Timeline for Turbo with HEX-NET in VCDS (not mobile)
CosmicVR6
C?ID=238069
Any idea when the HEX-NET interface will get Turbo mode enabled when using Windows with a USB cable?
Nope. What module are you logging?
CosmicVR6
C?ID=238069
Mainly want engine speed, maf, boost specified, boost actual
From what ECU? I'm curious if Turbo mode is even applicable to your particular ECU.
CosmicVR6
C?ID=238069
Oh, misunderstood. Its a 2012 Golf R
Part No SW: 5K0 907 115 M HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH20---
That ECU will only communicate via CAN. Turbo mode doesn't really apply there.
CosmicVR6
C?ID=238069
good to know, thanks.
What kind of sample rate are you seeing?
Can you please post complete scan data from your ECU? If it's UDS protocol, try the "Group UDS Requests" checkbox; it will make a big difference.
CosmicVR6
C?ID=238069
I was doing 12 measurements through the Advanced Measurement tool, and getting 1Hz. I noticed it was ~6Hz when I added just the first measurement, and dropped to 3 with the second, etc.
How can I tell if its UDS?
Autoscan:
Thursday,12,February,2015,08:58:11:63764
VCDS Version: 14.10.1.1 (x64)
Data version: 20150130
VIN:   License Plate:
Mileage: 62530km-38854mi   Repair Order:
Chassis Type: AJ (7N0)
Scan: 01 03 05 08 09 15 16 17 19 22 25 2B 2E 37 42 44 46 47 52 55
          56
VIN:    Mileage: 62530km-38854miles
Address 01: Engine (CRZ)       Labels: 06F-907-115-CDL.clb
   Revision: 5BH20---    Serial number:
   Coding: 0403010A180F0160
   VCID: 3424D5DC57C27B81BA8-8061
   Revision: 00H31001
   Coding: 144B800C49230001281301E692220041B70000
   VCID: 7BB63EE0FA1C74F93B2-802E
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434 B
   Revision: 00085000    Serial number: 0160625423
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_AU21.rod
   VCID: 3424D5DC9FC27B81BA8-8061
   Part No SW: 5K0 907 044 FE    HW: 5K0 907 044 FE
   Revision: 00001004
   Coding: 0000001002
   VCID: 73A616C0DA4C3CB9632-8026
   Part No SW: 1K0 937 084 G    HW: 1K0 937 084 G
   Component: BCM PQ35  B   110 0651
   Revision: 00110 AC
   Coding: 6F180A1A90272A04108800C170000C4448052086774D8DB0E48420248040
   VCID: 3228D3C46DD675B1A84-8067
   Component: Wischer 06121  26  0512
   Coding: 009795
   Serial number: 003GVRA12PVH
   Coding: 00003131
   VCID: 3FCE8AF0A684A8D957A-806A
   Serial number: ---0000R--00002EEG00
   Serial number: 3572MSME411A3168ZZZR
   Serial number: 3582MSME62273068ZZZS
   Serial number: 3512QSME46326630ZZZL
   Serial number: 3522QSME6236662FZZZ
   Serial number: 35527SME32644F29ZZZL
   Serial number: 35627SME51544A29ZZZH
   Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20111209200809
   Coding: 100A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DB230F8EC087AC9056-8028
   Coding: 820000
   Part No SW: 5K6 920 972 E    HW: 5K6 920 972 E
   Coding: 270F01
   VCID: 383CE1EC83AA9FE1960-806D
   Revision:   H42       Serial number: 071211F1003092
   Coding: 350000
   VCID: 3A38FBE4B5A68DF1604-806F
Address 22: AWD        Labels: Redir Fail!
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   VCID: 45C298180C58F2091D6-8010
   Coding: 000007
   VCID: 6A980BA48D86FD71D04-803F
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000274364003
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E10C7B471EE5151CCC-807B
   Revision: A1001003    Serial number: 7661472287
   Coding: 020000
   VCID: 291A34A84000366919E-807C
   Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
   Component: RNS315-NAR    H33 0265
   Serial number: VWZAZ2L8483252
   Coding: 04050001010005000000100A
   ASAM Dataset: EV_RNS315NARV2UDS A01004
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 230626802A2CEC39532-8076
   Component: NAR_V2  0002
          B11CF 53 [009] - Deactivated
                    Reset counter: 217
                    Mileage: 7042 km
                    Date: 2012.05.28
                    Time: 14:51:50
   Component: Tuer-SG         009 2117
   Coding: 0001076
   VCID: 312ADCC8A8D04EA9D1E-8064
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 251    3201
   Revision: 00H20000
   Part No SW: 5K0 035 456 B    HW: 5K0 035 456 B
   Component: KonzernAmp 8K H07 0368
   Revision: --------    Serial number: EAA085A0006473
   ASAM Dataset: EV_AudioVerst8KanalBNO1 Unknown
   VCID: 291A34A84800366919E-807C
   Coding: 0001076
   VCID: 3228D3C4ADD675B1A84-8067
   Coding: 1479708
   Subsystem 1 - Part No: 7L6 941 329 B
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B
   Coding: 00000022
End-------------------------(Elapsed Time: 01:41)--------------------------
When you open a session with a control module, the protocol is shown in the Comm Status box in the upper left corner of of the Open Controller screen.
We can also tell from the scan you posted that it's not UDS due to the absence of an ASAM identifier. E.g. look at your 08: Auto HVAC module. There you'll find a line showing "ASAM Dataset: EV_Climatronic A01010". That controller uses UDS. Since you ECU has no such line, it does not.
Now let's talk about not killing your sample rate so badly.
First, since this module still uses standard measuring block groups, the more different groups your pulling data from, the more groups VCDS has to read. In Advanced Measuring Values, your location identifiers take the form 001-1, 001-2, etc. The three digit number is the "Group" a particular data element is being pulled from. Try to minimize the number of different groups you're pulling data from. There's no speed penalty for a second, third, or even fourth value coming from a group that you're already reading one value from.
The next thing to do is head for the Options screen and try some of the stuff in our FAQ entry 4.8
CosmicVR6
C?ID=238069
Cool, thanks. I did just two modules and changed the Blk Int and Char Int values, and got 4Hz.
