Can anyone help me with eliminating the dash Light Malfunction Indicator. I installed LEDS in the front side parking lights (inside the high beam housing), license plate, and the reverse lights. The codes in VCDS are for the front side parking lights are 02394, 02395 and for the reverse lights are 01518, and 01519.
I have a 2012 Golf TDI
Central Electronics Component: BCM PQ35 M110 0651
Revision: 00110AC
Date: 13.09.11
All I have found from looking around it this:
_________________________________________________________________________________________________________________________________________________________________
LED Taillight Recoding Summary
Here is a summary of the information I've tracked down from various reputable sources (including my LED supplier), regarding the recoding required to remove the bulb-out warnings that are raised when regular tails are replaced with OEM LEDs.
In all cases, the byte to code is byte 18 of the Central Electrics module. Access it in VCDS via 09-Cent Electrics -> Coding 07 -> Long Coding Helper -> Byte 18.
Build date: Mid 2011+ (MY12)
Central Electrics Revision*: 0651
Headlights: Halogen (confirmed by Zircon):
- Coding (hex): 15
- Coding (binary): 00010101
What I would like to do is eliminate all the Light malfunction for the lights I have put in as well as future ones I put in such as the tail light bulbs, fog lights, etc.
New to VCDS but I am learning quick, please help!
Revision: 00110AC
Date: 13.09.11
- Coding (hex): 15
