Audi q7 HEX-USB+CAN issues
madreg98
C?ID=200265
I scanned a 2007 Audi Q7. In auto mode it kept saying I was using an unlicensed version and would only scan address 1 and 2. Then I would get the error message. My software is licensed and I use it on my 2005 VW Phaeton. I was able to read each address manually and clear the faults but could not run in auto mode. Typical scan is shown.
Monday,29,December,2014,19:38:24:39310
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: WA1AV74L37D010568   License Plate:
Mileage: 155640km-96710mi   Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 28 36 37 42 46 47 4F
          52 55 56 61 62 65 6D 6F 72 77
VIN: WA1AV74L37D010568   Mileage: 155640km-96710miles
47-Sound System -- Status: Sporadic communication error 1000
   Part No SW: 4L0 910 560 C    HW: 4L0 907 560 A
   Component: 4.2l V8/4V          0060
   Revision: --H16---    Serial number:
   Coding: 01210009190F0160
   Shop #: WSC 08251 444 83875
   VCID: 285F00C09B6A956107B-807D
008583 - Bank 1; System too Lean at Idle
               P2187 - 004 -  - MIL ON
                    Fault Status: 11100100
                    Mileage: 155450 km
                    Date: 2006.01.08
                    Time: 13:21:41
                    RPM: 708 /min
                    Load: 28.6 %
                    Temperature: 100.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.097 V
008585 - Unlicensed Version. Not all DTCs
               P2189 - 004 -  - MIL ON
                    Mileage: 155553 km
                    Date: 2006.01.08
                    Time: 17:13:11
                    RPM: 760 /min
                    Load: 14.5 %
                    Temperature: 26.0°C
                    Voltage: 14.224 V
   Part No SW: 09D 927 750 BR    HW: 09D 927 750 BR
   Component: AL 750 6A           0915
   Revision: 00H49000    Serial number:
   Coding: 0000504
   Shop #: WSC 31414 790 00001
   VCID: 7F0DFB9C2E64F2D9161-802A
Address 01: DTCs cleared
Address 07: DTCs cleared
Address 09: DTCs cleared
Address 19: DTCs cleared
Address 28: DTCs cleared
Address 37: DTCs cleared
Address 6F: DTCs cleared
Is there an issue with this version of the software or do I have to reload.
Dennis
I'm confused. I don't see any HEX-NET in our records for you, nor does that scan appear to have been made with a HEX-NET.
What kind of computer are you using this on?
madreg98
C?ID=200265
Oops. My mistake. I meant to say using a HEX+CAN cable. Sorry for my confusion.
OK, I've edited the thread title.
Now please tell us what kind of computer you are using this on. Make, model, CPU, RAM, version of Windows, and what location you have VCDS installed in.
madreg98
C?ID=200265
Software installed on C:\Ross-Tech\VCDS\ on a Dell Latitude D630, Intel T7250, 4Gb running Windows XP SP3. Again, software works fine in auto mode for my VW Phaeton. A second issue is I could not get the OBD mode to work when trying to scan a 2009 MB ML350. It just hung up.
Scratching my head. Computer sounds reasonable. Do you have easy/regular access to either of these vehicles?
madreg98
C?ID=200265
MB in garage. Q7 is currently at the dealer with a bad belt pulley and a vacuum leak. It has an extended warrantee.
OK, connect computer to MB, go to [Options], set Debug Level to 1024, and click [Apply]. Then try to connect to it using generic [OBD-II]. After it fails, look in the Debug sub-folder (typically C:\Ross-Tech\VCDS\Debug\) for a file named DEBUG-OBD.DLM and send it to Support@.... Please include a link to this thread in your e-mail.
DV52
C?ID=194404
Uwe: My question is related to your suggestion albeit it's a little off-topic. But if you will allow a minor diversion, I will ask it: I've read your suggestion above on a couple of occasions now and I'm intrigued! Without wanting to pry into secret RT stuff, can you explain what debug 1024 does - please!
It records the raw data being exchanged between the car and VCDS.
madreg98
C?ID=200265
Am now getting same error with auto mode on VW Phaeton that worked perfectly earlier. Did not use obd-ii. Am sending debug file. If you specifically need obd file I can rerun.
madreg98
C?ID=200265
Did you get the debug file??
Yes, but the guy who needs to look at that has been a bit preoccupied with other issues.
