- Joined
- Apr 9, 2014
- Messages
- 2,304
- Reaction score
- 2,252
- Location
- Tartu, Estonia
- VCDS Serial number
- C?ID=195131
How about correct tool and from cluster?
Wednesday,26,November,2014,21:22:35:42165
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: WAUZZZ8P94A155758 License Plate: A3
Mileage: 150140km-93292mi Repair Order: immo challenge
Address 25: Immobilizer
Control Module Part Number: 8P0 920 930 G
Component and/or Version: KOMBIINSTR. VDO H25 0140
Software Coding:
Work Shop Code: WSC 00000
VCID: 366309E241E3C891857-8063
Advanced Identification
Serial number: AUX7Z0D2FNJ0DI
Identification: VDD-024
Revision: D09
Date: 19.03.04
Test stand number: 7531
Manufacturer number: 0486
Misc.
Hardware number: 8P0 920 930 G
Immo Challenge: A2 1E AE D1
Car Info
Chassis Number: WAUZZZ8P94A155758
VCDS Info:
Labels: 1K0-920-xxx-25.clb
We've known that the A3 cluster/immo is Immo 4C for a couple of weeks, so this should not be a surprise now.The scan above, from the A3 Immo, says "Immo Challenge"... that's not what I wanted to see... is it?!?!!?
Here's a silly thought: Would the entire A3 dashboard (including the cluster) fit in the Touran?
Yes A3 cluster is 4C, but is also ECU 4C and withut channel 50, thats the question.
About your chip.
This site says it has a replacement. http://www.codecard.lt/electronics/...marked-as-5p08c3-in-so8-package/prod_240.html
5P08C3---ST95P08
That's an ambitous project you're undertaking.
My suggestion would be connect the power and can wires to r32 ecu and touran wiring. Then check diffrent modules if they have communication errors.
Somehow i although think your r32 ecu will com easiely with other touran modules.
On immobiliser(25) you can not use adaption channel 50, because of it being immo 4c. On ecu, maybe, check that out, I'm interested what results it will give.
I can't wait to see the result.
