7P T'Reg EPB
You'll probably wanna watch this on Youtube 'cause it's a bit small to make out all the details here:
vreihen
The Land of OCC, NY, USA
C?ID=31688
Now I've seen everything. My big 'ol piston-compressing C-clamp has been rendered obsolete by automation..... :(
What made us crazy is that on all the previous EPBs, all that was needed was some Basic Settings, one to open, one to close, one to do a function test, and that test was static, the module just opened and closed the brakes a few times to check itself. Yes, on the D3 A8, you also had to stuff the new pad thickness (in mm) into an adaptation channel.
But "Grinding In"? I'd really like to know why this is necessary.
Dana
Western PA, USA
I figured this was the best place for our (serious) Fall 2016 TSW Touareg EPB photos since we have it linked from the VW Touareg (7P) Parking Brake Wiki page. I saved them to my Google account for now, we can resize and watermark them for the Wiki at a later point in time.
vrh6RkSHjP9WhNWP9PQAnYO7TSwS8dV0qsWpUlkMLb1Zbym7KIFPzCBq5lIcDz1JZs3M5QxbuVNKTcQSRqkbWtl6lvUZmm7Q3DZlrgBRkrmcskCgDF1OtBvviePUd6nY3-EthA=w1176-h882-no
nfY0m_k8xMXZcdPMwWkDutcV3EnWChbq9BZpdhTNzLB5-Yi55DC_WRwegNPYAhl1K4FeISajMMtM4TMIr_jUGh2g8rYZ0PszX9D9UzYjlVhGl5o3FKpUIbWFNV8HikLeH8WRJw=w1176-h882-no
fSF002OmaWd9XIMcMpWIyVNiCEiLFQS-ovvJ1V-PVPFA_VGqS1yhkVEHdKA9UeJN1u670E9IAbVTmBNnqhgObcWhsBdquFtgvV4GIfoYxRmlQ7WPmS4P2cJt2jsqi5UX_cj7Sw=w1176-h882-no
2h86zsD2eMIwr2VRoNqk4gM3pPDjJNqbm6Db29cQyIxTsoA4o4cckrfDYIJ7Ter-W128B172lssGyJwGj9uZgtUJokaZNH7-Gk-YzzKlcuOycUsnGrw5hePCKhrn7hTYmpzqMw=w976-h1301-no
fK_mwb9G3JwspK55xfoYag4ynvEE8UX5lSYgKdpo28LhigENzD1n0-jA6VKqkwMMebC4EimZGWBNNB6D3nXnf84lQ4kL05arhB-m1ruasYhn1l7oNUFT-aj3hdWqQkijbbZLoA=w1176-h882-no
LZhvuRXY5iqsJgAj1VpAInvhxJlbMDdq37dQc46bP7cSXJr6Zo3xBvcRAuLLD9p-ZV6_7GQgZz7vivChaC56YR0WSQ6kYLV3IBY644UsVxV5Y4nhe9y29tf1t40Dg0LQ_A-SRg=w1176-h882-no
Boki Ar
Arandjelovac, Serbia
C?ID=57300
It works logically, IMO. The system does not allow "grinding in" for a period of 200 meters "at once". The brake shoes will be smoked more than Uwes electronic cigarette. :cool: ;)
Considering how many times we did "grinding in" of the shoes in that picture last year, the system seems to work OK. :)
(Repeated grinding in to figure out and document the process was done last year. Pictures of shoes are from this year).
alloyhead
Australia
C?ID=2976
How is the correct air gap set after repairs and before the grinding in procedure?
Jef
HQ
Touareg air gap specs are 1.9 to 2.4 mm. Left and right side must be within 0.2mm of each other.
The brake shoe adjuster wheel, each tooth is 0.15mm change.
Left side of vehicle:
Moving adjuster wheel towards front of vehicle, air gap gets SMALLER
Moving adjuster wheel towards rear of vehicle, air gap gets LARGER
Right side of vehicle:
Moving adjuster wheel towards front of vehicle, air gap gets LARGER
Moving adjuster wheel towards rear of vehicle, air gap gets SMALLER
I have just been suffering with this basic settings and gap adaopation on a 2012. I opened the calipers (!) shoes and we did new genuine Brembo discs and pads but the shoes were fine. I closed the calipers and checked the gaps which were wide so we reset then to almost dead on 2 with a 0.05mm difference between sides. I did the 21763 and went to air gap set but constantly got "aborted for safety reasons". I tried it EPB on then of, foot brake on and off, engine running, not running and all the possible combinations but it would not replace the values shown in the air gap when it came in. I noticed that the air gap that changed was the before calibration, the “air gap” never changed from what it had been to start with, I tried the grind in and it said running but did nothing and then said not running and then when I checked later, the air gap had gone out of spec at 2.3mm but the customer had to take the car. I am having it back on Friday when I get my new VAS6154 to use with ODIS which I s what I would have used if the new ODIS 4.3.3 had not taken a dislike to my 5054+ on Monday. Also, what really confused is the ECU lost its coding four times.
We solved this by using the Delphi diagnostic system of a friend, the gaps went straight in and it took us to a walk through of the grind in process and we were done in 30 minutes. Two days down the drain for the lack of ODIS which I should have up and running over the weekend.
2.8L
Canada
C?ID=324466
Worked out great for me
TimsterRS4
New Member
St Albans, UK
C?ID=99733 (NRRT)
Anyone know were the above brake brake grinding-in video has gone, or where else to see it? Thanks
Zenerdiode
Newcastle, England
C?ID=24330
It was pretty much @Uwe and @Eric playing about in a car park screeching brakes documenting the procedure that is now available in VCDS. :)
TimsterRS4
New Member
St Albans, UK
C?ID=99733 (NRRT)
Many thanks Zenerdiode. In the latest version of VCDS (which I installed today), it just links to this page / video. There also doesn't appear to be an option for the grind procedure in VCDS..... Last time I used a much older version, there was. Don't suppose you have any pointers, please?
Youtube seems to have made it private. The channel owner ( @Jef ) will have to fix that. It's not the only one we have that issue with at the moment.
