2012 B8 (8k) Avant, Coding Help, Westfalia Tow bar, factory tow electrics
ptotheg
Queensbury, NY, USA
C?ID=238014
Hello Everybody,
Just got the Westfalia Tow hitch (tow bar), and the factory electrics kit for my 2012 A4 Avant (B8/8K). I have already completed the "nut and bolt" install of the kit. My vehicle is not pre-wired, so I still have to add the pigtail that came with wiring kit (factory fuse location wiring, and tapping into the CAN data wires). First I would like to say for anyone considering adding a hitch to your Audi, spend the extra money and get this kit, it is top notch and high quality. If you are in North America, avoid Eurohitches.com at all cost and find another way to get it (ultra bad, horrible experience).
Now that that is out of the way, I am just a small step beyond a newbie with the Ross-Tech VCDS. And I have researched everywhere looking for anything information for this retrofit on this particular model (may be the same as the 8E?). I cannot find any specific information on what would need to be coded? Or if I can do that with the Ross-Tech or if it is necessary to have the dealer do the coding?
I appreciate any guidance or information that could be had from the wealth of information that the members here have (you guys have helped me a bunch already).
Cheers!
Patrick
No way no how is an 8K going to be anything like an 8E. The 8K is a totally different car with much newer systems in it. Unfortunately, we haven't got anything documented yet. Still, I think chances are good that some of our associates in Europe have some insight, so unless this is something that needs to be done immediately, give it a day or two to see what crops up here.
ptotheg
Queensbury, NY, USA
C?ID=238014
Thanks!, I've got a week or two before I need to hook up. Then, maybe hand signals, LOL! I was reaching with the 8E, but wasn't going to look at it like that unless someone had done it. I was hoping that other Avant/Allroad owners have hit this hurdle already, and maybe the Q5 might have some similar (reaching a little there). Who knows, may be very easy. Some of these Avants/Allroads were built with an extension on the rear harness that this will plug right into, and already wired through the rear fuse box. It might just be simpler than I'm thinking....Here's to Optimism!
ptotheg
Queensbury, NY, USA
C?ID=238014
The manufacturer of the harness and control module is "Jaeger".
At the end of the instruction it says:
-Please effect coding as follows:
--Guided Troubleshooting
---Skip
----Function Component Selection
----Select the "Direct Input of AM Code for Vehicle Alteration", testing program from within Action Management
---Done
----Enter AM Code
(the necessary AM code can be found in the "coding sheet" in the Audi dealer portals [including ServiceNet, ELSA-System, ETKA-System])
That last bit is making me think that I need to go to the dealer, but if it is a standard code.....maybe not
Zenerdiode
Newcastle, England
C?ID=24330
An Auto-Scan of your vehicle would definitely help here. Please have a look at my post here. In my list of modules; all but the 13-ADR were prompts from within Coding or Adaptation in VCDS. I forgot to add 6C-Backup Camera to that list, nonetheless it still has the data to code in VCDS.
ptotheg
Queensbury, NY, USA
C?ID=238014
Monday,20,April,2015,20:24:31:42805
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WAU4FAFL6CA083758   License Plate: FRM8334
Mileage: 47180km-29316mi   Repair Order:
Chassis Type: FL (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3C 42 46 47 52 53 55 56
          5F 62 6C 6D 72
VIN: WAU4FAFL6CA083758   Mileage: 47180km-29316miles
Address 01: Engine (0-----CAEB)       Labels: 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AG    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H20 0002
   Revision: E1H20---
   Coding: 010C010A290F0160
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
   ROD: EV_ECM20TFS0118K2907115AG.rod
   VCID: 74E7E680DF1C1A817A7-8021
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 8K0 927 158 S    HW: 0BK 927 156 R
   Component: 0BK 20TFSIUSA H17 1003
   Revision: --H17---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   ROD: EV_TCMAL551211_AU48.rod
   VCID: 46836C48F900D811143-8013
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
   Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
   Component: ESP8 quattro  H04 0060
   Coding: 1D0D18
   VCID: 020BB0589DA8243178B-8057
   Part No SW: 8K0 907 064 CH    HW: 8K0 907 064 CH
   Component: BCM2 2.0      H05 0435
   Coding: 0D0200
   Shop #: WSC 06335 000 00000
   VCID: 78FFD2B0CB747EE156F-802D
   Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
   Component: KLIMA 3 ZONEN H08 0180
   Revision: C1000000    Serial number: 01191020111027
   Coding: 64102000
   VCID: 000FBA5093A436216EF-8055
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H30 0392
   Revision: 10030001    Serial number: 00000001255367
   Coding: 26001091063CAF010000080300003D0D0F1C460802010161000000
   VCID: 3C770EA0BFCC92C1727-8069
   Component: WWS 171011  H07 0070
   Coding: 00FD11
   Component: RLS  H04 0003
   Coding: 025028
   Component: E1 - LDS  H03 0031
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 T    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H01 0081
   Revision: 11001001    Serial number: 36861129300363
   Coding: 200103
   VCID: 4A9B5878E5183C71F0B-801F
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003GLD0P54CD
   Coding: 303837354230303030304A55304C384B3053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 45816B44C406D3091D9-8010
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R1100005QSX
   Serial number: 6334MSME65440A69H
   Serial number: 6344MSME645216378
   Serial number: 6352QSME746002589
   Serial number: 6362QSME11621B4CG
   Serial number: 63732SME79661E605
   Serial number: 63832SME43610B48.
   Part No SW: 8R0 953 568 K    HW: 8R0 953 568 K
   Component: Lenks.Modul   H07 0156
   Revision: 00000000    Serial number: 20111020000488
   Coding: 000017
   VCID: 49996774E01E3769F91-801C
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 981 C    HW: 8K0 920 981 C
   Component: KOMBIINSTR.   H31 0258
   Revision: 00000000    Serial number: EJB62TEAC
   Coding: 8B1611000B00D705020000
   VCID: 3365259C92925DB9A3D-8066
   Part No SW: 8T0 907 468 AJ    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0120
   Revision: FC201059    Serial number: 5900F11A1001DC
   Coding: 00C303
   VCID: 0919A774A09E7769391-805C
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H07 0170
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
   Component: MEM-FS        H06 0074
   Revision: AA000000    Serial number: 00000015850939
   Coding: 00581B00000000000000
   VCID: 3B750DBCBAC295F97BD-806E
   Part No SW: 8K0 907 566 H    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0030
   Revision: 00H01000    Serial number: 6PZ 009 014-82
   VCID: 3C770EA07FCC92C1727-8069
   Subsystem 1 - Part No: 8K0 907 568 H
   Component: J0770_SWA_Slave_H01 0030
   Subsystem 2 - Serial number: 6PZ 009 014-92
   Subsystem 3 - Serial number: 5F10.10.1100H010003C325551ÿ
   Subsystem 4 - Serial number: 325551ÿ
   Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
   Component: TSG FA        H12 0357
   Revision:             Serial number: 0000120985353
   Coding: 011C13204E00410001
   Revision: 00002001    Serial number: 0160838493
   Coding: 0126023A20BA741580B0023200000000
   Component: GTO BF  H01 0070
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS150  H08 0043
   Subsystem 4 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J394 PS240  H08 0043
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34804010625703
   VCID: 7AFBC8B8F5786CF120B-802F
   Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
   Component: TSG BF        H12 0357
   Revision:             Serial number: 0000015955158
   Revision: 00000003    Serial number: 00000001036649
   VCID: 34672680979C5A81BA7-8061
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 C    HW: 8H0 907 357 C
   Component: AFS 1           H01 0040
   Revision: 00H01001    Serial number:
   Coding: 0000019
   VCID: 326B2098AD8854B1A8B-8067
   Subsystem 1 - Part No: 8K0 941 329
   Component: AFS-Modul links H02 S001
   Subsystem 2 - Part No: 8K0 941 329
   Component: AFS-Modul rechtsH02 S001
   Part No SW: 4G0 035 082 B    HW: 4G0 035 082
   Component: Radio U SIRIU H53 0076
   Revision: AB001007    Serial number: 156J60B7561579
   Coding: 020007010000000001
   VCID: 1F4DD92C0E1AE9D9775-804A
   Part No SW: 8T1 035 664 D    HW: 8T1 035 664 B
   Component: H-BN-NA       H52 0165
   Revision: --------    Serial number: 490J10B7644635
   Coding: 010200010006A1EF51000B0E000000030000
   VCID: 397917B4B0FEA7E9691-806C
   Component: NAR 2011  0505
   Component: DU7 High  H41 0104
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Component: E0380 Bedient  H08 0100
   Component: CD-Database  2712
   Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
   Component: TSG HL        H11 0357
   Revision:             Serial number: 0000015674767
   Coding: 010C13204000210001
   VCID: 45816B44CC06D3091D9-8010
   Revision: --H05---    Serial number: 525PA8-J149396
   Coding: 1000007
   VCID: 387F12B04BF4BEE196F-806D
   Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
   Revision: --------    Serial number: 8K9827851A
   Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H11 0357
   Revision:             Serial number: 0000015674764
End-------------------------(Elapsed Time: 03:54)--------------------------
ptotheg
Queensbury, NY, USA
C?ID=238014
Hey guys,
I think I've cracked it. Between the link above from Zenerdiode, and from a few other spots on the various Audi/VW forums, they had most of what I think I needed. My vehicle is North America Market, and most of the coding stuff I saw was with engine trans combos we unfortunately do not get (no V6 TDI's here :( ).
Due to the insane variety of delivered options these cars have, its hard to have a list of exactly what to do for every B8. Basically the only way to Code for the addition of the trailer module *j345 and wire harness, Is to take a peak inside each control module and its long coding and find everything "trailer" and check it on. There are 1 or 2 modules where you just substitute a number in the code string based on option you have added.
So pretty much everything works as intended now. With 2 exceptions.
1.) I need to calibrate my backup camera (keeps throwing a code for that, have not looking into it yet).
2.) With only the left directional (LHD), the lane change warning system flashes erratically when I turn the directional on. This just may the radar sensor in the bumper picking up on my trailer.
So, here is the coding, only things changed from the set listed above were strictly for the trailer coding. (and i'm not sure how to post the code so its in another window like edited above, so sorry for the long post).
Thursday,30,April,2015,17:08:17:42805
Mileage: 47520km-29527mi   Repair Order:
          5F 62 69 6C 6D 72
VIN: WAU4FAFL6CA083758   Mileage: 47520km-29527miles
   Revision: E1H20---
   Coding: 010C010A290F0960
   Shop #: WSC 06334 123 12345
Readiness: 0000 0101
   Revision: --H17---
   Coding: 000002
   Coding: 1D8D18
   Coding: 0D0200
   Coding: 64102000
   Coding: 26001091063CAF010000080300003D0D0F1C660802010161000000
   Shop #: WSC 06335 123 12345
   Coding: 00FD11
   Coding: 025028
   Coding: 210103
   Coding: 000017
   Coding: 00C303
   Coding: 0126023A20BA741580B0023220000000
   Coding: 0000019
Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Component: ConWys Trailer H09 0100
   Revision: 1A001001    Serial number: 00000161077413
   Coding: 0200000000000000
   Shop #: WSC 00007 223 57222
   VCID: 36631C8881E04891843-8063
   Coding: 1000107
03006 - Back-up Camera System not calibrated
                    Reset counter: 202
End-------------------------(Elapsed Time: 03:59)--------------------------
ptotheg
Queensbury, NY, USA
C?ID=238014
I can go back through this weekend and cruse through each module and let you know exactly which bits and bytes if you need for the wiki/RT instructions.
Thanks again for your help. After my local dealer basically refused to code it for me, the Ross-Tech VCDS has already earned its money in the short period of time that i've had it.
NEtech
C?ID=56995
I think you could have avoided the Calibration error, if you had not changed Coding in [6C] from:
1000007
to:
1000107
It should be: 1010007
One coding that may be changed (I have not seen result of it on a car yet), is coding for [5F]:
010200010006A1EF51002B0E000000030000
Maybe it changes some setup in MMI?
Else the rest is right.
ptotheg
Queensbury, NY, USA
C?ID=238014
Thanks for the feed back guys,
I looked through 5F a handful of times, nothing listed for trailer in any of the long coding option boxes, are you guys just typing that part of the code in there? or is this where the revision letter of the control module starts to show differences?
I will double check the coding on the back up camera, I am nearly certain that all I did was alter the digit as required for "trailer" in the coding section. The back up camera works fine as it always had. I have downloaded the .pdf from the link above, and have a large format printer at work, following those instructions should be too bad to recalibrate.
Also with the coding link directly above, there is a coding difference on the coding of the "lane change" module. Same part number on the control module except for the revision letter. When I have my trailer connected and use my left directional (does not happen with right directional), the warning will flash brightly 2x, then nothing for a second or two, then flash 2x quickly again. Other than that it appears to function correctly. I did not change coding to that module.
I'll have an opportunity to check shortly (waiting for the finish of the WEC 6hrs of Spa!)
NEtech
C?ID=56995
Once you touch coding in Backup Camera you must calibrate it, no matter what you change and even you roll back to genuine coding , it will require calibrate again
Yes, but I have seen several where there was no DTC for Camera calibration, after Trailer Hitch coding.
ptotheg
Queensbury, NY, USA
C?ID=238014
I did indeed have the coding wrong on the back up camera. So that is now corrected.
Here is an image of what I am seeing in the long coding of the 5F module, am I supposed to edit the binary code? I seem to be lost on that one.
NEtech
C?ID=56995
Yes, or use backspace on the zero, write 2 (result 2B) press tab.
Or just copy the complete long coding as New coding > [Do it].
ptotheg
Queensbury, NY, USA
C?ID=238014
Done and Done!
Thanks so much guys! Cheers!
So if anyone in North America, with a 2012 A4 Avant, optioned as mine, and you wish to put a trailer module and factory style wiring, here is the coding you need (and I hope that this post helps others in the future):
Monday,04,May,2015,17:48:17:42805
Mileage: 47590km-29571mi   Repair Order:
          5F 62 69 6C 6D 72
VIN: WAU4FAFL6CA083758   Mileage: 47590km-29571miles
   Revision: E1H20---
Readiness: 0010 0101
   Revision: --H17---
   Coding: 000002
   Coding: 1D8D18
   Coding: 0D0200
   Coding: 64102000
   Coding: 00FD11
   Coding: 025028
   Coding: 210103
   Coding: 000017
   Coding: 00C303
   Coding: 0000019
   Coding: 010200010006A1EF51002B0E000000030000
   Coding: 1010007
                    Reset counter: 210
ptotheg
Queensbury, NY, USA
C?ID=238014
Hey Guys, back again for a question.
Sold my old trailer. Built a new trailer for custom application (small sailboat). Built the trailer with a LED lighting kit (optronics model TLL36RK). Almost exactly like my last trailer lights, except these are LED. It is a 4-pin harness. I have a 7-pin Euro to 4-pin US harness adapter which worked with my old trailer.
Everything works correctly except brake lights (which are also the directionals). Running lights work, directionals work, Hazard lights work. Only the brake lights do not work. I hooked the trailer to a friends truck, and all works 100%. So there has to be something either with the coding, or within the trailer control module that needs to know there is LED lights instead of incandescent.
Is this a known issue?
Any help would be appreciated.
Thanks in advance
ptotheg
Queensbury, NY, USA
C?ID=238014
Hey Rene,
I have done the coding, all of those are done, and a couple more. I don't think the controller works with LED trailer lights. I plug a regular "incandescent" lighted trailer to the car, everything works 100%, plug the LED lighted trailer to the car, and everything works except brake lights. The lights on this specific LED trailer work 100% with junky American pick-up truck. I do need to use a 7-pin Euro/UK to 4-pin trailer adapter, which might have something to do with it. but everything being the same, my car will not operate brake lights on an LED lighted trailer, otherwise everything is perfect. Which would have been nice to know before I spent the money on the LED set.
I found some information similar for issues with VW tiguan which uses the same control module, but a slightly different OEM 7-pin connector (North American RV style), and they have an adapter they are supposed to use for LED trailer lights, but I cannot find part numbers or an adapter that works between a 7-pin Euro/7-pin North America plug.
ptotheg
Queensbury, NY, USA
C?ID=238014
A bit of research is telling me that there is a resistance difference in the circuit when LED tail lights are involved, compared to incandescent lights. There is a harness available on etrailer.com http://www.etrailer.com/Wiring/Curt/C57003.html which seems to do the trick for some people, guessing that one of the housings has a resistor set up on the brake circuit to solve the issue. The problem is. I start with a 7-pin round connector on the car (factory style Euro harness, because Audi did not want North American Market towing with Avants or Sedans, but it is OK for the ROW), and my trailer is a North American 4-pin flat connector. It is going to cost me more in adapters than it is to just get a regular incandescent light set.
I would like to solve this problem somehow, because now that LED trailer lights are becoming more prevalent on more trailers, I may be in the situation where I need to tow a trailer with LED lights.
DV52
C?ID=194404
ptotheg;
been reading your discussion with interest albeit i don't own your model vehicle. i could have entirely misunderstood your problem, but purely from a theoretical perspective, it shouldn't be that difficult to make-up your own loom to trick the lamp error detection module into thinking that you have incandescent brake lights (i think).
isn't the solution to simply load-up the two brake light circuits on your trailer with a couple of suitably sized resistors? you should be able buy a couple of cheap 20 watt ceramic resistors from you local hobby store and mount them onto the trailer frame for cooling, or you could buy purpose built resistor for car LEDs (i.e. something like these). if you go the former route, you will need to choose an appropriate resistance value. not sure where the lamp error threashold is for your Audi, but it's just a case of using Mr. ohm's formula. for example, if you start with a 20 ohm resistor and assuming a nominal bus voltage of 14V, the device will generate 10 watts (long term) which gives you a good safety margin -should the brake lights stay on for a long time. a 20 ohm resistor placed in parallel with the brake light LED on the trailer will increase the ciruit current by 700 mA. Not sure if this sufficient to do the trick, but 20 watt ceramic resistors are cheap, so try progressively smaller resistor sizes. only thing to keep in mind is that as you decrease the size of the resistor, the wattage rating increases inversely to it's resistance value(i.e. watts = V*V/R).
apology if i have misunderstood the problem.
cheers
