Hi Lala,
Thank you for trying to help. I want to confirm that you have full LED headlights installed, yes? (I am retrofitting from Bi-xenon to full LED.)
Please see the below table I created. I hope it is clear. Can you please confirm the table and see my questions below.
| Connect to | Function |
LED Pin 1 | unit Pin 4 ?? | module |
LED Pin 2 | unit Pin 5 ?? | module |
LED Pin 3 | Not used | |
LED Pin 4 | Not used | |
LED Pin 5 | HID Xenon wire 5 (brown) | ground |
LED Pin 6 | HID Xenon wire 6 (black/yellow) | low beam+ |
LED Pin 7 | ?? | |
LED Pin 8 | B box - fuse 5A | KL 15/cornering lamp? |
LED Pin 9 | C box - fuse 15A | KL 15/cornering lamp? |
LED Pin 10 | New ground wire | ground |
LED Pin 11 | HID Xenon wire 10 (black/blue) | DRL+ |
LED Pin 12 | HID Xenon wire 12 (black/grey) | DRL+ |
LED Pin 13 | HID Xenon wire 9 (black/white) | DRL turn signal |
LED Pin 14 | HID Xenon wire 8 (brown/blue) | side marker |
Questions:
1) What is KL 15? Is this cornering light?
2) How do I connect to unit? Do I need new wiring harness to connect?
3) How do I connect LED pin 8 to B box? Do I need new wiring harness to connect?
4) How do I connect LED pin 8 to C box? Do I need new wiring harness to connect?
5) Where does LED pin 7 connect?
6) Where does LED pin 12 connect? When I tested connections, I need BOTH LED pin 11 and pin 12 connected to power for DRL to work.
Thanks so much for your help!
Sanjeev
hello
yes I retrofit full LED light , I have before just like you !
you have lots of question but I try to help
first unit is : Address 55: Headlight Range
now you have in this unit plug in red color
and you need to :
remove out wires from pin 15 & 17 and connect together and put in pin 4
wires from pin 19 & 21 and connect together and put in pin 5
next
you must to pull wires from fuse box C
from SC 37 to left headlight pin 9
from SC 36 to right headlight pin 9
now pin 10 on pin 11 ( black/blue)
now pin 9 on pin 13 ( black /white)
now pin 8 on pin 14 ( brown /blue) only US !!!!!!
pin 3 ,4 and 11 headlight not use anymore
pin 5 ,6, 7 and 12 on headlight dont touch ( use on new light)
now is problem for explain but I try
for pin 8 hedlight
you need to pull witres from B-box in engine space
from SB 32
but if you dont have webasto
yuo dont have holder for SB 32
you need to buy !
then
this power you must get from relay
and again you must to buy holder for relay
when you all buy
next step is :
to get power from B-box
from letter T1 and pull wire to holder relay and put in space 123
, then you need to pull ground to holder relay in space 122,
then you need to get from neighborhood relay from red green wires and pull to holder space 121
when you finish you must to pull wires from space place relay 125 to SB 32 holder
then from this SB 32 to pull wires from left and right side pin 9
[/URL][/IMG]
after this you need to put thiscoding in :04141A46C041067541C04004511007000000000000000000000000000000
after this you need to go adaptation channel
and change value for front light....
