Results 1 to 9 of 9
Thread: Golf MK6 Bi-Xenon with LED DRL and AFS retrofitted
    Jan 2015
    Norway
    Hello
    First of all, the intent of this thread is mainly for an informational purpose from my side.
    I've recently retrofitted Bi-Xenon with LED DRL and AFS to my Golf Mk6, MY- 09. Car was originally fitted with halogen headlamps, euro headlight switch and RLS.
    Wiring is done the same way as factory fitted bi-xenon headlamps. Please see attached sketch for how it's wired:
    The wire colours I've written doesnt necessary fit your car just so you know...
    To quickly recap what i've fitted, heres a list of parts and partnumbers.
    • New BCM (1K0 937 087 AL)
    • AFS master module (5M0 907 357 C)
    • 2x AFS slave modules (at headlamps) (7L6 941 329 B)
    • 2x Xenon Ballasts (5M0 907 391)
    • Level sensor at rear axle (1K0 941 273M, part number for AWD only I believe)
    Wiring harnesses will also have to be fitted. I bought a harness kit for xenon retrofit. This includes adapters for headlamps including some new wires. Wiring for the AFS master and the rear level sensor. After checking the harnesses I discovered some wiring errors in the 10-to-14-pin adapter and I decided to just ditch the adapter and replace the 10-pin connector originally fitted in the car with the new 14-pin connector. However my sketch illustrates how the 10-to-14 pin adapter should be wired if used.
    If you decide to replace the 10 pin connector aswell you need to replace the terminal crimped on pin 4 (10-pin connector) with a smaller one (Part number: N10335807).
    Coding
    Attached picture shows partly how my BCM is coded:
    To get the LED DRL function properly with this wiring I figured I had to change Byte 18 in my BCM aswell. For my light setup I found Byte 18 coded to 40 to work as expected. (Originally coded to 02)
    I've also seen people just connect pin 10 and 12 together but I don't think LEDs will work properly (dimming) with this bodge. Please correct me on this.
    Before you do anything to Byte 18 I'll advice you to read up on byte 18.
    This thread may be a good starting point.
    My exterior light setup:
    • Bi-Xenon with LED
    • Front fog-lights
    • Halogen tail lights
    • Single reverse light
    • Tail fog light
    • 3x Brake lights
    • Turn Signals
    You also have to code the AFS Master module, #55 in VCDS (Xenon Range/Headlight Range).
    Module has to be enabled in the CAN-Gateway if you havent done that.
    Please read the following Ross-Tech wiki: VW Golf (1K) Headlight Aim Control (Xenon with AFS)
    My AFS-Master is under the group "not documented" and after an inquiry to Ross-Tech, Dana provided me with the following coding: 1475676
    To quote Dana:
    Quote Originally Posted by Dana
    That includes AWD (which I missed earlier), 1 level sensor in addition to the RLS for the RoW market.
    This is all I know about that coding. I have no clue what effect the AWD and RLS bit have on the light system. AFS Slaves are coded automaticly after you cycle your ignition.
    I used 1446940 as coding previously, however Dana provided me with information saying this was for the NAR-market 2010+ GTI, and also missing a bit for RLS and AWD.
    When I change to my new coding it felt like the AFS were "less aggressive" compared to the NAR coding. I'll do some testing and provide more information about this at a later point.
    To finalize the AFS installation you need to complete the Basic Settings. Again, the Wiki above contains all information your need to know about this.
    With all this done everything (should) works flawlessly. LED DRL should be lighted alone when its bright outside (not able to test this yet). However I've tested them manually. LEDs are dimming when I turn on the turn signal etc. Bi-Xenons are working aswell. No fault-codes.
    This thread can also be worth reading
    Feel free to correct me if I've done any misstakes.
    Auto-Scan:
    Sunday,25,January,2015,09:35:12:59807
    VCDS Version: 14.10.0.0 (x64)
    Data version: 20141022
    VIN: License Plate:
    Mileage: 114680km-71258mi   Repair Order:
    Chassis Type: 1K (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 20 22 25 37 42 44 46 52 55 56 62
              72 77
    VIN: Mileage: 114680km-71258miles
    Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 BJ    HW: 03L 906 022 G
       Component: R4 2,0L EDC G000SG  6758
       Revision: 13H01---    Serial number:
       Coding: 0000172
       Shop #: WSC 18496 000 1048576
       VCID: 6ED3C097797E9A518D7-803B
    Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
       Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
       Component: ESP MK60EC1   H35 0106
       Revision: 00H35001
       Coding: 143B600D092700FB280F06E5901900423500
       VCID: 75E1EFFBDC28A9894CD-8020
       Part No SW: 5K0 907 044 AK    HW: 5K0 907 044 AK
       Component: Climatronic   130 0303
       Coding: 0000000000
       ASAM Dataset: EV_Climatronic A01001
       ROD: EV_ClimaAutoBasis_SE36.rod
       VCID: 74E7D2FFDF52B0817B3-8021
       Part No SW: 1K0 937 087 AL    HW: 1K0 937 087 AL
       Component: BCM PQ35  H+  112 0771
       Revision: AF112771
       Coding: 46180A3898251AC040080088710089EC477F4088733D8DF0E48420040000
       VCID: 7BF5F9C3FA0CFFF93A9-802E
       Component: Wischer 18110  21  0501
       Coding: 009795
       Component: RLS 281108 05  54  0402
       Coding: 0330AD
    Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
       Part No SW: 5K0 919 475     HW: 5K0 919 475
       Component: PARKHILFE 8K  H07 0002
       Revision: --------    Serial number: 60630832100423
       Coding: 100001
       VCID: 73E5D1E3D25CB7B9629-8026
       Part No SW: 5K0 959 655     HW: 5K0 959 655
       Component: AirbagVW10    022 0507
       Serial number: 003C2D063RL1
       Coding: 00003135
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01003
       VCID: 77FDE5F3CE24DB995E1-8022
       Component: S.Sens.Fahr.V  U01 ----
       Serial number: 4F697241ZZZZZZZZZZZZ
       Component: S.Sens.Beif.V  U01 ----
       Serial number: 40417241ZZZZZZZZZZZZ
       Serial number: 201F1247ZZZZZZZZZZZZ
       Serial number: 041A1315ZZZZZZZZZZZZ
       Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
       Coding: 0000532
       VCID: 78FFE6CF0B3AD4E157B-802D
       Subsystem 1 - Part No: 3C8 959 537 B
       Component: E221__MFL-TAP   H4˙ 0021
       Coding: 00000226
       Part No SW: 5K0 920 870 C    HW: 5K0 920 870 C
       Component: KOMBI         H21 0029
       Coding: 170F00
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
       ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
       VCID: 2D51079B7CF8A149F4D-8078
       Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1642
       Revision:   H56       Serial number: 24011400F14111
       Coding: 350002
       VCID: 7CF7FADFFF02F8C1333-8029
    Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
       Part No SW: 5K0 857 511 B    HW: 8P0 857 511 C
       Component: FLA           H04 0006
       Revision: AA001002
       Coding: 0101856B74745D545420363E00
       VCID: 2D51079B74F8A149F4D-8078
    Address 22: AWD        Labels: Redir Fail!
       Part No SW: 0BR 907 554 A    HW: 0BR 907 554 A
       Component: Haldex 4Motion      3016
       Coding: 0000005
       VCID: 43854123027C4739329-8016
       Component: IMMO          H21 0029
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
    Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
       Part No SW: 1T0 035 686 E    HW: 1T0 035 686 E
       Component: RNS-MID       H23 6270
       Revision: AB001001    Serial number: VWZ6Z7P4569654
       Coding: 04000400040000A00000
       VCID: 366328F781AEE291857-8063
       Subsystem 1 - Part No: 1T0 919 859 B
       Component: EU West V10  8048
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
       Part No SW: 1K0 959 701 AN    HW: 1K0 959 701 AN
       Component: Tuer-SG         008 2015
       Coding: 0004342
       VCID: 7AFBFCC73536C6F121F-802F
       Part No: 1K0 909 144 C
       Revision: 00H15000
       Shop #: WSC 01324 785 00200
       VCID: 2A5B0C878516B67111F-807F
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
       Part No SW: 1K0 959 702 AG    HW: 1K0 959 702 AG
       Component: Tuer-SG         008 2033
       Coding: 0004598
       VCID: 74E7D2FF1752B0817B3-8021
       Coding: 1446940
       VCID: 346712FF57D2F081BB3-8061
       Subsystem 1 - Part No: 7L6 941 329 B
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000022
       Subsystem 2 - Part No: 7L6 941 329 B
       Coding: 00000022
    Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
       Part No SW: 1K0 959 703 AL    HW: 1K0 959 703 AL
       Component: Tuer-SG         007 2009
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       Part No SW: 1K0 959 704 AL    HW: 1K0 959 704 AL
       Coding: 0000208
       Shop #: WSC 01357 011 1012551
       VCID: 7BF5F9C33A0CFFF93A9-802E
    00123 - Outside Warning Light/Door exit Light; Rear Right
    Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
       Part No SW: 3C8 035 730 C    HW: 3C8 035 730 C
       Component: Telefon       012 0822
       Revision: --------    Serial number: 35909603519167
       Coding: 020000010100010000000400
       ASAM Dataset: EV_UHVPremi A02705
       ROD: EV_UHVPremi_SE36.rod
       VCID: 2345E1A32A3C6739529-8076
    End-------------------------(Elapsed Time: 02:31)--------------------------
  2. Likes Andy, Santos, Dana, GaryM, golfhappy and 2 others liked this post
  3. #2
    Jun 2014
    Great!!! NASA awaits!
    If you connect pins 10 and 12 together you get a front side light error code, think the code was 02896, short to ground. This happens when you switch on the main beams. My Drls are set at 100% brightness and don't dim with the pins connected. It was documented in Bruno Prado write up that you had to bridge the pins to get the drls to work. We did this and i had the error code problem.
    Jan 2015
    Norway
    Did you fix this issue? Did you connect pin 10 or 12 from the car/cecm when you jumped 10-12 on the headlamp or did you short them together?
    I believe Pin 10 should go to CECM connector T52c pin 26 (left, grey/black)and T52a pin 44 (right, grey/red). Pin 12 should go to T52a pin 6 (left, blue/yellow) and T52a pin 28 (right, blue/green).
    However if your car dosent have rear fog light Pin 12 on right headlamp might be connected to T52c pin 47. Not sure why its done like that. What MY is your car anyway?
    52-pin connector -T52 A- black -A-
    6 - Left daytime running light bulb -L174-
    28 - Right daytime running light bulb -L175-
    44 - Right side light bulb -M3-
    47 - Left rear fog light bulb -L46- , left reversing light bulb -M16-
    52-pin connector -T52 C- brown-C-
    26 - Left side light bulb -M1-
    Jun 2014
    They were shorted together. Forum member from Golfgti.co.uk posted me his long helper code for the CECM and i've got new Kufatec harnesses to go in. Tried the harnesses without the AFS and it worked did throw an error bulb in the dash but VCDS didn't pick a code up. I asume it was the AFS not being connected that threw the bulb.
    Jan 2015
    Norway
    Shorting the output from the CECM is generally a bad idea I'd say, because if one of the outputs is enabled while the other one isnt. The one that is disable will then recieve a 12v signal and the CECM thinks theres a short to positive.
    Jun 2014
    Quote Originally Posted by somlioy View Post
    Sorry the car is a 2012 plate GTD. I suppose when the guy in Mexico did the retrofit that was the only way he could get his drls to work.
    Jan 2015
    Norway
    Alright I've done some testing with the AFS. It seems theres not much difference between the two codes I provided in the first post in terms of "aggressiveness".
  9. #8
    May 2015
    Hello guys,
    I've recently done this retrofit on RHD 2009 tdi Golf and I cannot make the DRL to turn on properly. Can you please help. I bought the adapters from Carsystem.pl and the plugs are wired as the above wiring diagram.
    Before BCM upgrade scan
    Wednesday,28,June,2017,12:19:16:25075
    VCDS Version: 17.1.3.0 (x64)
    VIN: WVWZZZ1KZAP013389   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZAP013389   Mileage: 154670km-96107miles
    37-Navigation -- Status: Not registered 0011
       Part No SW: 03L 906 022 LA    HW: 03L 906 022 G
       Component: R4 2.0l TDI G000SG  9978
       Revision: 13H02---    Serial number:
       Coding: 0001072
       Shop #: WSC 84224 544 534920
       VCID: 6FEDCD087EFCFF3900-803A
       Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
       Revision: 00H45001
       Coding: 163B400D092300FD680E02EC902200823400
       Shop #: WSC 00028 028 00001
       VCID: 7EF3E04CE99686B19B-802A
    02214 - Tire Pressure Warning
                        Reset counter: 7
                        Mileage: 154429 km
                        Date: 2011.11.07
                        Time: 01:00:09
                        Count: 32768
                        Count: 4608
                        Count: 397
                        Count: 50709
       Part No SW: 3C8 907 336 H    HW: 3C8 907 336 H
       Component: Climatic      H13 0203
       Revision: 00006001
       Coding: 0000000000
       Shop #: WSC 00028 028 00318
       ASAM Dataset: EV_Climatic A01001
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 326B047C654E92D12F-8066
       Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
       Component: BCM PQ35  M   103 0537
       Revision: 00103 AC
       Coding: 48180A3A9825F1C044080080140081E443510088536D8960648000200000
       VCID: 306F0E746342A0C159-8064
       Component: Wischer 26050  21  0501
       Coding: 009795
       Component: RLS 090609 05  54  0402
       Coding: 0330AD
       Subsystem 4 - Part No: 1K8 951 605
       Component: LIN BACKUP HO  H09 9002
                        Fault Status: 00101010
                        Fault Frequency: 46
                        Reset counter: 12
                        Mileage: 154385 km
                        Date: 2011.11.05
                        Time: 20:17:38
                        Voltage: 13.95 V
                            Term 50 Off
       Part No SW: 5K0 919 475 C    HW: 5K0 919 475
       Component: PARKHILFE 8K  H07 0008
       Revision: --------    Serial number: 12940915406240
       Coding: 100001
       VCID: 3663386C81268EF103-8062
       Component: AirbagVW10    033 0604
       Serial number: 003C2D0BB10A
       Coding: 00003230
       Shop #: WSC 00028 790 00306
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 77FDF568CEACB7F9D8-8022
       Serial number: 106E6447ZZZZZZZZZZZZ
       Serial number: 0B313048ZZZZZZZZZZZZ
       Serial number: 18502F4DZZZZZZZZZZZZ
       Serial number: 282E2D3DZZZZZZZZZZZZ
       Coding: 0000532
       VCID: 78FFF6540BB2B881D1-802C
       Subsystem 1 - Part No: 3C8 959 537 B  Labels: 3C8-959-537.CLB
       Coding: 00000226
       Part No SW: 5K0 920 970 J    HW: 5K0 920 970 J
       Component: KOMBI         H05 0206
       Coding: 470B00
       VCID: 35613F60942085E90A-8060
    Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
       Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
       Component: J533  Gateway   H07 0081
       Revision:   H07 01    Serial number: 040609F1002433
       Coding: E9A07F06000212000003
       VCID: 66C3A82C51063E7173-8032
                        Reset counter: 247
                        Mileage: 153982 km
                        Date: 2011.10.29
                        Time: 14:14:22
                        Mileage: 153982 km
                        Date: 2011.10.29
                        Time: 14:30:06
       Component: IMMO          H05 0206
       Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
       Component: SG EXT.PLAYER H13 0084
       Revision: A1001003    Serial number: 7667461881
       VCID: 2643E82C5186FE71B3-8072
       Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
       Component: RNS-MID       H50 2840
       Revision: AB001001    Serial number: VWZ6Z7L3080015
       Coding: 000002000200000000
       Shop #: WSC 05314 123 12345
       VCID: 2E53100C7976B6314B-807A
                        Reset counter: 244
                        Mileage: 153976 km
    00857 - CD Changer Unit (R41)
                        Reset counter: 244
                        Mileage: 153976 km
    01523 - Microphone for Telephone (R38)
                        Reset counter: 229
                        Mileage: 154483 km
                        Date: 2011.11.11
                        Time: 21:13:53
    00862 - Antenna for GPS Navigation (R50/R52)
                        Reset counter: 229
                        Mileage: 154483 km
                        Date: 2011.11.11
                        Time: 21:13:53
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.clb
       Part No SW: 5K0 959 701 E    HW: 5K0 959 701 E
       Component: Tuer-SG         009 2124
       Coding: 0004790
       VCID: 34670264575A9CE13D-8060
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 70     2901
       Revision: 00H15000
       VCID: 2F6D0D08BE7CBF3940-807A
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.clb
       Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
       Coding: 0005046
       VCID: 35613F605C2085E90A-8060
                        Reset counter: 244
                        Mileage: 153976 km
                        Reset counter: 244
                        Mileage: 153976 km
                        Reset counter: 229
                        Mileage: 154483 km
                        Date: 2011.11.11
                        Time: 21:13:53
                        Reset counter: 229
                        Mileage: 154483 km
                        Date: 2011.11.11
                        Time: 21:13:53
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
       Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
       Coding: 0000144
       Shop #: WSC 00028 028 1012545
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
       Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
       Coding: 0000144
    End-------------------------(Elapsed Time: 02:26)--------------------------
    After BCM upgrade and coding scan
    Friday,16,March,2018,22:14:22:22001
    VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
    Mileage: 160700km-99854mi   Repair Order:
    Chassis Type: 1K-VW36 (1K0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 55 56 62 72
    VIN: WVWZZZ1KZAP013389   Mileage: 160700km-99854miles
       Coding: 0001072
       VCID: 6FAE3FD97EC8FD3CF1-803A
       Revision: 00H45001
       VCID: 7EB0129DE9A284B46A-802A
       Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
       Component: AC Manuell    H19 0404
       Revision: 00001018
       Coding: 0000004003
       Shop #: WSC 00028 028 00025
       VCID: 004C6C659B56F24418-8054
              U1111 00 [009] - -
              [Motorsteuergerät - kein Signal/Kommunikation]
                        Reset counter: 176
                        Mileage: 160709 km
                        Date: 2018.03.16
                        Time: 21:04:50
       Part No SW: 5K0 937 087 R    HW: 5K0 937 087 R
       Component: BCM PQ35 H    021 0064
       Revision: BE021001
       Coding: 48180A3AF825F1C040880080950089EC43D50488536D8D60E48020040040
       Shop #: WSC 04941 123 12345
       VCID: 44C4A075C7CE2E647C-8010
       Coding: 009795
       Coding: 0730AD
    02896 - Control Circuit for LED Module for DRL and Parking Light; Left
                        Fault Status: 01101010
                        Reset counter: 176
                        Mileage: 160709 km
                        Date: 2012.08.06
                        Time: 22:13:13
                        Voltage: 13.80 V
    02898 - Control Circuit for LED Module for DRL and Parking Light; Right
                        Reset counter: 176
                        Mileage: 160709 km
                        Date: 2012.08.06
                        Time: 22:13:13
                        Voltage: 13.80 V
       Coding: 100001
       VCID: 3620CABD81128CF4F2-8062
       Coding: 00003230
       VCID: 77BE07B9CE98B5FC29-8022
       Coding: 0000532
       VCID: 78BC04850B86BA8420-802C
       Coding: 00000226
       Coding: 170900
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
       VCID: 3522CDB1941487ECFB-8060
       Coding: E9A17F06400212000003
       VCID: 66805AFD51323C7482-8032
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       VCID: 26001AFD51B2FC7442-8072
       Coding: 040004000200008100
       VCID: 2E10E2DD7942B434BA-807A
       Coding: 0004790
       VCID: 3424F0B5576E9EE4CC-8060
       Revision: 00H15000
       VCID: 2F2EFFD9BE48BD3CB1-807A
       Coding: 0005046
       VCID: 3522CDB15C1487ECFB-8060
       Coding: 1446940
       Shop #: WSC 33361 790 00052
       Coding: 00000022
       Coding: 00000022
       Coding: 0000144
       Coding: 0000144
    End----------(Elapsed Time: 01:32, VBatt start/end: 13.8V/13.7V)-----------
    The car has also LED taillights. I would be very grateful if you guys can point me in the right direction.
  10. #9
    May 2015
    hi guys,
    just to let you know that I have managed to sort it out with the setup I had. I've changed byte 18 to 4E VW Golf/Jetta Variant (VW362) and this made everything work less the outer rear taillights. To make them lit up I have amended the EEPROM in the BCM1 and now all works as it should.
