- Joined
- May 27, 2015
- Messages
- 283
- Reaction score
- 156
- Location
- Nipomo, CA, USA
- VCDS Serial number
- C?ID=149231
Hello. I have added the necessary components to a 2015 Q5 3.0 TDI to retrofit Active Lane Assist except the replacement windshield. This option is available ROW but not in NA. I am having trouble coding module 5C. I have installed the new Multifunction switch on the steering column with the Lane Assist activation button. I have also added the Lane Maintenance control module (Camera). I have coded the following modules to reflect the changes and they do not give any errors: 16, 17, 19, 44, 5F. When I get all of the control modules coded correctly I will be replacing the windscreen and performing the calibration. After that I will be doing a complete writeup including photos and procedures. I found some information online regarding Lane Assist on a B4 but using that coding model doesn't seem to be working. From MY09-12 the feature was just "Lane Assist" and used part number 8K0 907 217. FROM MY13-Current it became "Active Lane Assist" which provides steering corrections and uses part number 8T0 907 217 A am really hoping someone here might have an idea on where the coding fault in 5C is and can help me input the correct 7 digit value. I do have the necessary steering components already fitted to the car by the factory. Below I have attached a scan before I did any retrofitting or coding as well as a scan after all modules and components were fitted and coded. Thank you greatly for any information anyone might have.
Vehicle info.
1. Q5
2.USA
3.Adaptive Cruise Control (13)
4.No Adaptive Chassis Control
5.Trailer provisions
6.Lane Change Assist (3C)
7.Navigation High
8.CAN High
Before any modification or retrofit scan:
After Retrofit and coding 16, 17, 19, 44, 5F
Vehicle info.
1. Q5
2.USA
7.Navigation High
8.CAN High
Thursday,09,April,2015,11:04:40:00104
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: WA1WMBFP6FAxxxxxx License Plate:
Mileage: 16350km-10159mi Repair Order:
Chassis Type: FP (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 36 3C 42 44 46 47 52
53 56 5F 62 69 6C 6D 72 AC
VIN: WA1WMBFP6FA048050 Mileage: 16350km-10159miles
Address 01: Engine (J623-CPNB) Labels: 059-907-311-CLA.clb
Part No SW: 8K5 907 401 S HW: 4G0 907 401 E
Component: 3.0TDI EDC17 H14 0001
Revision: 58H14---
Coding: 2A2A4012057603050000
Shop #: WSC 55440 001 1048576
ASAM Dataset: EV_ECM30TDI0118K5907401S 001003
ROD: EV_ECM30TDI0118K5907401S.rod
VCID: 408F6B65DB83AB212EF-8015
8812 - Cylinder 2 Internal Pressure Sensor
P13D1 00 [047] - Short to Plus
Mileage: 12828 km
Date: 2015.03.14
Time: 10:40:38
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 8R0 927 158 Q HW: 0BK 927 156 AM
Component: 0BK 30 TDIUSA H19 1003
Revision: --H19---
Coding: 000001
ROD: EV_TCMAL551211_AU48.rod
VCID: 4B954C49E2C57879CBD-801E
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 8R0 907 379 AS HW: 8R0 907 379 AS
Component: ESP8 quattro H09 0020
Coding: 23AD1C03
VCID: 11299E21C86912A9F11-8044
Part No SW: 8K0 907 064 KP HW: 8K0 907 064 KP
Component: BCM2 2.0 H15 0711
Coding: 0DA54040000000000000
Shop #: WSC 06335 000 00000
VCID: 081FB345BB33536126F-805D
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Component: KLIMA 3 ZONEN H04 0122
Revision: C1000000 Serial number: 01190920141164
Coding: 3621228080
VCID: 77FDC0B9C6CD2C995F5-8022
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000893404802
Coding: 26000091867CAFF21100488300003D0D4F9CE708A6090221000008004000010200040034000000
VCID: 7AFBD98DF5DF31F120B-802F
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 140827 H12 0050
Coding: 01DD13
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Coding: 02005C
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Subsystem 5 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 6 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Address 13: Auto Dist. Reg (J428) Labels: Redir Fail!
Part No SW: 8R0 907 561 A HW: 8R0 907 561 A
Component: ACC3 H11 0100
Coding: 008157
VCID: 377D00B9864DEC999F5-8062
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 R HW: 8K0 959 655 R
Component: AirbagVW-AU10 H51 0812
Serial number: 003NED12HYXB
Coding: 303334313432383132304A55304C38523053
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 4C974F55E7CB7F41C27-8019
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R140000GX4R
Serial number: 6334MSME480E2C00D
Serial number: 6344MSME4879646DV
Serial number: 6352QSME5C460456J
Serial number: 6362QSME4747316EO
Serial number: 63732SME40443466U
Serial number: 63832SME64424D44+
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372NIG000A4
Coding: 00003F
VCID: 44876775C79BB7010A7-8011
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
Part No SW: 8R0 920 982 B HW: 8R0 920 982 B
Component: KOMBIINSTR. H35 0564
Revision: 00400000 Serial number: ZDC27399F
Coding: 8BBF22002F01D705020000
VCID: 3A7B198DB55FF1F160B-806F
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z149050B6E
Coding: 80CF07FF00
VCID: 4C974F55EFCB7F41C27-8019
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 M HW: 8K0 907 144 M
Component: DYNAMIKLENK. H06 0730
Revision: 52001005 Serial number: --------------
Coding: 020100
VCID: 39790681B059FAE9691-806C
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02019164747464545425363E00
Shop #: WSC 06325 000 00000
VCID: 7CF7DF95FFEB0FC1327-8029
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000114744385
Coding: 01581B00000000000000
VCID: 428B616DDD8FB93138B-8017
Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0346139735
Coding: 010221
ROD: EV_LaneChangAssis.rod
VCID: 3F8D6899A67DD4D9575-806A
Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000116313843
Coding: 011D13215E00440004
VCID: 4FAD58591EDD4459A75-801A
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 8R0 909 144 J HW: 8R0 909 144 B
Component: RCEPS H41 0509
Revision: 00001000 Serial number: 0030925634
Coding: 010000010001
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_RCEPSAU48X 008016
ROD: EV_RCEPSAU48X.rod
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0347056755
Coding: 0126063A20FA709584A0053600040047
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813034061406
VCID: 2D5122D174115649F59-8078
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000117929946
VCID: 4E93455D19D74D51AC3-801B
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 30000000264223
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A7B198DBD5FF1F160B-806F
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156I20E8065591
Coding: 020007010000000001
VCID: 2447C7F527DB97012A7-8071
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R1 035 746 F HW: 8R1 035 746 D
Component: H-BNT-NA H41 0812
Revision: -------- Serial number: 204I10E7679622
Coding: 160200060005E9EF7502AF5E00000403140000000000000000
Subsystem 1 - Part No: 8R0 060 884 CA
Component: NAR 2014 1002
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Component: CD-Database 5950
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000117821679
Coding: 010C13204000240004
VCID: 46837D7DF1A78511143-8013
Address 69: Trailer (J345) Labels: 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: Anhaenger H09 0100
Revision: 1A001001 Serial number: 00008200724693
Coding: 0200000000000000
VCID: 36630DBD81471591843-8063
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H09--- Serial number: 525PA8-J47A2YG
Coding: 1031010
VCID: 346737B5573B0781BA7-8061
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D711291A471C6C9459-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000116472682
Address AC: Reductant Control (J880) Labels: None
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 142460205
ROD: EV_RDCMA00100.rod
VCID: 2D5122D17C115649F59-8078
End-------------------------(Elapsed Time: 04:43)--------------------------
Wednesday,27,May,2015,09:53:42:00104
Mileage: 17380km-10799mi Repair Order:
53 56 5C 5F 62 69 6C 6D 72 AC
VIN: WA1WMBFP6FA048050 Mileage: 17380km-10799miles
5C-Lane Maintain. -- Status: Malfunction 0010
Revision: 58H14---
P13D1 00 [109] - Short to Plus
Mileage: 17382 km
Date: 2015.05.26
Time: 01:38:04
Readiness: 0 0 0 1 1
Revision: --H19---
Coding: 000001
Coding: 23AD1C03
Coding: 3621228080
Coding: 01DD13
Coding: 02005C
H05 0012
H05 0012
Coding: 008157
Coding: 0000FF
Coding: 8BBF22006F01D705020000
Coding: 80CF07FF00
Coding: 020100
Revision: AA001002
Coding: 010221
Coding: 010001010001
Address 5C: Lane Maintain. Labels: None
Part No SW: 8T0 907 217 A HW: 4E0 907 217 C
Component: J759 HC 0040
Revision: 00H08006 Serial number: 600213910000FA
Coding: 0102104
VCID: 377D00B9464DEC999F5-8062
02797 - Control Module for Directional Stabilization Assistance (J759)
Fault Status: 01100101
Reset counter: 237
Mileage: 17382 km
Date: 2015.05.26
Time: 21:01:37
Reset counter: 237
Mileage: 17382 km
Date: 2015.05.26
Time: 21:01:37
02858 - Windshield Heater for Directional Stabilization Assistance (Z67)
Reset counter: 237
Mileage: 17382 km
Date: 2015.05.26
Time: 21:01:38
Coding: 160200060005E9EF7D02AF5E00000403140000000000000000
Coding: 1031010
End-------------------------(Elapsed Time: 05:11)--------------------------
