Electronic Parking Brake Malfunction
CoreyHeretick
New Member
C?ID=215131 (NRRT)
I have been having a lot of trouble getting my parking brake to work. Any help would be greatly appreciated!
Codes:
Reset counter: 104
Mileage: 168460 km
Date: 2013.08.30
Time: 17:17:51
Hex Value: 0x0240
Hex Value: 0x4026
Hex Value: 0x1217
Hex Value: 0x01AA
Hex Value: 0x00FF
02432 - Supply Voltage for Left Parking Brake Motor (V282)
011 - Open Circuit - MIL ON
Fault Status: 11111011
Fault Frequency: 92
Reset counter: 46
Mileage: 185992 km
Date: 2015.06.02
Time: 19:37:06
Voltage: 11.08 V
Count: 116
02433 - Supply Voltage for Right Parking Brake Motor (V283)
Fault Frequency: 131
Reset counter: 42
Mileage: 184616 km
Date: 2015.02.12
Time: 15:05:02
Voltage: 13.77 V
Count: 85
The car is a 2005 Audi A6. The parking brake will work while driving and I can hear the motors on both sides working when I turn the key from the off position to the accessory position and back, but the parking brake switch will not let me either engage or disengage the parking brake while I am parked. Also, when I first cleared the codes, everything worked perfectly how it should. Then after maybe an hour, I turned the car off and both of the EPB motors were going on and off for about 30 seconds, then back to the switch being unresponsive. Now the codes will clear, but instantly come back on.
CoreyHeretick
New Member
C?ID=215131 (NRRT)
VCDS Version: Release 14.10.2 (x64)
Data version: 20150311
Wednesday,10,June,2015,18:47:23:46512
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56
          61 62 72 77
VIN: WAUDG74F85N075329   Mileage: 186270km-115742miles
Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
   Part No SW: 4F2 910 559 B    HW: 4F1 907 559 A
   Component: 3.2l V6 FSI         0030
   Revision: --H15---    Serial number:
   Coding: 0000000000000000
   Shop #: WSC 22011 444 54304
   VCID: 2B5510688AB08079EBD-807E
005715 - Please check DTC Memory of ABS Controller
               P1653 - 008 -
                    Reset counter: 40
                    Mileage: 186270 km
                    Date: 2015.06.10
                    Time: 15:02:44
                    RPM: 896 /min
                    Mass Air / Rev.: 87.2 mg/str
                    Temperature: 88.5°C
                        Idle
                    Load: 13.3 %
008304 - Intake Manifold Tuning Valve (Bank 1)
               P2070 - 006 - Stuck Open
                    Fault Status: 01100001
                    Reset counter: 40
                    Mileage: 186270 km
                    Date: 2015.06.10
                    Time: 15:02:47
                    RPM: 736 /min
                    Mass Air / Rev.: 169.0 mg/str
                    Temperature: 87.0°C
                        Idle
                    Absolute Pres.: 473.5 mbar
               P0087 - 009 - Too Low - MIL ON
                    Fault Status: 11100100
                    Reset counter: 40
                    Mileage: 186270 km
                    Date: 2015.06.10
                    Time: 15:03:32
                    RPM: 704 /min
                    Mass Air / Rev.: 130.8 mg/str
                    Temperature: 87.0°C
                        Idle
                    Pressure: 36.4 bar
Readiness: 0110 0101
   Part No SW: 4F1 910 156 H    HW: 09L 927 156
   Component: AG6 09L 3.2 FSI USA 0020
   Revision: --H01---    Serial number:        0067808
   Coding: 0001002
   Shop #: WSC 02327 785 00200
   VCID: 2959EA60804C9269191-807C
   Part No SW: 4F0 910 517 E    HW: 4F0 614 517 A
   Component: ESP8 quattro    H03 0010
   Coding: 0020895
   VCID: 2643E15C9152BD11343-8073
                    Reset counter: 65
                    Mileage: 186270 km
                    Date: 2015.06.10
                    Time: 15:03:00
                    Hex Value: 0x0280
                    Hex Value: 0x4082
                    Hex Value: 0x0000
                    Hex Value: 0x00AA
                    Hex Value: 0x00FF
                    Reset counter: 65
                    Mileage: 186270 km
                    Date: 2015.06.10
                    Time: 15:03:23
                    Hex Value: 0x0280
                    Hex Value: 0x4082
                    Hex Value: 0x0000
                    Hex Value: 0x00A9
                    Hex Value: 0x00FF
                    Reset counter: 65
                    Mileage: 186270 km
                    Date: 2015.06.10
                    Time: 15:03:23
                    Hex Value: 0x0280
                    Hex Value: 0x4082
                    Hex Value: 0x0000
                    Hex Value: 0x00AA
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10602901714332
   Coding: 0000011
   Shop #: WSC 06128 444 84030
   VCID: 2541E650EC54B6093D9-8070
   Subsystem 1 - Part No: 4F0 910 131 J
   Component: FBSAUDIC6 EZS   H43 0070
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H35 0040
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
   Part No SW: 4F0 910 730 E    HW: 4E0 035 729
   Component: Interfacebox    H43 1070
   Revision: 00000000    Serial number: 360KR047510828
   Coding: 0000003
   VCID: 2345F848E260483953D-8076
   Subsystem 1 - Part No: 4F0 910 609
   Component: Bedienteil MMIC6H07 0870
   Subsystem 2 - Serial number: 00000000076070
   Subsystem 3 - Serial number: 0104.11.040000000100010593ÿ
   Subsystem 4 - Serial number: 010593ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
   Part No SW: 4F0 910 043     HW: 4F1 820 043 J
   Component: KLIMABETAETIGUNGH11 0110
   Revision: 00000024    Serial number: 00000000084875
   Coding: 0524326
   VCID: 5BB580A89A9030F95BD-800E
   Part No SW: 4F0 910 279     HW: 4F0 907 279
   Component: ILM Fahrer      H14 0080
   Coding: 0013123
   Shop #: WSC 02335 785 00200
   VCID: 66C3A15C51D27D11F43-8033
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Coding: 00141886
   Shop #: WSC 02335
                    Reset counter: 65
                    Mileage: 186268 km
                    Date: 2015.06.10
                    Time: 13:37:00
   Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0430
   Revision: 00000000    Serial number: AUZ5ZBD7100423
   VCID: 1B35C0A8DA1070F99BD-804E
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 B    HW: 4F0 959 655 A
   Component: 56 AIRBAG AUDI8RH29 0310
   Revision: 10H29000    Serial number: 00359D081DBK
   Coding: 0013622
   Shop #: WSC 08221 444 83902
   Subsystem 1 - Part No: 4F0 910 339
   Component: BF-Gewichtsens. 002 0040
   Subsystem 2 - Serial number: 6332CSME07161007Q
   Subsystem 3 - Serial number: 6342CSME07294631.
   Subsystem 4 - Serial number: 6351HSME05074C768
   Subsystem 5 - Serial number: 6361HSME0505436D4
   Subsystem 6 - Serial number: 6371VSME044108213
   Subsystem 7 - Serial number: 6381VSME044D0C0EV
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90025043070175
   Coding: 0002021
   Shop #: WSC 02323 785 00200
   Component: Lenkradmodul    H06 0080
   Part No SW: 4F0 910 900 A    HW: 4F0 920 950 M
   Component: KOMBIINSTR. M73 H09 0660
   Revision: 00400000    Serial number: 4I2520FC4
   Coding: 0067263
   Shop #: WSC 06128 067 57207
   VCID: 1E33C9BCC90265D17C3-804B
Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 B
   Component: Gateway         H09 0030
   Revision: 09          Serial number: 0800804B08004B
   Coding: 6CFE73C41B1104
   Shop #: WSC 02325 785 00200
   VCID: 275DEC589658A4190F5-8072
   Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
   Component: TSG FA          H10 0020
   Revision: 00000000    Serial number: Q22
   Coding: 0035435
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 E    HW: 4F0 907 289 E
   Component: Komfortgeraet   H14 0090
   Revision: 00900014    Serial number: 01001659900000
   Coding: 0423997
   VCID: 2C5713748FBE8741E27-8079
   Component: LIN BACKUP HORN H02 1301
7 Faults Found:
01696 - Footwell Lighting; Rear Left (W45)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 65
                    Mileage: 133102 km
                    Date: 2011.05.06
                    Time: 08:53:47
02199 - Bulb for Tail Light 2; Right (M50)
                    Fault Frequency: 7
                    Reset counter: 65
                    Mileage: 186271 km
                    Date: 2015.06.10
                    Time: 13:29:13
01506 - Bulb for Rear Fog; Right (L47)
                    Fault Frequency: 23
                    Reset counter: 65
                    Mileage: 185853 km
                    Date: 2015.05.30
                    Time: 21:08:15
                    Fault Frequency: 7
                    Reset counter: 65
                    Mileage: 186271 km
                    Date: 2015.06.10
                    Time: 13:29:13
02735 - Bulb for Tail Light 3; Right
                    Fault Frequency: 7
                    Reset counter: 65
                    Mileage: 186271 km
                    Date: 2015.06.10
                    Time: 13:29:14
02397 - Parking Light Rear Right (M2)
                    Fault Frequency: 7
                    Reset counter: 65
                    Mileage: 186271 km
                    Date: 2015.06.10
                    Time: 13:29:16
02743 - Bulb for Brake/Turn Signal Light; Right
                    Fault Frequency: 65
                    Reset counter: 65
                    Mileage: 186271 km
                    Date: 2015.06.08
                    Time: 18:43:11
   Part No SW: 4F5 910 223 C    HW: 4F5 035 223 D
   Component: DSP-High C6     H14 0240
   Revision: PROD_01     Serial number: 00000000014012
   Coding: 0000016
   Component: ILM Beifahrer   H09 0050
   Revision:             Serial number: 00000000047004
   Coding: 0001114
   VCID: 5EB389BC898225D13C3-800B
   Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
   Component: TSG BF          H10 0020
   Revision: 00000000    Serial number: d2
   Coding: 0035435
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0005022
   Shop #: WSC 02334 785 00200
   VCID: 5DB18EB084843EC9259-8008
                    Fault Status: 11101011
                    Fault Frequency: 58
                    Reset counter: 64
                    Mileage: 186264 km
                    Date: 2015.06.08
                    Time: 17:40:02
                    Voltage: 11.70 V
                    Count: 102
                    Fault Frequency: 83
                    Reset counter: 64
                    Mileage: 186264 km
                    Date: 2015.06.08
                    Time: 15:49:03
                    Voltage: 12.63 V
                    Count: 85
   Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
   Component: AFS 1           H01 0010
   Coding: 0000016
   Subsystem 1 - Part No: 4F0 941 329 A
   Component: AFS-Modul links H05 0010
   Subsystem 2 - Part No: 4F0 941 329 A
   Component: AFS-Modul rechtsH05 0010
   Part No SW: 4E0 910 541 F    HW: 4F0 035 541 B
   Component: TUNER EU/US/RDW H42 0480
   Revision: 00000000    Serial number: 394KY047500676
   Component: ENERGIEMANAGER  H11 0400
   Revision: 00000000    Serial number: 00000000080652
   Shop #: WSC 00000 384 00290
   Subsystem 1 - Part No: 4F0 915 105 C
   Component: von VA0  2411110004
   Coding: 344630393135313035432056413032343131313130303034
02274 - Quiescent Current Stage 3
            000 -  -  - Intermittent
                    Fault Frequency: 52
                    Mileage: 185230 km
                    Date: 2015.04.03
                    Time: 13:14:58
02255 - Voltage Measuring Lead from Vbat
                    Fault Frequency: 20
                    Reset counter: 65
                    Mileage: 185122 km
                    Date: 2015.03.28
                    Time: 07:53:53
00992 - Consumption Cut-Off Active
                    Fault Frequency: 47
                    Mileage: 185367 km
                    Date: 2015.04.06
                    Time: 20:21:42
                    Mileage: 185580 km
                    Date: 2015.04.23
                    Time: 13:12:18
   Part No SW: 4F0 910 795     HW: 4F0 959 795
   Component: TSG HL          H09 0010
   Coding: 0035370
   VCID: 69D9AA6040CC5269D91-803C
   Part No SW: 4F0 910 795     HW: 4F0 959 794
   Component: TSG HR          H09 0010
   Coding: 0035370
   Part No SW: 4F0 910 336 A    HW: 4E0 862 335
   Component: Handyvorb2      H10 0120
   Revision: 00000000    Serial number: 00000007507907
   Coding: 0010900
   VCID: 2149F240F87C5A29411-8074
End-------------------------(Elapsed Time: 02:17)--------------------------
Hmm.. Supply voltage codes for both EPB motors... Needs to be looked at with a DVOM and WD.
But.. You have low voltage codes in other modules as well. What kind of shape is the battery in? Is it the original, or has it been replaced? If replaced, was it coded properly?
CoreyHeretick
New Member
C?ID=215131 (NRRT)
I agree, using a meter would be a good way to check at the motors.
I just bought this car about a week ago, so I am not sure how old the battery is. The interface on the car has a battery level that has always sat at 10%, so either it doesn't read correctly or I do need a new battery. I haven't had any noticeable low battery conditions such as dim lights or anything like that, so I hadn't really suspected the battery at all.
Dana
Western PA, USA
I suspect a voltage drop as Uwe suggested but the Battery that you have coded is an old, if not original, part number:
If the battery is original that alone may be responsible for any number of issues but this fault isn't common and may be be indication that something else (corrosion?) is going on back there:
Jef just published this video about an hour ago:
http://forums.ross-tech.com/showthread.php?3240-Battery-Coding
markn1992
New Member
I have a 2005 Audi A6 2.0tdi with Electronic Handbrake Control Module problems.
The fault code that comes up is:
00473- control module for elect. Park/ hand brake (J540)
008- implausible signal
The handbrake operates correctly however there has been a few times where the handbrake would not release. As well as this, the parking light on the speedo does not come on at all apart from when I start the car and it runs it's pre-checks but then goes off and the light on the button only ever comes on when I push/pull the button but then goes off.
I am wanting to sell the car so would like to know possible solutions as well as whether it would pass an MOT in this state as like I said, the handbrake operates...
Thanks in advance.
