Friday,12,June,2015,20:22:50:14758
VCDS Version: 15.6.0.0 (x64)
Data version: 20150604
VIN: WAUML44E74N017518 License Plate:
Mileage: 80250km-49865mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 25 28 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 72 76
VIN: WAUML44E74N017518 Mileage: 80250km-49865miles
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 S HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 346IP047514325
Coding: 0000103
Shop #: WSC 00000 000 08192
VCID: 326B24F1AD16C7AF35-8067
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000097794
Subsystem 3 - Serial number: 0113.11.130000000100010015ÿ
Subsystem 4 - Serial number: 010015ÿ
Reset counter: 196
Mileage: 80252 km
Date: 2015.06.12
Time: 20:18:09
For this: take the car to a dealership, they can corroborate whether the component belong or not to the car. they are able to clear the DTC. make sure the component really belong to the car, else I guess it will find the rightfully car..... I Don't know what is going to happen
Part No SW: 4E0 910 043 HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0240
Revision: 00000022 Serial number: 00000000033347
Coding: 1151313
Shop #: WSC 02311 785 00200
VCID: 5ABBAC519526DFEFDD-800F
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO15122003065A000000000168ÿ†89
Subsystem 5 - Serial number: 000168ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO18122003065A00000000
Subsystem 7 - Serial number: 65A000000000072ÿ
00066 - Rear Right Footwell Heater (Z43)
Check the pic for location. this get disconnected very often in this models
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
Shop #: WSC 22145 444 54027
VCID: 2541CFADECD8A017A0-8070
...Most of the time this is cause by Human error: if you were there chances are you busted it. it is located near the Motor Mounts.
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM005 0110
Coding: 0000541
VCID: 5EB3A041890E33CFA1-800B
02110 - Window Regulator Switch
All this DTC could cause the battery to go drained (depleted)
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040312110112
Coding: 0065086
Shop #: WSC 02313 785 00200
VCID: 275DC5A596D4B20792-8072
Subsystem 1 - Component: HDSG keine Antwort
Component: Neigungssensor H02 0020
02107 - Trunk or Luggage Compartment Opening Motor (V254)
01699 - Motor for Central Locking; Hatch/Trunk (V53)
014 - Defective
009 - Open or Short to Ground
Address 47: Sound System Labels: None
Part No SW: 4E0 910 224 C HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0470
Revision: Dev_D01 Serial number: 00000000655399
Coding: 0000018
VCID: 1E33E041C98E73CFE1-804B
02084 - Component Protection
Fault Status: 01100101
Reset counter: 196
Mileage: 80251 km
Date: 2003.10.08
Time: 03:26:43
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
Shop #: WSC 23435 444 58960
VCID: 1D31E74DC48868D7F8-8048
02596 - Rear Brake Pads Worn
Fault Status: 01111000
Reset counter: 46
Voltage: 6.21 V
Count: 61
Time for a brake Job check Brake pad thickness and sensor
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
VCID: 62CB94B1BD76172F85-8037
For this First Fix your level sensor issue then perform 1 - Air Suspension System Basic Settings
or Repaired Air Suspension Air Line
End-------------------------(Elapsed Time: 03:27)--------------------------
