2013 Golf 7 coding problem
bloggo
Birmingham UK
C?ID=198143
Could you please assist with a problem I have with settings on the new Golf 7, whereas I am trying to activate the “Closing the windows in the rain” option?
I have set the adaptation coding for channels 15 active-16 permanent-28 active. As this did not work I tried to alter “RLS_Close_Glazing” in the adaptation to active, but this produced “ERROR: Channel Not Available”. I then tried to change the setting in the Long Coding of module 5Q0 937 084Q” sub module “5Q0-955-547” by setting bit 2 in byte 0 “Rain Closing Active” and again this produced an error: “Coding rejected Error 31: Request out of range”.
The attempt was made with only the ignition on and also with the engine running.
This is my autoscan:
Saturday,15,March,2014,11:05:15:11201
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WVWZZZAUZDP079089   License Plate:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
Address 01: Engine (J623-CPTA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 AD    HW: 04E 907 309 G
   Component: 1.4l R4 TSI   H02 5532
   Revision: WKH02---
   Coding: 01250032236405082000
   Shop #: WSC 00028 028 00080
   ASAM Dataset: EV_ECM14TFS01104E906016AD 002006
   ROD: EV_ECM14TFS01104E906016AD.rod
   VCID: 64C759686F707E3E1FF-8031
   Part No SW: 0CW 300 045 D    HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 3902
   Revision: 00043014    Serial number: CU501303187173
   Shop #: WSC 00028 028 00310
   ROD: EV_TCMDQ200021_AU37.rod
   VCID: 3A7BC710BD7458CE953-806F
   Part No SW: 5Q0 907 379 Q    HW: 5Q0 907 379 E
   Component: ESC           H75 0534
   Coding: 01FA8AA1202712750377060801CC2980510448C0608094F3F82A502AC1
   VCID: 4A9B97D0ED94C84E053-801F
   Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
   Component: Climatronic   H02 0503
   Revision: 00001K06
   Coding: 00120004200100011005000000101000
   ROD: EV_ACClimaBHBVW37X_SE37.rod
   VCID: 3663D320896CBCAE71B-8063
263426 - Air Quality Sensor
          B10AF 31 [008] - No Signal
                    Reset counter: 12
                    Mileage: 4676 km
                    Date: 2014.02.25
                    Time: 07:41:01
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011308601425
   Coding: 03001846C24102FB0FA44080B11C0728100A000000000000000000000000
   ROD: EV_BCMBOSCH_SE37.rod
   VCID: 4683A3E0F98C2C2EE1B-8013
   Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A
   Component: WWS    130317  042 0551
   Serial number:         130319080559
   Coding: 0E4DD5
   Component: RLFS  024 0042
   Serial number: Y13M04D09H13M01S36S1
   Coding: 00A8DD
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY130520P6C
   Serial number: 00000000000056508464
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
   Component: PARKHILFE PLA H11 0029
   Revision: --------    Serial number: 61131308700820
   Coding: 0131161051
   Shop #: WSC 00017 666 00908
   ASAM Dataset: EV_EPHVA2CAU3700000 003014
   ROD: EV_EPHVA2CAU3700000_VW37.rod
   VCID: 3D71CC0CAC5A6FF6B01-8068
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 G    HW: 5Q0 907 567 G
   Component: ACC3          H08 0390
   Serial number: 04041375030254
   Coding: 001E1300FE0309
   ASAM Dataset: EV_ACCBoschMQB 001021
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 3F8DB604A6567DE6A2D-806A
   Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
   Serial number: 003M1R02DGFD
   Coding: 98FCC0C0000000005C5400CF00C800000065
   Shop #: WSC 00028 028 00057
   Seat belt tensioner; left:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169677A04041350661
   Coding: 333135
   Seat belt tensioner; right:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169676A04041340700
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 803 13
   Serial number: 35767000000BB8B0AC05
   Subsystem 4 - Part No SW: -----------    HW: 480 002 803 13
   Serial number: 35867000000187BCDC07
   Subsystem 5 - Part No SW: -----------    HW: 480 400 304 13
   Serial number: 35165029B0FAE8A462D
   Subsystem 6 - Part No SW: -----------    HW: 480 400 304 13
   Serial number: 3526502BF0FEA210C0DU
   Subsystem 7 - Part No SW: -----------    HW: 480 402 003 13
   Serial number: 3556502B70FAE8A1223N
   Part No SW: 5Q0 953 507 AG    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 12031308490737
   Coding: 0D00
   Shop #: WSC 40195 333 37120
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 7BF50214F2CEA1C6CE5-802E
   Part No SW: 5G0 920 970     HW: 5G0 920 970
   Component: KOMBI         336 0580
   Coding: 27A401082790260001886A01040000
   VCID: E7DDCE641E469526BAD-80B2
   Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1109
   Revision: --------    Serial number: 0000484847
   Coding: 030100042B086400EF00065C1C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_AU37.rod
   VCID: 3467E9289F10AEBE4FF-8061
   Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K
   Component: E221__MFL-DC1  H13 0035
   Serial number: 23130000275380040291
   Coding: 2DFFFF
   Serial number: 6877660103
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Component: TSG FS        007 0006
   Serial number: 0000056235917
   Coding: 003B0220D001028000001000
   Shop #: WSC 00028 028 00074
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 020B7FF09524D00E8D3-8057
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
   Serial number: 00000000000001117534
   Coding: 0D0000
   Coding: 83
   ROD: EV_SteerAssisMQB.rod
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000056849937
   Coding: 003B0020DE01028000801000
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 010970FC9022CB16949-8054
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
   Serial number: 00000000000001128000
   Coding: 050000
   Part No SW: 5G0 035 858     HW: 5G0 035 858
   Component: MU-S-ND-ER    039 0170
   Serial number: V5F00704130548
   Coding: 02730001FF00000021111201002800001F0100160100010045
   ASAM Dataset: EV_MUStd4CPASE 002036
   ROD: EV_MUStd4CPASE_SE37.rod
   VCID: E9D9C85C0852A356AC9-80BC
   Media Player Position 1:
   Component: ABT_Std_Nav  H44 0020
   Serial number: VWZ8Z9N3401HQ1
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 5G0 919 866 D    HW: -----------
   Component:  ECE 2013  --- 0021
Your help would be appreciated.
Thank you
Bill.
bloggo
Birmingham UK
C?ID=198143
Does anyone know if this error 31 is caused by an incorrect security code (31347); if so what is the correct code.
Thanks.
Andy
Sector 7G
HC424490
We've gotten other reports of that and one of my colleagues is checking into this exact issue today so watch this space for updates. :) No guarantees but we're going to try to see what's going on when you use the factory tools to do it compared to using VCDS. It appears to be related to just the RLFS since cars with RLS seem to be able to be Coded successfully.
bloggo
Birmingham UK
C?ID=198143
OK, thanks Andy; I will keep watching.
At least now I know there is a problem and not my incompetence.
TDI28
Stoke on Trent. UK
C?ID=14643
I have done the rain closing via the 09 cent elect but not with VCDS no problems on both occasions.
The software used arranges the data in different format which other than been in german makes
it easy to do.
andyvee
Rossendale, Lancashire, UK
C?ID=159389
The RLFS on the MQB platform for some strange reason will only accept certain values - these have been proven to work, but you need a different tool at the moment to code the RLFS as VCDS can't do it yet - hopefully soon Dana & Andy :)
06885D> motorway light "OFF" / rain light "ON" / Rain Close "ON" for Octavia 3 / Leon 5F
06A8DD> motorway light "OFF" / rain light "ON" / Rain Close "ON" for Golf 7
07C85D> motorway light "ON" / rain light " ON "/ Rain Close" ON "for Octavia 3 / Leon 5F
07E8DD> motorway light "ON" / rain light "ON" / Rain Close "ON" for Golf 7
I have rainclosing working perfectly on Octavia 3.
See this thread for info on a lot of tried and tested tweaks for the MQB platform
http://www.briskoda.net/forums/topic/299424-octavia-iii-vcds-adaptations-tried-and-tested/
andyvee
C?ID=159389
I don't think ODIS can code it either Andy - have you tried with VAS?
DV52
C?ID=194404
Hello VCDS gurus!
Has there been any further developments to the RLFS question for the MQB platform? I'm also keen to complete this tweak but alas I can't make the rainclosing function work on my car. Don't mean to rush whoever is looking at this, just interested in an update (please)
golfi_vend
Tartu, Estonia
C?ID=195131
RLS - rain light sensor right, but what is RLFS?
Thank You.
Dana
Western PA, USA
Hello VCDS gurus!
A few weeks ago a few VW dealers had Mk7 VINs online but those vehicles aren't (or weren't at that time) actually at the dealers. In the meanwhile VW has this teaser available:
http://www.vw.com/content/dam/vwcom/modelBucketMastheadImages/2014Mastheads/gti.png
European models shown
So.. we are working on it but I do not have an update. It will be much easier for the guys when these vehicles are available for live testing in the US market :)
Thank You.
Rain Light Humidity Sensor | Regen-/Licht-/Feuchtesensor
DV52
C?ID=194404
Dana: many thanks for the update. I'll await news of any further developments.
btw, I'm more than happy to loan Ross-Tech my car for testing purposes. Of course the trip to the antipodes might be a liitle longer than you are normally used to, but I can assure you that we are all quite domesticated down here and we all speak English (well.......it's a version of English, at least)
andyvee
C?ID=159389
Hi Don :) Thanks for the offer!
I think this problem is sorted after a few hours with a Mk7 at the local VW dealer:
http://www.briskoda.net/forums/topi...eta-1460-and-vcds-lite-12/page-5#entry3807931
Please give our latest Beta a shot and let us know how it goes!
It is indeed solved - I coded my RLFS on the 5E Octavia 3 back to the original 02805D and back to 06885D with the latest beta :)
The only issue I have is the databus seems to go to sleep after an hour approx and rain closing then stops working. Has anyone found any coding or adaptations to alter this behaviour?
DV52
C?ID=194404
Dana: You are a dead-set genius! Thanks for actioning this.
PS: Take $50 out of Ross-Tech's petty cash tin (I assume that Ross-Tech has a petty cash tin). Tell the accountant that I said that it was OK (the "Benevolent Dictator" won't mind-I hope)!
PPS:My offer is still open- my MKVII awaits!!
DV52
C?ID=194404
Dana,
Desparately need your help (again)! Tried to download the lastest beta as per your suggestion (i.e. ver 14.6.0- Data Version 20140601). Tried several times with IE and with Firefox - running 32 bit windows 7. Got the same message on all occassions. "Installer integrety check failed".Tried running the downloads as administrator, but same error. Never had this problem with Ross-Tech's other Beta files. Are you absolutely sure that the latest Beta file is executable on this MS operating platform?
Of course the problem could be that in the Southern Hemisphere, electrons spin in the opposite direction (bit like water going down our drain-pipes)! If I come up to USA and try to load it there, will it load properly (-it's a long way to come to get the RLFS to work on my mk7)?
flygteye
WI
C?ID=79663
Dana,
I downloaded it the other day and didn't have any problems. I have (the now out dated....) Windows XP, used Firefox, and am in the U.S.. Will try to use it tomorrow to make sure it all works...if it's nice out.
Yes, 'cause I built that installer and actually executed it before uploading it. :rolleyes:
It's also been there unchanged for more than a week. If it was problematic, others would have said something by now. But as a sanity check, I just downloaded it, despite the fact that I'm on a miserably slow DSL line right now, and it ran and installed just fine on a W7x64 system.
Sounds like you have some kind of network issues down there. When you save the installer file, what are its properties?
DV52
C?ID=194404
Uwe: Didn't mean to infer that guy who built the installer was somehow deficient! Your inescapable logic is compelling (the argument about no one else complaining). Kind of confirms that the problem may be at my end. I'll investigate further -strange, because the previous version loads OK.
Anyhow the properties details are as follows:
File description: VCDS installer
Type Application
file version 1.0.0.0
Product name VCDS
Copyright Copyright (C) Ross-Tech LLC
Size 16.1 MB (16,922,366 bytes)
Size on disc 16.1 MB (16,924,672 bytes)
Is the downloaded file size correct?
flygteye: Thanks for the response and it's good to see that you have made the transistion to this forum! Hope the weather holds-up for you - it's winter down here now, so it's got to be better up there!
Yup, file sizes match.
How about the digital signature? Is it intact? Click the Digital Signatures tab...
mtl
Slovenia
C?ID=153305
