Good evening peeps.
Here's the autoscan:
Just to give you some brief information.
This car started life as a PD115. The turbo failed and took out the engine. The owner has replaced the engine with an ARL and fully rebuilt it. He's also placed a bigger hybrid turbo on, intercooler etc.
He bought a second hand ECU from an online auction website that was plug and play, apparently!
Anyway, he's come to us for some tuning to be done but we only had time to do a full scan and a quick run to check fueling/boost etc. Now after clearing the other codes, these 3 were the only ones left and concern me slightly.
Question is, is it just the coding that needs sorting or is there an underlying fault with the plug & play ECU he's bought?
Any help/guidance will be much appreciated.
Thanks ahead.
Monday,12,January,2015,11:03:29:16548
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
Dealer/Shop Name: GHE Tuning
VIN: License Plate: V965EJT
Mileage: 183570km-114065mi Repair Order:
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
76
Mileage: 183570km-114065miles
Address 01: Engine Labels: 038-906-019-ARL.lbl
Part No: 038 906 019 FE
Component: 1,9l R4 EDC 0000SG 1468
Coding: 00002
Shop #: WSC 13765
VCID: 5FC6BD00DD7D38D9361-4ACE
18020 - Engine Control Module Incorrectly Coded
P1612 - 35-00 -
16989 - Internal Control Module
P0605 - 35-00 - ROM Error
17932 - Fuel Pump Relay (J17)
P1524 - 35-10 - Open or Short to Ground - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 R
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 00028
VCID: 40845E7C40C367212FB-4AE6
Part No: 6Q0 909 605 A
Component: 02 AIRBAG VW5 0003
Coding: 12338
Shop #: WSC 00028
VCID: 356A3FA80F01D2898CD-4AE6
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 922 C
Component: A4-KOMBIINSTR. VDO V22
Coding: 05444
Shop #: WSC 00001
VCID: 2648E8E4C2A7A911357-5102
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0X2095207
IMMO-IDENTNR: VWZ7Z0X2095207
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00028
VCID: 70E4CEBC30E3B7A19FB-5102
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 4V Zentral-SG Komf. 0001
Coding: 00256
Shop #: WSC 00028
VCID: 040C926C145BBB014B3-4AE6
Subsystem 1 - Part No: 1J2959802C
Component: 4V Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J2959801D
Component: 4V Tõrsteuerger. BF0002r
No Faults Found
End-------------------------(Elapsed Time: 05:38)--------------------------
Thanks ahead.
