Monday,24,November,2014,18:16:57:26785
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: WUAZZZ8E96N901688 License Plate: 201
Mileage: 43550km-27060mi Repair Order:
67 69 75 76 77
VIN: WUAZZZ8E96N901688 Mileage: 43550km-27060miles
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0080
Revision: --H09--- Serial number: XXXXXXXXXXXXXX
Coding: 01040003180F0160
Shop #: WSC 60909 124 07124
VCID: 63C58070A23D1939129-8036
Readiness: 0000 1000
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Coding: 0004533
Shop #: WSC 06335 000 00000
VCID: 2B5528508A6D9179EA9-807E
Address 08: Auto HVAC Labels:
Part No: 8E0 820 043 BL
VCID: 6CD7EB4C1CE35641A33-5104
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0704
Coding: 01041
VCID: 3B751810290D01F97A9-4AE4
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H12 3730
Revision: 91H12373 Serial number: 0036M00BCV10
Coding: 0430712
VCID: 3B7518107A0D01F97A9-806E
Subsystem 1 - Serial number: 6332DRB40300CB26H
Subsystem 2 - Serial number: 6342DRB4031204A04
Subsystem 3 - Serial number: 6352ARB4010E3E74P
Subsystem 4 - Serial number: 6362ARB4010C07227
Subsystem 5 - Serial number: 63729RB4010607C5E
Subsystem 6 - Serial number: 63829RB40106081CC
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0201
Coding: 16021
Shop #: WSC 00010
VCID: 448763EC54F37E010B3-4AE4
35-00 - -
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 G HW: 8E0 920 931 G
Component: KOMBI+WFS 4 H14 0030
Revision: 0030 Serial number: 00000000000000
Coding: 0007101
Shop #: WSC 00001 777 104166
VCID: 2C572B4C8C639641E33-5122
Address 25: Immobilizer Labels:
VCID: 55A1AEA8BF69F7896CD-5122
Address 36: Seat Mem. Drvr Labels:
Part No: 8E0 959 760 A
VCID: 326B3534FE47C0B1A9F-4AE4
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 D HW: 8E0 035 192 D
Component: RNS-E HIGH EU H72 0650
Revision: 04S Serial number: AUZBZ7F1142075
Coding: 0131715
Shop #: WSC 75736 146 52284
VCID: 2541DE68EF89A7093CD-515C
Reset counter: 188
Date: 2014.11.24
Time: 17:56:16
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
VCID: 6BD5E85019ED5179AA9-5140
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4035
Coding: 06858
Shop #: WSC 06335
VCID: 79F9C21863B1F3E9285-4AFE
Subsystem 1 - Part No: 8E2959802F
Component: Tõrsteuer.FS BRM 0606
Subsystem 2 - Part No: 8E2959801F
Component: Tõrsteuer.BF BRM 0606
Component: Tõrsteuer.HL BRM 0606
Component: Tõrsteuer.HR BRM 0606
01616 - Signal Wire to Interior Monitor
Address 55: Headlight Range Labels:
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Coding: 0000019
VCID: 285FD75C9B9BBA6107B-807D
Subsystem 1 - Part No: 8E0 941 329
Component: AFS-Modul links H03 0020
Subsystem 2 - Part No: 8E0 941 329
Component: AFS-Modul rechtsH03 0020
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0131715
VCID: 2541DE68EF89A7093CD-517A
Reset counter: 188
Date: 2014.11.24
Time: 17:56:16
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 HW: 8E0 907 273
Component: Reifendruck 3 H04 0110
Coding: 0102525
Shop #: WSC 00010 777 63489
VCID: 69D9925843114369D85-5140
Fault Status: 11100100
Reset counter: 40
(no units): 75.0
Voltage: 13.60 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
02214 - Tire Pressure Warning
Fault Frequency: 10
Reset counter: 40
(no units): 0.0
Temperature: 40.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 E HW: 8E0 919 283 E
Component: Parkhilfe 8-Kan H06 0010
Revision: 00H06000 Serial number: 00067802120606
Coding: 0000104
VCID: 326B3534AE47C0B1A9F-5122
Part No SW: 8P0 862 335 M HW: 8P0 862 335 M
Component: FSE_255x BT H21 0200
Revision: 00000001 Serial number: 00000000418602
Coding: 0011722
VCID: 408F6FFC10EB62212FB-5122
End-------------------------(Elapsed Time: 07:20)--------------------------
Hi All,
Jef here from little ole Brunei, posting for the first time, and just gotten my Dongle.
Having recently got this 2006 RS4 B7, found none of the four buttons on the Euro Flat bottom Sports steering Wheel working.
Previous owner claims that the Steering was a MFSW before, and that the car was retrofitted with the Euro Flat Button Sports steering.
The S mode would be selected via the S button on the Dash.
The Multi Function Display, controlled via the Right Control Stalk.
The buttons on the wheel was lit, but non functional, which led me to check out the coding.
Original Coding was found to be 14441.
(Autoscans revealed no faults, apart for Tire Pressure, as the wheels were changed to after markets)
I Proceeded to changing to 16041. All Steering Buttons now works.
When I used 16021, all buttons also works.
Reason for varying 16021 to 16041 was to see variation in messages which I gooten after Autoscanning with the new codes.
No changes in messages was noted.
I have also tried 06021, as I noted that on my option codes in the owners manual, this car had 7QO (Without Navigation Device)
as denoted on the sticker. But gotten same results.
(Car is fitted with RNS-E High.)
However, on running Auto Scan, I got the messages,
35-00 - -
and implausible signal from Steering, Navi, and Radio.
( I have no idea whether 46 Convenience message is involved, as it seems intermittent that. )
Not Sure if applicable, so Im including the options sticker for this car aswell below
E0A = No special edition
7A0 = Without CD changer/CD player
4UE = Air bag for driver and front seat passenger
6XD = Exterior mirrors: electrically adjustable/heated
5SJ = Left exterior mirror: convex
6TS = Right exterior mirror: aspherical, large viewing field
1KY = Disc brakes, rear
J0Z = Battery 520 A (110 Ah)
1LP = Disc brakes, front
2MC = Sports suspension with variable shock absorption
3FA = Without roof insert (standard roof)
5MN = Decorative inserts
7X2 = Park distance control, front and rear
4R4 = Power windows with comfort operation and circuit breaker
F0A = No special purpose vehicle, standard equipment
8GH = Alternator 190 A
0G1 = Gearshift lever
0YK = Weight range 10 installation control only, no requirement forecast
0JK = Weight category front axle weight range 10
TK7 = 8-cylinder gasoline engine 4.2 L unit 079.D (aluminum)
3NZ = Rear seat bench unsplit, backrest split folding
8EC = Bi-functional headlight with gas discharge lamp, for driving on the left
U1A = Instrument insert with km/h speedometer, clock, tachometer and trip odometer
X8K = National sales program Singapore
1N3 = Speed-related variable steering assist (Servotronic)
2FS = Leather trimmed multi-function sports steering wheel
8Q5 = Headlight-range adjustment, automatic / dynamic with dynamic bending light (AFS 1)
9Q4 = Multi-function display/on-board computer with check control
8Z5 = Not hot country
D0W = 8-cylinder SI engine 4.2 l/309 kW (32V) FSI, homogeneous base engine is TK7
7Q0 = Without navigation device
C5K = Alloy wheels 9J x 19
7K8 = Tire pressure control, frequency 315 MHz basic level version
6C1 = Side air bag rear, with curtain air bag
VJ3 = Reinforced bumpers
3L3 = Manual height adjustment for front seats
4KC = Side and rear windows in heat-insulating glass
3Y0 = Without roll-up sun screen
4K4 = Radio remote controlled central locking
5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
1SA = Without additional front underbody guard
0GG = Emission standard EU4
Q4P = Sports front seats
4GH = Windshield in heat-insulating glass with sunshield
Would appreciate any guidance here guys.
Im particularly new to this VCDS, but believe I have noted the procedures.
I carried out the coding with Ignition on, as well as with engine running as well.
Hopefully you guys are better at defining the Report better than I am.
Cheers
