Faults
Excoastie
Bossier City, LA
C?ID=232376
Good afternoon everyone:
I noticed when I did my auto scan the other day that it had a few faults in it. Could these faults be a direct result of the car not running (but ignition was on) and the radio was turned off?
I haven't noticed any issues, that is to say that everything appears to be functioning properly.
Monday,29,December,2014,12:42:27:50069
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: 3VW5S7AJ3EM389444   License Plate:
Mileage: 12810km-7959mi   Repair Order:
Chassis Type: AJ (7N0)
Scan: 01 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 4F 52 55
          56 62 72 75 77
VIN: 3VW5S7AJ3EM389444   Mileage: 12810km-7959miles
Address 01: Engine (J623-CPLA)       Labels: None
   Part No SW: 06K 906 070 T    HW: 06K 907 425
   Component: Simos12.2     H09 6110
   Revision: --H09---    Serial number: 00000000000000
   Coding: 00190012242400161000
   Shop #: WSC 00066 000 00201
   ASAM Dataset: EV_ECM20TFS02006K906070T 001005
   ROD: EV_ECM20TFS02006K906070AA.rod
   VCID: 3B5BDB15B2A635F97A9-806E
15304 - Engine Off Timer Performance
          P150A 00 [032] - -
   Revision: 00H31001
   Coding: A14B600C492A0003850F06E8921D0041B61800
   Shop #: WSC 00066 123 12345
   VCID: 7DDF150DE432FBC904D-8028
02214 - Tire Pressure Warning
                    Fault Frequency: 17
                    Reset counter: 83
                    Mileage: 5470 km
                    Date: 2014.06.01
                    Time: 10:03:33
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 50690
                    Count: 1
                    Count: 512
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Component: VWKESSYPQ35GP 086 1101
   Revision: 00086000    Serial number: 0194130020
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_AU21.rod
   VCID: 3449F0299FF8FA81BB3-8061
   Part No SW: 3AA 907 044 BH    HW: 3AA 907 044 BH
   Component: Climatronic   H03 0404
   Revision: 00001K01
   Coding: 0010019002
   Shop #: WSC 00066 000 00122
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 77D30725CE0ED1995E1-8022
   Part No SW: 5K0 937 086 R    HW: 5K0 937 086 R
   Component: BCM PQ35 M    122 0173
   Revision: BJ122001
   Coding: EF200A3A902F06C40188008100000DCC0104000854808DB0E4842000A040
   VCID: 43ABA3F5C2564D39329-8016
            000 -  -  - Intermittent
                    Reset counter: 58
                    Mileage: 12258 km
                    Date: 2014.12.12
                    Time: 01:16:28
                        Term 15 Off
                    Voltage: 12.40 V
   Part No SW: 5C0 959 655 AD    HW: 5C0 959 655 AD
   Component: AirbagVW10    102 0912
   Serial number: 003MVD01RK4Z
   Coding: 00004139
   VCID: 74C93029DF78BA817B3-8021
   Serial number: 6940000Y130000Z1MS0E
   Coding: 303041
   Serial number: 3572MSME0458637DZZZ$
   Serial number: 3582MSME7E60637DZZZ7
   Serial number: 3516KSME4E0B4328ZZZZ
   Serial number: 3526KSME411D4328ZZZQ
   Serial number: 3556LSME3E095A28ZZZ2
   Serial number: 3566LSME24385728ZZZY
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010042    Serial number: 20130825300167
   Coding: 0002140000
   Shop #: WSC 00066 123 00201
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DDF150DEC32FBC904D-8028
   Component: E221__MFL-TAS  H31 0037
   Coding: 820000
   Part No SW: 5C6 920 973 B    HW: 5C6 920 973 B
   Component: KOMBI         H04 0811
   Coding: 271E01
   Shop #: WSC 00066 000 00195
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 2E7DE24171D4D051CD7-807B
   Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1642
   Revision:   H55       Serial number: 18101303000369
   Coding: 351002
   VCID: 7BDB1B15FA26F5F93A9-802E
   Component: IMMO          H04 0811
   Coding: 000007
   VCID: 6AF52E518DBC7C71D1F-803F
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Revision: 00000000    Serial number: 13000199189002
   Coding: 4100000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3041FC396BE0C6A1DFB-8065
Address 2E: Media Player 3
   Part No SW: 1K0 035 274 F    HW: 1K0 035 274 F
   Component: RNS315-NAR    H73 0409
   Serial number: VWZAZ2N0520214
   Coding: 040900610100060000008000
   Shop #: WSC 01383 790 50316
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 277317655E2E81190E1-8072
   Component: NAR_V4  0041
   Revision: 13110009    Serial number: 0007480192
   Coding: 0004B5
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 5B9B7B9552E615F95A9-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1508
   Serial number: 00000008188920
   Coding: 000490
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 70     3501
   Revision: 00H22000
   VCID: 3957C11D709A07E9685-806C
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K H07 6813
   Revision: --------    Serial number: EAA098A0086895
   VCID: 266D1A6159249811357-8073
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
   Component: EZE_2         H55 1642
   Coding: 01030100
   VCID: 6FC33F45BE5E9959861-803A
   Subsystem 1 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H10 0007
   Coding: 180000
   Revision: 15110009    Serial number: 0007402613
   Coding: 0004B4
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 5C99788957E812C1533-8009
   Slave Passenger:
   Component: J389__TSG-HR  009 1508
   Serial number: 00000008219089
   Coding: 000490
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Component: AFS-ECU       H04 0111
   Coding: 081200010B000200
   Shop #: WSC 00066 790 00208
   ROD: EV_HeadlRegulVWAFSPt.rod
   VCID: 3753C7258E8E11999E1-8062
   Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329
   Component: LeiMo links  H02 0010
   Coding: 860000
   Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329
   Component: LeiMo rechts  H02 0010
   Coding: 860000
Address 75: Telematics (J949)       Labels: None
   Part No SW: 561 035 285     HW: 561 035 285
   Component: OCULowUSA     014 0086
   Serial number: 000003554140507
   Coding: 02630102C2423A107F1606000000
   ROD: EV_OCULow_SE12.rod
   VCID: 538B93B53A36DDB9829-8006
12670464 - Databus
                    Fault Frequency: 20
                    Reset counter: 71
                    Mileage: 7644 km
                    Date: 2014.07.29
                    Time: 15:25:31
0035 - Databus
                    Fault Frequency: 74
                    Reset counter: 77
                    Mileage: 457 km
                    Date: 2014.01.10
                    Time: 03:30:29
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 43
                    Time: 00:00:00
Address 77: Telephone (J412)       Labels: None
   Component: TELEFON       H05 0315
   Revision: 1B001001    Serial number: 00007665190665
   Coding: 0A100300A0010110
   ROD: EV_UHVUMI.rod
End-------------------------(Elapsed Time: 02:51)--------------------------
thanks
Exco
Mari
C?ID=150535
... erase the faults and check later (after a drive) which of them come back... the ones that come back you have to investigate!
Some of the faults are there for a very long time (check mileage that is noted).
Excoastie
Bossier City, LA
C?ID=232376
OK. thanks for the help Mari. I was out of town, but now that I'm back in town I'll hook everything up and see about clearing the faults.
After I go for a spin I will do another auto scan and see what I come up with.
Will doing the scan with the car not running (with ignition on) and the radio turned off through anything off? or does it even matter?
thanks again
Exco
I don't see a problem with VCDS here, so moved to Car Repair.
