Wow, that looks VERY clean!
This car is going to get an exhaust loud enough so that anyone who's behind it will realize it's not a 4-banger right?
Monday,17,April,2017,16:22:03:42165
VCDS Version: 17.1.3.0 (x64)
Workshop Code: 123 12345 045678
VIN: WVWZZZ1KZ6W124470 License Plate:
Mileage: 71240km-44266mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ6W124470 Mileage: 71240km-44266miles
22-AWD -- Status: Cannot be reached 1100
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 CD HW:
Component: MOTRONIC ME7.1.1 7802
Revision: --H01--- Serial number: VWZ7Z0E3138758
Coding: 0000172
Shop #: WSC 12345 123 45678
VCID: 4FAD5C06DE79993920-801A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0004738
Shop #: WSC 01279 785 00200
VCID: 72EBF5F26D0B94D1EF-8026
6 Faults Found:
Part No: 1K0 907 044 BD
Component: ClimatronicPQ35 090 0808
VCID: 6ADBED9245DB5C1157-803E
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000005382893
Coding: 008D0F210004100000120C000000000000097B075C
Shop #: WSC 01324 785 00200
VCID: 2A5B2D92855B9C1197-807E
Subsystem 1 - Part No: 1T0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW358 012 0401
Coding: 00063445
Shop #: WSC 01324
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD0H4NRK
Coding: 0012338
VCID: 35610EEE5CE5C3E90A-8060
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 034 0070
Coding: 0000042
VCID: 76E3C9E2016388F1C3-8022
Part No: 1K6 920 862 F
Component: KOMBIINSTRUMENT VDD 4316
Coding: 0001103
Shop #: WSC 00070 824 83288
VCID: 336530F65291DDD924-8066
00771 - Fuel Level Sensor (G)
010 - Open or Short to Plus
00438 - Fuel Supply Sensor 2 (G169)
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800106127113D
Coding: BD3F0340078003
Fault Frequency: 24
Reset counter: 125
Mileage: 71127 km
Time: 15:42:18
Address 22: AWD
Component: IMMO VDD 4316
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2302
Coding: 0000692
VCID: 366309E241E3C8F103-8062
00943 - Heated Exterior Mirror; Driver Side (Z4)
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.0 D06 1701
VCID: 346733EA579FDAE13D-8060
02546 - Steering Limit Stop
Mileage: 3280 km
Temperature: 18.0°C
Voltage: 12.30 V
Voltage: 12.20 V
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 00C802087F2D8405485FC61010CC
Shop #: WSC 00010 824 05318
VCID: 79F9C2DE307DE789AE-802C
Subsystem 5 - Part No: 1K0 947 291 F
Component: Innenraumueberw.009 4809
Coding: 00000000
Subsystem 6 - Part No: 1K0 951 605 C
Subsystem 7 - Part No: 1K0 907 719 C
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000692
VCID: 377D04E646E931F918-8062
Part No: 1K0 035 186 P
Component: Radio GR0 015 0019
Revision: 0001503S Serial number: VWZ2Z2F3751220
Coding: 0040400
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2428
Coding: 0000144
VCID: 326B35F2AD8BD4D12F-8066
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 E
Coding: 0000144
End-------------------------(Elapsed Time: 01:47)--------------------------
LA7X color ?
this sameYeah "Bamboo Gray"... Isn't that the same as yours???
I've been secretly stalking you on the internet
