Audi A8 Quatro- Transmission Errors , no forward motion or limited to slow
keeganjm
Old-Timer :-)
C?ID=18718
Monday, 13 April 2015, 19:15:18.
Control Module Part Number: 4D0 927 156 CP
Component and/or Version: AG5 01L 4.2l5V USA 1414
Software Coding: 00002
Work Shop Code: WSC 02314
VCID: 79856EE770C1
17114 - Gear Ratio Monitoring: Incorrect Gear Ratio
P0730 - 35-00 - -
After flushing the gear box twice, I now have the following errors
The engine seems to run normally.
Address 01: Engine Labels: None
Controller: 4D0 907 559
Component: 4.2L V8/5V G 0004
Coding: 06653
Shop #: WSC 12345
VCID: EBA9C4AF8A9D
17549 - Load Calculation Cross Check: Implausible Value
P1141 - 35-00 - -
At this point the car is un-drivable. I would like some kind of procedure to check the valve body or TCM. These two items can be fixed without dropping the transmission which is like major surgery with the A8.
Is it possible that the TCM is not throwing enough current to the shift solenoids? Is it possible the valve body is simply "plugged" and therefore not alloy enough hydraulic pressure to engage the forward friction plates? The car makes a weird noise when engaged in 1 thru 4.
It sounds like it just is not engaging
What year? How many miles? How regularly has the fluid been done previously? (Yes, I know, Audi says it's "lifetime". Bullshit.)
I believe that TCM supports output tests on the solenoids, but I don't see how that's going to help here. I don't think you have an electrical problem here. TCMs are pretty good at identifying electrical problems and flagging them with DTCs.
golfi_vend
Tartu, Estonia
C?ID=195131
Flushing with transmission fluid not with some sort of cleaning solution?
keeganjm
Old-Timer :-)
C?ID=18718
the car is a 2000 with 166,600 miles
i have owned it 2 months
when i changed the atf is was black like used engine oil
the magnets had some very fine particles attached
so , im thinking now the valve body could be plugged?
would aplugged valve body show these symptons?
reverse motion is strong
roth
C?ID=242642
With 166K on the clock, I would look for a low miles used transmission or a good trans shop.
BR, Andy
