Results 1 to 3 of 3
Thread: 2015 Caddy 4gen 2.0 Bluemotion
    Oct 2014
    Poland
    Wednesday,15,July,2015,09:45:12:53737
    VCDS Version: 14.10.1.1 (x64)
    Data version: 20150130
    Dealer/Shop Name: marcin
    Workshop Code: 555 11112 012345
    VIN: WV2ZZZ2KZGX006726   License Plate: GGGGGGGGGGGG
    Chassis Type: 2K (7N0)
    Scan: 01 03 08 09 10 13 15 16 17 19 25 42 44 46 4C 52 5F 61
    Address 01: Engine (J623-CUUD)       Labels: None
       Part No SW: 04L 906 016 CA    HW: 04L 907 309 K
       Component: R4 2,0L EDC   H20 1419
       Revision: 8AH20---
       Coding: 01110032042415090000
       Shop #: WSC 35110 790 50316
       ASAM Dataset: EV_ECM20TDI01104L906016CA 001004
       ROD: N/A
       VCID: 6ADBE4468DAE0071D04-803F
    No ASAM data for: "EV_ECM20TDI01104L906016CA" (VN35)
       Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
       Component: ESC           H05 0132
       Revision: 00000000    Serial number: 41505000000897
       Coding: 1079409B9362B484087C0278C9882DD378F1F0
       ROD: N/A
       VCID: 3F8D6512A6AC55D957A-806A
    No ASAM data for: "EV_Brake1ESCCONTIVN75XGP2" (VN35)
    Address 08: Auto HVAC (J301)       Labels: None
       Part No SW: 1K8 907 426 AB    HW: 1K8 907 426 AB
       Component: AC Manuell    H20 0808
       Revision: 00001002
       Coding: 0010004003
       ROD: EV_ACManueBHBVW36X_SE36.rod
       VCID: 73E5F922DA64C1B9632-8026
       Part No SW: 5K0 937 086 AA    HW: 5K0 937 086 AA
       Component: BCM PQ35 M+   122 0183
       Revision: BD122001
       Coding: 491A0A3E8025E16B088800809400016403D10008426F8120648087000041
       Shop #: WSC 35110 377 08192
       VCID: 73E5F922D264C1B9632-8026
       Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer 28051  27  0512
       Coding: 009795
       Subsystem 2 - Part No: 5K7 955 559 B
       Component: RLS 280515 03  37  0059
       Coding: 0228DD
       Subsystem 3 - Part No: 7N0 951 172
       Component: Sensor, DWA 0  005 0502
    Address 10: Park/Steer Assist (J791)       Labels: None
       Part No SW: 1K8 919 475 B    HW: 5Q0 919 298
       Component: PARKHILFE PLA H12 0479
       Revision: --------    Serial number: 39491515602734
       Coding: 0011061041
       ASAM Dataset: EV_EPHVA2CVW364GP00 001010
       ROD: N/A
       VCID: 39790B0AB8887BE969E-806C
    No ASAM data for: "EV_EPHVA2CVW364GP00" (VN35)
    Address 13: Auto Dist. Reg (J428)       Labels: None
       Part No SW: 7N0 907 572 A    HW: 7N0 907 572
       Component: ACC Bosch PQx H03 0110
       Serial number: 29051577120676
       Coding: 00000000FE0339
       ASAM Dataset: EV_ACCBEGVW361 001004
       ROD: EV_ACCBEGVW361.rod
       VCID: 34673A3E9FEA8681BA8-8061
    Address 15: Airbags (J234)       Labels: None
       Part No SW: 2K5 959 655 A    HW: 2K5 959 655 A
       Component: VW10Airbag00G 008 0016
       Revision: --------    Serial number: 003QX0002U2A
       Coding: 000000000000000000000000000000003047
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       ROD: EV_AirbaVW10BPAVN750_SK12.rod
       VCID: 3A7B1406BD8E70F1604-806F
       Serial number: 3497ARB406539P826GTC
       Serial number: 3507ARB405V39P822H1+
       Serial number: 3517ARB406539P82D12D
       Serial number: 3527ARB406539P825OB
       Part No SW: 5K0 953 521 GD    HW: 5K0 953 569 BE
       Component: LENKS.MODUL   018 0230
       Revision: FF010042    Serial number: 20150602300925
       Coding: 5080160010
       ROD: N/A
       VCID: 74E7FA3EDF6AC6817A8-8021
    No ASAM data for: "EV_SMLSNGVOLWSR8C" (VW36 *)
    Address 17: Instruments (J285)       Labels: None
       Part No SW: 2K5 920 876 A    HW: 2K5 920 876 A
       Component: KOMBI         H04 1009
       Coding: 180A01
       ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
       VCID: 336539229AE481B9A32-8066
       Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1663
       Revision:   H56       Serial number: 030615F1002745
       Coding: 357420
       VCID: 72EBFC26AD7EC8B1684-8027
       Component: IMMO          H04 1009
    Address 42: Door Elect, Driver        Labels: None
       Part No SW: 2K5 959 701 A    HW: 2K5 959 701 A
       Component: Tuer-SG         009 2143
       Coding: 0135218
       VCID: 326B3C26ADFE88B1A84-8067
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 140    3501
       Revision: 00H22000
       VCID: 39790B0A70887BE969E-806C
    Address 4C: Tire Pressure II
    Address 52: Door Elect, Pass.        Labels: None
       Part No SW: 2K5 959 702 A    HW: 2K5 959 702 A
       Coding: 0135218
       VCID: 3365392252E481B9A32-8066
       Part No SW: 1K8 035 150 D    HW: 1K8 035 150 D
       Component: MU-E--ER      857 6495
       Serial number: 20051500011266
       Coding: 06330700BE00000041110001000000001F0000840000010001
       ASAM Dataset: EV_MUEnt4CGen2LGE 001025
       ROD: N/A
       VCID: 2643D0765936E41134C-8073
    No ASAM data for: "EV_MUEnt4CGen2LGE" (VN35)
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Component: Batt.regelung H56 1663
       Coding: 030F1873
       VCID: 71E9F32AA878F3A991E-8024
       Component: J367-BDM  H07 0180
    End-------------------------(Elapsed Time: 02:50)--------------------------
  2. Likes Uwe liked this post
  3. #2
    Jan 2018
    Switzerland
    Hi
    Is your car with PLA system fitted?
    Thank you
    Aug 2016
    Switzerland
    I'd say yes
  5. Likes Uwe liked this post
