Hi All,
With the help from NEtech, I managed to config all necessary modules after retrofitting a Westfaila system trailer hitch. Thanks to NEtech.
However the first time when I hooked up a trailer, there were trailer right & left rear light warning on the dash. Fault code 00335 registered with Trailer Control Module (J345/#69) fault 00335 - Control Circuit Taillights
Is the coding: 0300000000000000 correct?
Many thanks in advance,
Tony
Tony
Tuesday,06,January,2015,17:31:59:50635
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: WAUZZZ4FX8N0xxxxx License Plate:
Mileage: 72300km-44925mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 34 37 42 46 47 4F 52
53 55 56 61 62 67 69 6C 72 76 77
VIN: WAUZZZ4FX8N062131 Mileage: 72300km-44925miles
67-Voice Control -- Status: Cannot be reached 1100
Part No SW: 4F9 910 401 L HW: 4F0 907 401 C
Component: 3.0L V6TDI G000AG 0020
Revision: --H05--- Serial number:
Coding: 0011372
Shop #: WSC 02334 758 00200
VCID: 2E5920EEB9D28E51CD7-807B
005663 - Glowplug for Cylinder 6 (Q15)
P161F - 001 - Open Circuit
Fault Status: 01110001
Mileage: 72195 km
Date: 2015.01.04
Time: 09:39:32
RPM: 882 /min
Torque: 124.8 Nm
Duty Cycle: 1.0 %
Voltage: 13.68 V
Duty Cycle: 24.1 %
Temperature: 25.2∞C
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F5 910 156 C HW: 09L 927 156 C
Component: AG6 09L 3,0 TDI RdW 0020
Revision: --H04--- Serial number: 4378581
Shop #: WSC 02325 758 00200
VCID: 2855D6F69B36D06107B-807D
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AB HW: 4F0 614 517 R
Component: ESP 8.0 quattro H05 0040
Coding: 0000392
VCID: 64CD82C6A79E7401EB3-8031
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601500899793
Coding: 0000147
Shop #: WSC 02323 758 00200
VCID: 63CF81DAA2907339129-8036
Subsystem 1 - Part No: 4F0 910 131 A
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 732 B HW: 4E0 035 729 A
Component: Interfacebox H43 4220
Revision: 00000000 Serial number: 351J$077552688
Coding: 0003002
Shop #: WSC 02335 785 00200
VCID: 2241C4DEFD0A3A3159F-8077
Subsystem 2 - Serial number: 00000001438112
Subsystem 3 - Serial number: 0105.11.090000000100010101ˇ
Subsystem 4 - Serial number: 010101ˇ
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 A HW: 4F2 820 043 Q
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000030290851
Coding: 0001366
VCID: 1C3DFA26DF6E0CC1933-8049
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
Fault Status: 00101010
Reset counter: 143
Mileage: 72208 km
Date: 2015.01.04
Time: 11:47:14
Voltage: 13.60 V
(no units): 210.0
(no units): 255.0
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H18 0250
Coding: 0003121
VCID: 31633B92A8EC91A9D05-8064
Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0190
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
VCID: 2757D5CA5628DF190E1-8072
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4F AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0UADBM
Coding: 0013382
VCID: 2953D3F2803CE969185-807C
Subsystem 1 - Serial number: 6332CSME2823047F2
Subsystem 2 - Serial number: 6342CSME2973601D3
Subsystem 3 - Serial number: 6352QSME3D2E4C2F%
Subsystem 4 - Serial number: 6362QSME3C530D63N
Subsystem 5 - Serial number: 63734SME41682C191
Subsystem 6 - Serial number: 63834SME3D314001R
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90025072630567
Coding: 0102142
VCID: 2757D5CA9628DF190E1-8072
Component: E0221 H02 0030
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 933 J
Component: KOMBIINSTR. M73 H21 0240
Revision: 00700000 Serial number: 6XX13Y0A7
Coding: 7273758
Shop #: WSC 31250 822 00001
VCID: 234FC1DAE2103339529-8076
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B0792584EC
Coding: F751DE7F70720600
VCID: 2D5B27E2B4D4F549F4D-8078
01301 - Control Module for Voice Recognition (J507)
Reset counter: 102
Mileage: 72166 km
Date: 2015.01.03
Time: 16:46:00
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H46 0350
Revision: 00046006 Serial number: AUZ5ZBG3488469
VCID: 1835E6362B5660E1B7B-804D
Address 34: Level Control Labels: None
Part No SW: 4F0 910 553 A HW: 4F0 907 553 A
Component: J197 LUFTFEDER H17 0060
Serial number: 00619003920500
Coding: 0000220
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H50 1060
Revision: 00000000 Serial number: 364J.077721666
Shop #: WSC 03002 959 06940
VCID: 3B7F19BA7AA06BF97A9-806E
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 F HW: 4F0 959 793 F
Component: TSG FA H21 0210
Coding: 0001562
Shop #: WSC 02327 758 00200
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H26 0210
Revision: 02100026 Serial number: 01070434870000
Coding: 0394121
01699 - Motor for Central Locking; Hatch/Trunk (V53)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 105
Mileage: 63685 km
Date: 2014.09.01
Time: 16:55:05
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000065830
Coding: 0000123
Shop #: WSC 50620 822 999999
VCID: 254BDFC2EC24CD093CD-8070
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000076857
Coding: 0001013
VCID: 5EB9B02E89F25ED13D7-800B
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 792 F HW: 4F0 959 792 F
Component: TSG BF H21 0210
Coding: 0001562
VCID: 2C5D2AE68FCEFC41E33-8079
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000321
Shop #: WSC 02324 758 00200
VCID: 2045CED6F30628214FB-8075
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000017
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Revision: 00000000 Serial number: 304AA037512408
Shop #: WSC 02312 785 00200
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000021398
VCID: 244DC2C6E71E34012B3-8071
Component: von VA0 320410A08B
Coding: 344630393135313035442056413033323034313041303842
Shop #: WSC 55163 000 1048576
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 F HW: 4F0 959 795 F
Component: TSG HL H21 0210
Coding: 0001026
VCID: 2F673DEABED88759C61-807A
Address 67: Voice Control
Address 69: Trailer (J345) Labels: 4F0-907-383.clb
Part No SW: 4F0 907 383 D HW: 4F0 907 383 D
Component: Anhaenger H10 0080
Revision: 2B001001 Serial number: 00000325428571
Coding: 0300000000000000
VCID: 2C5D2AE64FCEFC41E33-8079
Fault Status: 11101010
Reset counter: 103
Mileage: 72208 km
Date: 2015.01.04
Time: 11:44:00
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J7930AA
Coding: 1030305
Shop #: WSC 02335 758 00200
VCID: 1E39F02EC9721ED17D7-804B
03006 - Back-up Camera System not calibrated
Reset counter: 102
Invalid
Invalid
Invalid
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 F HW: 4F0 959 794 F
Component: TSG HR H21 0210
Coding: 0001026
Part No SW: 4F0 910 283 H HW: 4F0 919 283 H
Component: Parkhilfe 8-Kan H12 0080
Revision: 00H12000 Serial number: 06340726801378
Coding: 0231416
Shop #: WSC 131071 102 209715
Part No SW: 4E0 910 336 K HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005035159
Coding: 0010900
VCID: 2A512CFE853AE27111F-807F
End-------------------------(Elapsed Time: 03:15)--------------------------
