find it?
Also is there a way to test the right relay?
How can I check or test the OXS heater (curve ball you mentioned)...
You can go to Erwin.
In USA : www.erwin.audiusa.com
World : www.erwin.audi.com
Dude you need to learn to test stuff not just swap parts and take a class.....You must RTFB.
You could, however, unplug the OXS sensors heaters by plug or extract the lead just for them, using WD to see if the N276 DTC goes bye bye.
dsnads
C?ID=77857&TC=1
Thanks but I don't have Erwin or the Fine Book or the Bentley. Guess I will see how much the subscriptions are.
Not sure I understand your suggestion on the OXS sensor heaters, can you help with a little more handholding...
I tried to remove the fuel pump relay labeled 614 but there must be a trick to that. Pushing the tab isn't working.
Striking out on most everything. Your help is much appreciated.
Okay ok.
No sticky hands though.......
Please unplug the Oxygen sensors and see if symptom for N276 goes away during road test.
dsnads
C?ID=77857&TC=1
Thanks Jack, I will try that and report back!
Don't forget to clear codes before road test and report back a full auto-scan after road test
dsnads
C?ID=77857&TC=1
Jack, I have run the car as you said without the oxygen sensors connected, and looks like no change.
Here are the pics of the disconnected sensors and the VCDS screen (2 images):
http://imgur.com/q6Mesti
Below is the new log file (I cleared codes before like you said), please let me know if you have other suggestions to try.
Is it possible I have a bad fuel pump relay, is that worth swapping out with a new one... any other ideas...
Friday,31,July,2015,11:53:56:61551
VIN:    License Plate: Q7 NO OXS
                Address 01: Engine       Labels: 03H-906-032-BLV.LBL
Control Module Part Number: 03H 906 032 DA    HW: 03H 906 032 G
  Component and/or Version: Q7 3.6-FSI-LEV2 G   3234
           Software Coding: 0001175
            Work Shop Code: WSC 31414 790 00001
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
               P0036 - 004 - Malfunction / Open Circuit
                    Mileage: 108566 km
                    Date: 2015.07.31
                    Time: 11:50:55
                    RPM: 1578 /min
                    Load: 18.4 %
                    Temperature: 69.0°C
                    Temperature: 45.0°C
                    Voltage: 11.938 V
000086 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
               P0056 - 004 - Malfunction / Open Circuit
                    Mileage: 108566 km
                    Date: 2015.07.31
                    Time: 11:50:55
                    RPM: 1578 /min
                    Load: 18.4 %
                    Temperature: 69.0°C
                    Temperature: 45.0°C
                    Voltage: 11.938 V
000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
               P0030 - 004 - Malfunction / Open Circuit
                    Mileage: 108566 km
                    Date: 2015.07.31
                    Time: 11:50:55
                    RPM: 1578 /min
                    Load: 18.4 %
                    Temperature: 69.0°C
                    Temperature: 45.0°C
                    Voltage: 11.938 V
000080 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
               P0050 - 004 - Malfunction / Open Circuit
                    Mileage: 108566 km
                    Date: 2015.07.31
                    Time: 11:50:55
                    RPM: 1578 /min
                    Load: 18.4 %
                    Temperature: 69.0°C
                    Temperature: 45.0°C
                    Voltage: 11.938 V
                    Mileage: 108566 km
                    Date: 2015.07.31
                    Time: 11:50:55
                    RPM: 1547 /min
                    Load: 14.5 %
                    Temperature: 69.0°C
                    Temperature: 45.0°C
                    Voltage: 11.811 V
Readiness: 0110 0101
Okay very good......so now why is voltage in the crapper?
Have you verified that the wiring from ECU/supply J757 to N290/N276 is okay with overlay?
Have you changed J757?
dsnads
C?ID=77857&TC=1
Jack, great catch I assume voltage should be around 13+ with the car running. I have removed and reseated the same fuel pump relay think that is J757. Should I replace that with a new one as a first step? Mine has a 614 on the top.
dsnads
C?ID=77857&TC=1
Ok thanks but I will need to find a library with these manuals...
dsnads
C?ID=77857&TC=1
Thanks! Thought I needed a subscription but will try this when I get home...
