RNS315 was retrofitted to Skoda Rapid. 37-Navigation was enabled on CAN Gateway and almost all works ok.
- navigation data is shown on MFD; also navigation instructions
- Phone menu in MFD is activated and everything works great (though, still waiting for microfon to test also this function, sound from phone call is heard; address book is on MFD, etc. etc.)
The only problem is, that when you start the car on the MFD shows searching for the phone and then connects to the phone. But after that, you cannot go to any other menu on MFD, you are stuck on Phone menu. Except, when you set navigation, than navigation menu with instructions is shown. Though it is interesting that then also other menus on MFD can be accessed (Audio, MFD, Settings, etc.). If you select Phone, than you are again locked into the Phone menu, you cannot go out of it.
Is there any suggestion what to try? I tried different options of coding the RNS315, factory resetting both RNS315 and MFD, but no luck.
Can this be maybe connected to the fact, that it does not have the correct buttons on steering wheel installed? I checked if that can be programmed but it is not possible.
Steering wheel with buttons for factory installed phone:
Installed steering wheel without buttons for phone:
Full autoscan:
Full autoscan:
Saturday,25,April,2015,14:58:11:07078
VCDS Version: 15.3.0.0 (x64)
Data version: 20150314
VIN: TMBEM6NH0E45xxxxx License Plate:
Mileage: 7360km-4573mi Repair Order:
Chassis Type: NH (6N0)
Scan: 01 03 08 09 10 15 17 19 25 37 44 56
VIN: TMBEM6NH0E45xxxxx Mileage: 7360km-4573miles
Address 01: Engine (J623-CBZA) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 HA HW: 03F 907 309 AK
Component: SIMOS10.22AH10 5483
Revision: --H10--- Serial number:
Coding: 00110056202400080000
Shop #: WSC 73430 031 00043
ASAM Dataset: EV_ECM12TFS02103F906070HA 004005
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 68D58C8593687D786F-803D
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 614 517 BD HW: 6R0 614 517 BD
Component: EBC 460 ESP H08 0004
Serial number: A00GV2E
Coding: 4129281489B100BC824914D891A80040490400
ASAM Dataset: EV_Brake1ESPAEntryTRW 002011
ROD: EV_Brake1ESPAEntryTRW.rod
VCID: 76E9D2FDC9DC9B88ED-8023
Address 08: Auto HVAC (J255) Labels: 6Q0-907-044.lbl
Part No SW: 5JA 907 044 HW: 5JA 907 044
Component: Climatronic H04 0106
Revision: A1001000 Serial number: 1309021A-0499
VCID: 78F5DCC5CBC8EDF8FF-802D
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 P HW: 6R0 937 087
Component: BCM PQ25 H+4 H34 0411
Revision: BF034001 Serial number: 0581 299131865
Coding: 7A980BB800010000000806307D6B8CC00EC0400F608E0000020000004000
Shop #: WSC 73430 790 00043
VCID: 4A91560DE5A4AF6859-801F
Subsystem 1 - Part No SW: 5E0 919 719 E HW: 5E0 919 719 E
Component: E221__MFL-PR6 H04 0120
Coding: 800000
Address 10: Park/Steer Assist (J446) Labels: 5JA-919-475.clb
Part No SW: 5JA 919 475 A HW: 5J0 919 475 A
Component: PARKHILFE 3K H11 0005
Revision: -------- Serial number: 32961330102958
Coding: 108002
ASAM Dataset: EV_EPHVA14SK25X0000 001002
ROD: EV_EPHVA14SK25X0000.rod
VCID: 448D7835CF807918A3-8011
Part No SW: 34D 959 655 B HW: 34D 959 655 B
Component: AirbagVW20 004 0365
Serial number: 003K7R022AK5
Coding: 88CCC00000000000540000C8000000000065
ASAM Dataset: EV_AirbaVW20SMEVW253 001108
ROD: EV_AirbaVW20SMEVW253_SE25.rod
VCID: 346D28F59F20C99813-8061
Subsystem 1 - Part No SW: ----------- HW: 480 412 310 13
Component: SideSensor_Df 003 0148
Serial number: 349650A25A6CBEE47C49
Subsystem 2 - Part No SW: ----------- HW: 480 411 510 13
Component: SideSensor_Pf 003 0148
Serial number: 350650A25A7D3CE37E6$
Subsystem 3 - Part No SW: ----------- HW: 480 411 710 13
Component: SideSensor_Dr 003 0148
Serial number: 351650A25ACBBF12BDC6
Subsystem 4 - Part No SW: ----------- HW: 480 411 510 13
Component: SideSensor_Pr 003 0148
Serial number: 352650A25B8A3F52BE6.
Part No SW: 5JA 920 840 D HW: 5JA 920 840 D
Component: KOMBI H04 0709
Coding: 111800
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 3B7F03C9B27E06E0D2-806E
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H34 0411
Revision: BF034001
Coding: 932200
VCID: 70E5E4E5A3B8B5B837-8025
Component: IMMO H04 0709
VCID: 6AD1F68D8D644F6879-803F
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 3C8 035 279 L HW: 3C8 035 279 L
Component: RNS315-EU H73 0407
Serial number: VWZAZ2N0513556
Coding: 040002110200100000000302
Shop #: WSC 00788 648 00255
ROD: EV_RNS315EUV2UDS.rod
Component: EUR_W_V4 0050
1048629 - Aux IN Socket
B1104 13 [009] - Open Circuit
Reset counter: 209
Mileage: 7364 km
Date: 2015.04.25
Time: 12:55:39
1048647 - Cellular Antenna
B1053 13 [009] - Open Circuit
Reset counter: 209
Mileage: 7364 km
Date: 2015.04.25
Time: 12:55:38
1048650 - Telephone baseplate
B1051 13 [009] - Open Circuit
Reset counter: 209
Mileage: 7364 km
Date: 2015.04.25
Time: 12:55:38
1048652 - Telephone Microphone
B1048 13 [009] - Open Circuit
Reset counter: 209
Mileage: 7364 km
Date: 2015.04.25
Time: 12:55:38
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V2.clb
Part No SW: 6R1 909 144 R HW: 6R1 909 144 E
Component: EPS_TRW_ALow 311 3111
Serial number: CDAP0601
Coding: 0003
Shop #: WSC 63199 001 1048576
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_SE25.rod
VCID: 4689623DF9BC4B08BD-8013
End-------------------------(Elapsed Time: 01:53)--------------------------
