- Joined
- Jan 18, 2015
- Messages
- 22
- Reaction score
- 19
- Location
- USA
- VCDS Serial number
- C?ID=235721 (his son)
My name is David and me and my father both have VW and he recently decided to get vcds to have a little fun with our cars and to see if their were any problems. I own a 2005 vw MK4 jetta tdi 1.9L and upon hooking up vcds and doing an autoscan, it showed a few faults as shown here.
AutoScan
Their were a few things that caught my eye but the main question I have is what I should do about this camshaft fault code that is shown below.
Camshaft
Me and my father were driving around and looking at the solenoids in the tranny along with many other things and we came across this camshaft fault. We cleared the fault code and it immediately showed back up. What do you guys think?
AutoScan
Saturday,17,January,2015,22:11:23:31462
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: 3VWSR69M25M033882 License Plate:
Mileage: 244970km-152217mi Repair Order:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
75 76
VIN: 3VWSR69M25M033882 Mileage: 244970km-152217miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 038 997 016 R HW: 028 101 181 2
Component: R4 1,9L EDC G000AG 0282
Revision: 12345678 Serial number: VWZ7Z0D0331077
Coding: 0150034
Shop #: WSC 05232 444 85902
VCID: AD124E4B356B584974D-5184
19463 - Camshaft Position Sensor (G40)
P3007 - 000 - No Signal - Intermittent
RPM: 315 /min
Torque: 34.0 Nm
Voltage: 9.96 V
Bin. Bits: 00101111
Idle Stabilization: 0.0°KW
(no units): 32.0
16787 - EGR Valve (N18)
P0403 - 000 - Malfunction
Torque: 2.0 Nm
Duty Cycle: 0.0 %
Voltage: 11.32 V
Mass Air / Rev.: 0.0 mg/str
Duty Cycle: 101.2 %
Bin. Bits: 00000000
Address 02: Auto Trans Labels: 09A-927-750.lbl
Part No: 09A 927 750 BL
VCID: F6A0A127D0BD5B91C57-5184
00300 - Transmission Fluid Temp. Sensor (G93)
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019458
VCID: B4245B2FD64109813B3-5184
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 04 AIRBAG VW61 0202 0003
Coding: 12340
Shop #: WSC 00066
VCID: A71EBC63479772198E1-5160
00532 - Supply Voltage B+
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 906 R
Component: KOMBI+WEGFAHRSP VDO V57
Coding: 15234
VCID: BC34730FAE11C1C1F33-5160
3VWSR69M25M033882 VWZ7Z0D0331077
01304 - Radio
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00066
VCID: F0AC973FB2D975A11FB-5160
01304 - Radio
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 00066
VCID: B73E6C239737E2991E1-4B3C
Component: 1H Tõrsteuer.FS KLO 0202
Component: 1H Tõrsteuer.BF KLO 0202
Component: 1H Tõrsteuer.HL KLO 0202
Component: 1H Tõrsteuer.HR KLO 0202
54-00 - Incorrectly Equipped
00912 - Window Regulator Switch; Front Left (E40)
27-00 - Implausible Signal
End-------------------------(Elapsed Time: 07:44)--------------------------
Camshaft
Sunday,18,January,2015,17:53:52:31462
Mileage: Repair Order: CPS
Control Module Part Number: 038 997 016 R HW: 028 101 181 2
Component and/or Version: R4 1,9L EDC G000AG 0282
Software Coding: 0150034
Work Shop Code: WSC 05232 444 85902
RPM: 1890 /min
Torque: 34.0 Nm
Speed: 87.0 km/h
Load: 13.7 %
Voltage: 13.91 V
Bin. Bits: 00101000
(no units): 48.0
Readiness: 0 0 1 1 1
