Results 1 to 10 of 11
Thread: 09 q7 roof leak
    Jul 2014
    09 q7 roof leak
    hi everyone looking to get any info on this leak. after car wash noticed no sound from speakers. right rear headliner was wet. volume came back after few hours. removed right rear panel to inspect. it has panoramic roof, poured water and noticed water leaking from right rear. poured on all corners of the roof, all corners drained about the same . hope to get some info before dropping the headliner.
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    Water drain hose behind
    Water drain hose run(proceed) behind in the columns-C-and end in the wheel arch about the wheel arch bowl.
    The cleaning occurs(takes place) from the lower wearing out.
    (done by translation helper)
    -Wolfgang
    Magdeburg, Germany
    The Q7 and A6 Avant have a common problem with the rear wiper/washer. The washer supply/pipes break near the rear lid/hatch, resulting in washer fluid dropping right onto the infotainment system (with the sound system on top). This is a common issue and Audi is aware of it. If I remember correctly, they might even cover this (partially) under warranty. The sound system is likely beyond repair, just make sure not to use the (rear) washer until this has been checked and fixed.
    Jul 2014
    just to make it clear when I pour water around moon roof drain, I can see it leaking inside the cab onto the head liner and then to the amplifier
    Jun 2014
    idaho
    your sunroof drains are leaking where they connect at the drains
    Mar 2015
    Belgium
    Here an overview
    IMAGE REMOVED DUE TO COPYRIGHT ISSUES
    Last edited by Sebastian; 03-23-2015 at 06:28 AM. Reason: Please do NOT use copyrighted materials, to which you don't own the rights to...
  7. Likes ivagp liked this post
    Jul 2014
    Quote Originally Posted by passatmotion View Post
    Here an overview
    thank you. has any one had audi cover this after warranty.
  9. #8
    Jun 2014
    idaho
    i doubt that, its easy to do all the drains yourself, i bet audi would be lickin their chops to charge u for their crappy job gluing the stupid things
  10. #9
    New User
    Nov 2017
    I have a tutorial I made on how to repair this yourself for £4.50 / $6.22
    Can i post it here or make a new thread?
  11. #10
    If it's for the Q7, feel free to post it here.
  12. Likes jaisunny liked this post
