Hi All, - (Take two after sorting out the legalities)
Huston we have a problem!!!
I have a T5 7E (2011-2012 model).
It came stock with white DIS (including trip computer operated from the right stalk), RCD210 head unit and rubber steering wheel.
I have since retrofitted RCD 510 and 9w7 kit and coded successfully.
I have bought and installed;
3c8419091BF E74 MFSW (with DSG paddles)
3c8971584 A Airbag loom
6Q0953513BA Stalk switch (inc cruise) (I reused my ring 6Q0959654D)
I have also modified the clockspring connector by adding;
1. pin 9 which runs to light switch position 15 (ignition live)
2. pin 10 which splices into pin 17 of the 73 pin plug to the BCM
I have tried coding in the MFSW using VCDS and all the coding gets accepted, however nothing works.
Could you run some magic coding please to get full functionality, I would love to get;
The buttons and DSG paddels on the MFSW to work and to control the RCD510,Telephone,Voice recognition and Cruise control on the left and the current white DIS trip computer from the right switch.
I have read some threads and it seems you were able to do just this (without the right side buttons working) for SnowMotion in 2013 (http://www.vwwatercooled.com.au/foru...n-60513-4.html)
Your help is very appreciated, thank you.
I'm adding the scan of the car below. Please note the scan was clean until we attempted to fit a Polo R6 Stalk switch/clockspring setup, to see if that would work. Now its not letting us clear the Steering sensor fault code (since there is no 44 Steering Assist in this car).
Saturday,11,July,2015,22:47:01:38359
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
VCDS Version 15.6.1.0
Data version: 20150612
VIN: WV2ZZZ7HZCH049920 License Plate:
Mileage: 86450km-53717mi Repair Order:
Chassis Type: 7H (6N0)
Scan: 01 02 03 08 09 10 15 17 19 25 56 69 77 0B
VIN: WV2ZZZ7HZCH049920 Mileage: 86450km-53717miles
04-Steering Angle -- Status: Not registered 0001
Address 01: Engine (J623-CCHA) Labels: 03L-906-022-CAA.clb
Part No SW: 03L 906 019 DH HW: 03L 907 309 K
Component: R4 2,0L EDC H43 9133
Revision: 26H43--- Serial number: 00000000000000
Coding: 01254012231400080000
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_ECM20TDI01103L906019DH 002008
ROD: EV_ECM20TDI01103L906019DG.rod
VCID: 74E715C9DF2EF89FED-8021
Address 02: Auto Trans (J743) Labels: 0BH-927-711.clb
Part No SW: 0BT 300 045 M HW: 0BH 927 711 C
Component: DSG DQ500-7F H05 1712
Revision: 00H05V01
ROD: EV_TCMDQ500021_SE36.rod
VCID: 3F8D8AE5A6E86BC7C0-806B
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 H HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0107
Revision: 00H43001
Coding: 208724AD09A8049E24AB9073AA5E10
Shop #: WSC 02756 790 49152
VCID: 377DE2C586D8538708-8063
Fault Status: 01100101
Reset counter: 56
Mileage: 86450 km
Date: 2015.07.11
Time: 22:25:47
Count: 16512
Count: 4865
Count: 8215
Count: 762
003 - Mechanical Failure
Fault Status: 01100011
Reset counter: 56
Mileage: 86450 km
Date: 2015.07.11
Time: 22:42:03
Count: 16384
Count: 4353
Count: 300
Count: 764
Address 08: Auto HVAC (J301) Labels: 7E5-907-047.clb
Part No SW: 7E5 907 047 BA HW: 7E5 907 047 BA
Component: Climatic-T5 H19 0404
Revision: 00001009
Coding: 0000000402
ROD: EV_ClimaT5Basis_VN75.rod
VCID: 6FED1AA5B608DB4710-803B
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 H HW: 7H0 937 087
Component: BCM T5GP H+4 H47 0251
Revision: BO047001 Serial number: 0429 269110622
Coding: BAB879380E2120130028081022288CD50080410F60040040300000000000
Shop #: WSC 35683 123 104857
VCID: 3979E4FDB0CC45F7FE-806D
Subsystem 1 - Part No SW: 7E0 959 801 B HW: 7E0 959 801 B Labels: 7E0-959-801.CLB
Component: J386__TSG_FT 002 3311
Subsystem 2 - Part No SW: 7E0 959 802 B HW: 7E0 959 802 B Labels: 7E0-959-802.CLB
Component: J387__TSG_BT 002 3311
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 D HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47301120800438
Coding: 108101
ASAM Dataset: EV_VW75XParkAssis4K A01006
ROD: EV_VW75XParkAssis4K_VN75.rod
VCID: 3365D6D59AA0BFA734-8067
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag00B H06 0013
Revision: -------- Serial number: 003HL007WDMT
Coding: 000000000000000000000000000000003042
Shop #: WSC 02754 790 50316
ROD: EV_AirbaVW10BPAVN750_SE12.rod
VCID: 3561E8CD94D4A1971A-8061
Part No SW: 7E0 920 860 E HW: 7E0 920 860 E
Component: KOMBI H04 0305
Coding: 760200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
VCID: 2A5BCBB14D6AFE6F87-807F
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H47 0251
Revision: BO047001
Coding: 942300
VCID: 70EF19D9A336C4BF09-8025
Mileage: 86450 km
Date: 2015.07.11
Time: 22:25:10
Reset counter: 56
Mileage: 86450 km
Date: 2015.07.11
Time: 22:27:15
Component: IMMO H04 0305
VCID: 6ADB0BB18DEA3E6F47-803F
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 HW: 5K0 035 190
Component: Radio RCD510 040 0167
Revision: 00000001 Serial number: VWZ1Z3K3531926
Coding: 0800020101
Shop #: WSC 10580 123 65156
VCID: 62CB63917DDA662F8F-8037
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00000158754925
Coding: 410D000100000000
Shop #: WSC 02756 790 00000
VCID: 306FD9D963B684BF49-8065
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 D HW: 5K0 035 730 D
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007662471347
Coding: 0A00000000010110
Shop #: WSC 00015 115 12345
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA.rod
VCID: 26433F815972DA0FA3-8073
End-------------------------(Elapsed Time: 02:46)--------------------------
