A6 2001 4.2 Electric Steering Wheel Memory Problem
Artmarks
C?ID=245401
Hello all,
What module controls and saves the electric steering wheel position? Can this module be reset?
Background: Car was not driven for 6 months while waiting for a transmission fix. Battery died completely.
Problem: After battery died, automatic electric Steering Wheel does not return to the correct location when the ignition is turned on. More accurately, steering wheel returns to the last set memory position 50% of the time, the other 50%, it returns to the proper extension, but then dips down. The seat memory positions for the seat work perfectly 100%, but 50% of the time, the steering wheel does not return to the last set position. This is the same for all 3 memory buttons.
Question 1: Is the Steering Wheel memory controlled by the Address 36: Seat Mem. Drvr or is it stored in some other module? This car is a 2001 and has a limited number of modules. If so, can this module be reset? It displays no fault codes.
Question 2: Is it possible that because we had to jump start the car several times, and the steering wheel button was set to on, is it possible some motor or memory in the steering column was damaged? I doubt the motor is an issue, because when manually used, the electric steering wheel works very well in all directions. Does Address 16: Steering wheel control steering wheel memory?
Question 3: Aside from the Address 36: Seat Mem. Drvr module, which is not displaying fault codes,...even if the seat memory works, is it possible the memory switch in the door has failed?
Fault Codes: Except for an engine mount code, no fault codes
FOB Keys: I have 2 sets of keys and one is set to memory position 1 and the other is set to memory position 2. When using each key, upon opening the doors, the seat returns to the proper position for that key. This has even been reset based on the manual, and both keys work.
Appreciate any insight you may have.
John
Even though you say there are no fault codes relevant to this problem, an Auto-Scan would be appreciated so we can see exactly what modules are installed in this car.
Artmarks
C?ID=245401
Thank you this is what just came up.
Chassis Type: 4B (4B - Audi A6 C5 (1998 > 2006))
          75 76 77
VIN: WAUZL64B51N146666
Address 01: Engine        Labels: None
   Part No: 4D0 907 560 AE
   Component: 4.2l V8/5V      G01 0001
   Coding: 07752
   Shop #: WSC 26097
   VCID: E99AF43791B7C469591-5184
   WAUZL64B51N146666     AUZ7Z0A1816377
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 01L-927-156.lbl
   Part No: 4B0 927 156 CT
   Component: AG5 01L 4.2l5V  USA 0708
   Coding: 00002
   VCID: FBB6BE7FEB2B46F9BBD-5184
   Part No: 4B0 959 760 C
   Component: Sitzmemory R1 BF    0102
   Coding: 00003
   VCID: AD12402765DF1849759-4B3C
Address 08: Auto HVAC        Labels: 4B0-820-043-MY1.lbl
   Part No: 4B0 820 043 AH
   Component: A6-Klimavollautomat D65
   Coding: 00180
   Shop #: WSC 02325
   VCID: E08CE913628D85218EF-259E
Address 15: Airbags        Labels: 4B0-959-655-AI8.lbl
   Part No: 4B0 959 655 F
   Component: Airbag Front+Kopf  2002
   Coding: 00305
   Shop #: WSC 02325
   VCID: B326565F83FB4EB923D-5184
Address 16: Steering wheel        Labels: 4B0-907-487.lbl
   Part No: 4B0 907 487 D
   Component: Lenkradelektronik    D03
   Coding: 00102
   Shop #: WSC 65535
   VCID: AD12402765DF1849759-5066
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 981 GX
   Component: C5-KOMBIINSTR. VDO D17
   Coding: 03283
   Shop #: WSC 54321
   VCID: 8248C39B8CC13731F8B-5184
Address 35: Centr. Locks        Labels: 4B0-962-258.lbl
   Part No: 4B0 962 258 J
   Component: Central Lock/Alarm  D34
   Coding: 15945
   Shop #: WSC 26097
   VCID: B02C595372ED75A15EF-4F0C
01559 - Drivers Door
            59-00 - Can't Unlock
01560 - Passenger Door
01561 - Rear left door
01562 - Rear right door
   Part No: 4B0 959 760 B
   Component: Sitzmemory R1 F     0101
   Coding: 00001
   VCID: AC144D235EC51141627-4B3C
Address 45: Inter. Monitor        Labels: 4B0-951-178.lbl
   Part No: 4B0 951 178 A
   Component: Innenraumueberw.    D04
   Coding: 00101
   Shop #: WSC 02325
   VCID: A600BF0B40292B11B43-5160
Address 55: Headlight Range        Labels: 4B0-907-357-DYN.lbl
   Part No: 4B0 907 357 C
   Component: dynamische LWR       D06
   Coding: 00020
   Shop #: WSC 02325
   VCID: A81CB1334A3D3D6186F-4B7A
I suspect it is in the Driver's Seat Memory for that car, but it looks like those were rare enough that nobody ever documented them.
Can we get you to make Measuring Block maps for both 06 and 36 please?
Is the controller in the drivers door panel or on the seat itself?
With Recaros and does it also control mirror base settings too?
The faults in the Central locking, are most likely screwing with the ability of the seat memory to initiate.
It is not seeing the positions of the door properly before going night nights ( Sleep mode MA draw reduction )
Check wiring in door jams for damage.
Get the factory repair manual to test, and trace the current tracks with WD.
www.erwin.audi.com
Coding: 15945
Shop #: WSC 26097
Has car taken on water?
Artmarks
C?ID=245401
Thank you kindly for the reply. Please send instructions to make those Measuring Blocks maps...happy to do so. Can this module be reset in any way?
Artmarks
C?ID=245401
Thank you Jack.
I know the Seat Drivers Module is under the seat. I do not know where the Central Lock Module is located.
Never had a problem with the central locking system....so these codes are a surprise. I recently changed the central lock software code to unlock all doors at the same time as well as have the FOB key lower and raise the windows....and that worked well. Car has never taken on water....in preparation for the transmission rebulid, I opened up passengers side floor to make sure TCM was not wet. No water that I could see or feel. But I never opened up drivers side.
How involved would testing, and tracing the current tracks with WD be?
Ohhhhh FOD
Can you reverse what you did to see if it changes anything in 0x35?
Artmarks
C?ID=245401
Jack.....I am very new to VCDS. Do you mean return the Central Lock Software to the default code?
Artmarks
C?ID=245401
Measuring Blocks for 06 and 36 sent to Support
Uwe.....I made the maps you requested and sent them in to support.
Andy
Sector 7G
HC424490
We got the maps, thanks! :thumbs:
Artmarks
C?ID=245401
Uwe.....based on the Measuring Block maps I sent, cannot you confirm if the steering wheel memory is controlled by the Driver's Seat Module 06?
John
Artmarks
C?ID=245401
Uwe. I am still trying to solve the steering wheel adjustment memory issue with my 2001 A6 4.2L. I sent you maps for the 06 Driver's Seat Module. In summary, two FOBs are keyed to memory settings 1 and 2 and perform perfectly, applying settings to seats and mirrors.....but steering wheel memory works perfectly 50% of the time, the other 50% steering wheel coming out properly but dips down. Also, when starting the car, the steering wheel returns to proper position 50% of the time.
1. Can you confirm or deny if the Driver's Seat Module controls Steering Wheel memory? I am starting to think not.
2. I have learned about a Steering Control Module 4DO 909 611 that does not come up on any scan....does this module control steering wheel memory?
3. Any thoughts on whether the faults in the Central locking, are most likely screwing with the ability of the seat memory to initiate for the steering wheel as another reader posted? Again, seat and mirror memory works fine.
John
