I posted this on other forums but the US Access Code does not seem to be known. I was hoping that you guys could help find this for us?
I have a 2014 A6 Prestige with ACC and upon a phone enquiry, I was asked to post in "tweaks" with my scan.
13 - Auto Distance Regulator.
16 - Security Access.
This is where I need the help - this access code allows for the subsequent step but I do not have a code and Ross-Tech does not either. They told me that if they knew it then it would show up. If I had the code then it would enable me to change the following:
10 - Adaptation.
select "Driving off without Driver Trigger After Short Stop"
select Yes or Do It (I don't remember).
Scan:
10 - Adaptation.
Scan:
Wednesday,29,October,2014,13:01:31:39672
VCDS Version: 12.12.3.0 (x64)
Data version: 20140822
VIN: WAUHGAFCXEN065032 License Plate: ME
Mileage: 16349 Repair Order:
Chassis Type: FC (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 47
52 53 55 56 5F 62 6C 72 85 8B 8E 8F 90
Address 01: Engine (J623-CTUA) Labels: None
Part No SW: 4G0 907 551 J HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0002
Revision: --H07---
Coding: 0A2A0034056601060000
ASAM Dataset: EV_ECM30TFS0214G0907551J 001002
ROD: EV_ECM30TFS0214G0907551J.rod
VCID: 306F1A4A6BB9AB9E2BD-8065
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4G1 927 158 A HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H16 1006
Revision: --H16---
Coding: 000002
ROD: EV_TCMAL551211_AU57.rod
VCID: 2D51033E7C8BC67600B-8078
Address 03: ABS Brakes (J104) Labels: 4G0-907-379.clb
Part No SW: 4G0 907 379 M HW: 4G0 907 379 M
Component: ESP PREMIUM H09 0450
Coding: 44A7970122E5E9804B00
ROD: EV_ESPPremiAU57X.rod
VCID: 3B753D66B2FF58C68EF-806E
Part No SW: 4H0 907 064 DR HW: 4H0 907 064 DR
Component: BCM2 2.0 H35 0510
Coding: 0DA82046000000000000
VCID: 7CF7FE7AFF719FFEC75-8029
Part No SW: 4G0 820 043 AF HW: 4G0 820 043 AF
Component: KLIMA 4 ZONEN H13 0088
Serial number: 30091300042134
Coding: 6601207A4D
ASAM Dataset: EV_AirCondiComfoUDS 002043
ROD: EV_AirCondiComfoUDS.rod
VCID: 63C5A5066ACF4006E6F-8036
0192 - Position Sensor in Left Side Vent
B10E3 15 [008] - Open or Short to Plus
Reset counter: 251
Mileage: 24326 km
Date: 2014.10.08
Time: 09:39:34
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001483678
Coding: 0907A091073C9FE281000884A0003800CF9CD208A60802258001085C7B00
VCID: 6FEDD936BE07F466727-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119
Component: WWS57X 130904 H36 0080
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Subsystem 5 - Part No SW: 8K0 959 772 E HW: 8K0 959 772
Component: SLR-B8 H06 0007
Coding: 853000
Subsystem 6 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Coding: 110000
Subsystem 7 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Coding: 110000
Subsystem 8 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Coding: 020300
Subsystem 9 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Revision: 11001001 Serial number: 61031326400844
Coding: A8EB06
ROD: EV_EPHVA18AU57X0000.rod
VCID: 71E9DF4EA033E296643-8024
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Coding: 7E01010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X.rod
VCID: 285FF22A5369E35EF3D-807D
Address 15: Airbags (J234) Labels: None
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D8003FZTK
Coding: 303234373131303030324A55304C34473053
VCID: 336515469AAF908656F-8066
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y130000XYN30L
Serial number: 3575HRB401250LNIK97D
Serial number: 3585HRB401450LNIFH1D
Serial number: 3515JRB405126M6MA1O2
Serial number: 3525JRB405326M6MB1M4
Serial number: 3554VRB401G50L34P902
Crash sensor for front airbag; passenger side:
Serial number: 3564VRB401G50L34H0M8
Address 16: Steering wheel (J527) Labels: None
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372MIN0014L
Coding: 0000FC
VCID: 377D215686D77CA66A7-8062
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 984 R HW: 4G8 920 984 R
Component: TBenUsaAcc H80 0621
Revision: 30460234 Serial number: 658160913596030
Coding: 03CF09040F51D705020000
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: 45815B9EC43B1E36E8B-8010
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Revision: -------- Serial number: 00000001104492
Coding: 00CD073000
ROD: EV_GatewPkoUDS.rod
VCID: 72EBD042A535D98E9D9-8027
Serial number: 5555991303
Voltage stabilizer:
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 J HW: 4G0 919 158 J
Component: KLIMA FOND H07 0088
Serial number: 24091300040890
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 002021
ROD: EV_ClimaContrUnitRearUDS.rod
VCID: 36632C5289DD85AE711-8063
Part No SW: 4G8 959 760 A HW: 4G8 959 760 A
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000075835321
Coding: C0581B008F006001000001010101102030303232203232
VCID: 387F226A8BC973DE63D-806D
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H03 0056
Revision: -------- Serial number: EJ1BPA8204ZHEV
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_AU57.rod
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH03 0060
Revision: 00H03000 Serial number: 6PZ 010 287-03
VCID: 306F1A4AA3B9AB9E2BD-8065
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H03 0060
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F19.09.1300H03000AMS16220ÿ
Subsystem 4 - Serial number: S16220ÿ
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0507
Coding: 011F17005E00628002000013
VCID: 45815B9ECC3B1E36E8B-8010
Address 44: Steering Assist (J500) Labels: None
Component: RCEPS H38 0010
Revision: 00001000 Serial number: 0024891020
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS.rod
VCID: 326B104265B5998E5D9-8067
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0316710869
Coding: 0106063A00FA408582B0088402070E470000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Coding: 101F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Subsystem 5 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000037339
Coding: 030000
VCID: 1D31D3FE042B36F690B-8048
Component: TSG BF H03 0507
Coding: 011F17005E00628002000002
VCID: 46835C92F13D152EE11-8013
Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
Component: EPB-4 H03 0014
Revision: -------- Serial number: 00000000834444
ROD: EV_ParkiBrake_AU48.rod
VCID: 2C570E3A4791CF7E175-8079
Address 55: Xenon Range (J431) Labels: None
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 130930-0002-050
Coding: 1221A6601002A500
ROD: EV_HeadlRegulBasic.rod
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156J60D7911695
Coding: 020007010000000001
VCID: 2447E61A2741073EDF5-8071
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 746 E HW: 4G0 035 746 E
Component: H-BNT-NA H40 0735
Revision: -------- Serial number: 194J40D7557622
Coding: 050200000003E9EF7D12CB3E00000003100001000000000000
VCID: 2959F72E4063DA56EC3-807C
Subsystem 1 - Part No: 8R0 060 884 BD
Component: NAR 2013/2014 0802
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Component: CD-Database 5298
Component: TSG HL H03 0507
VCID: 499957AEE023FA560C3-801C
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 4H0 907 428 B HW: 7P6 907 441 D
Component: TopView H05 0220
Revision: 11001001 Serial number: 82330JF0108996
Coding: 0200000001010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
ROD: EV_CamerSysteTopViewAUDI.rod
Address 85: On Board Cam. (J852) Labels: None
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Revision: -------- Serial number: 262130025421000
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2643FC12597DF52EC11-8073
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7E01010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X.rod
Address 8E: Image Processing (J851) Labels: 4G0-907-107.clb
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H32 0041
Serial number: 005000122009137
Coding: 04C198180111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 0066E608031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 31691F4E60B3A296243-8064
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End ---------------------------------------------------------------------
