Hello Ross Tech,
First let me say, "Thank you, thank you, thank you, for making such a wonderful product!" I had been looking at your products for awhile and just couldn't get off the fence, until my 08 Jetta decided it didn't want to play one morning. I decided on the VCDS Mobile because of its flexibility with Mac OS and other platforms. I just can't say enough great things about your product, I love it!
Okay, on to the story... My 08 Jetta is stock and runs perfectly most times. I insist on doing my own maintenance, mainly because I don't trust dealerships. The other morning, my wife went to take our daughter to school using the Jetta. For some odd reason, the PCM / ABS / ASR / and check engine lights were all on. The car would go no faster than idle speed in forward or reverse gear; stepping on the gas pedal did nothing! So basically, the car would start, would go forward, and would go backwards, but you could run faster.
Connecting the VCDS Mobile was simple and straight forward. This was the first scan:
I was able to individually clear all codes except for the Address 01 "005445 - Throttle Valve Controller" and the Address 03 "01314 - Engine Control Module". I focused on these two faults and discovered through reading other posts, the following:
If your car was previously running fine and you get these two fault codes, "Do not buy anything yet! First remove the throttle body and clean it." These throttle bodies supposedly have a life expectancy of about 300k miles, but are sensitive to dirt and carbon build-up. Mine showed some minor carbon build-up, but I didn't think it was enough to interfere with its operation. So I cleaned and lubed it with Kroil. Great penetrant and cleaned the carbon quite well. After cleaning, the throttle body was re-installed and an exterior ground wire was added at one of the fastening screws and connected to the vehicle ground (This was also a recommendation of the trouble shooting article).
With everything re-connected and engine running, I was able to clear all faults. A short test drive proved that the problem was fixed.
It is safe to say that the VCDS Mobile has more than paid for itself during its first use. I'm sure there is more than one dealership that would have sold me "One of each" for everything listed in the scan that had a "Fault". Once again I can't thank you enough for a wonderful product.
Very respectfully,
Phil Hogge.
VCDS Mobile 0.4123.0.4
VIN: 3VWJZ71K28M109066
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
62-Door, Rear Left -- Status: Communication Error 1000
Address 01: Engine Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 BG HW: 07K906032Q
Component: 2,5l R5/4V G 1565
Revision: 1NH01--- Serial Number: VWX7Z0GD24H1AV
Coding: 0000003
VCID: 6FA140BF29C21C69CB49D3-803A
P1545 - 008 - Malfunction - MIL ON
000291 - Throttle Position Sensor (G69)
P0123 - 001 - Signal too High - Intermittent
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No SW: 09G 927 750 HE HW: 09G927750HE
Component: AQ 250 6F 1090
Revision: 00H69000 Serial Number:
Coding: 0000584
VCID: 7BB964EF6DBA70C977C157-802E
No fault codes found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No SW: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3FC1D0FF3922ACE91B69A3-806A
013 - Check DTC Memory
Part No SW: 1K0 820 047 HH HW: 1K0820047HH
Component: Climatic PQ35 141 1010
Revision: 00141028 Serial Number: 00000000000000
VCID: 71A546C73FF60A99DD7DC5-8024
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0937049AH
Revision: 00H54000 Serial Number: 00000000831820
Coding: 14050E234004150007140000001400000008730B5C000100000000000000
Subsystem 1 - Part No SW: 1K1-955-119-E Labels: 1Kx-955-119.clb
Component: Wischer 191207 021 0501
Coding: 0038805
Part No SW: 1K0 909 605 AB HW: 1K0959339F
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial Number: 003B6M03YA03
Coding: 0013889
VCID: 6C9B57B318D4E771EE2BBC-8039
Subsystem 1 - Part No SW: 1K0-959-339-F
Serial Number: 6332MSME181903395
Subsystem 2 - Serial Number: 6342MSME172F6539K
Subsystem 3 - Serial Number: 6351HSME124558271
00532 - Supply Voltage B+
Part No SW: 1K0 953 549 BF HW: 1K0953549BF
Component: J0527 051 0100
Coding: 0010021
VCID: 77B178DF519254A913B93B-8022
Part No SW: 1K0 920 954 Q HW: 1K0920954Q
Component: KOMBIINSTRUMENT 3HL 1212
Revision: V0002000 Serial Number: VWX7Z0GD24H1AV
Coding: 0023203
VCID: 3A37A1EB220089C12C579A-806F
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0907951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial Number: 021107F1000162
Coding: ED807F070002021002
VCID: 302383C3F47C439192F308-8065
Component: IMMO 3HL 1212
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0959793L
Component: J386 TUER-SG FT 1133
Revision: 32008001 Serial Number: 00000009579206
Coding: 0001205
VCID: 3B39A4EF2D3AB0C9374197-806E
Part No SW: 1K1 909 144 M
Component: EPS_ZFLS Kl.070 H08 1901
VCID: 352DB2D70B1E66B9C10551-8060
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0959433CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial Number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DCA0
VCID: 844B9F1390448F31863BB4-80D1
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0959792L
Component: J387 TUER-SG BT 1133
Revision: 32008001 Serial Number: 00000585779130
Coding: 0001204
VCID: 3C3BA7F32834B7F13E4B8C-8069
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 C HW: 1K0035161C
Component: Radio DE2 015 0019
Revision: 00015000 Serial Number: VWZ4Z7G6312110
Coding: 0040402
VCID: 1F01707F99E2CCE93B2943-804A
Part No SW: 1K0 959 703 Q HW: 1K0959795J
Component: J388 TUER-SG HL 1120
Revision: 12006001 Serial Number: 00000002609210
Coding: 0001168
VCID: 3E3FADFB3E28A5E1107FB6-806B
Component: RDK 0450
Coding: 0100101
Part No SW: 1K0 959 704 Q HW: 1K0959794J
Component: J389 TUER-SG HR 1120
Revision: 12006001 Serial Number: 00000002551104
Coding: 0001168
Very respectfully,
Phil Hogge.
