Looking for some assistance on a retrofit of a MIB2 into a 2015 Passat.
Love the new setup. It is so much faster than my RNS510, but there are some small issues that i'm confident can be overcome.
Issues
- The car has bluetooth and the radio has bluetooth, and I think both are talking to the MFI making the MFI go a little crazy. I'd like some way to disable the bluetooth on the car, but it isn't as simple as removing the 9w7/2/3 etc because there is nothing under the passenger seat in my 2015. (My bt module was there in my 2010). Sometimes the MFI wants me to connect my phone (even though it is already connected to the MIB2's radio) and sometimes it shows it connected to the MIB and then it will suddenly drop off.
- The audio is super loud -- at 10% it was like the radio is at 50-60% and 25% is like 100%. I think this is because I had a fender amp and it doesn't know anything about that
- There is no ability to use the fader. I see balance, but no fader
Probably know solution to this issue:
- The mic doesn't work - I am thinking this is just a polarity thing on the mics, but unsure. I'm having someone help me with the install and need to head over there to get the unit pulled out to test, so that one is probably on hold for now.
Note, I did go into 19 CANBUS to uncheck 77 telephone which I was hoping would kill off the onboard bluetooth but it wasn't checked to begin with....
VCDS scan below.
Thanks for the help!
Issues
VCDS scan below.
Wednesday,18,July,2018,18:40:07:00481
VCDS Version: 18.2.1.5 (x64) HEX-NET CB: 0.4411.4
VIN: 1VWCV7A3XFCXXXXXX License Plate: MINE
Mileage: 25170km-15639mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F 52
56 5F 62 72 77
VIN: 1VWCV7A3XFCXXXXXX Mileage: 25170km-15639miles
37-Navigation -- Status: Sporadic communication error 1000
56-Radio -- Status: Sporadic communication error 1000
5F-Information Electr. -- Status: Not registered 0011
Address 01: Engine (J623-CVCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 AE HW: 04L 907 309 K
Component: R4 2.0l TDI H20 9288
Revision: 8AH20---
Coding: 01190012832410081000
Shop #: WSC 95862 999 00000
ASAM Dataset: EV_ECM20TDI01104L906016AE 004018
ROD: EV_ECM20TDI01104L906016AE_004.rod
VCID: 6C940028878A1624E8-8038
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: C54BC0F549260002A31403EC921B0042A1100012
Shop #: WSC 09003 957 00200
VCID: 04444888871AFE6400-8050
Reset counter: 128
Mileage: 24961 km
Date: 2018.07.15
Time: 00:00:24
Count: 2
Count: 6
Count: 20480
Count: 16390
Count: 45056
Count: 255
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Revision: 00092000 Serial number: 0342676559
Coding: 030C0C
VCID: 373EEF448E4C65FCD5-8062
Part No SW: 561 907 044 AR HW: 561 907 044 AR
Component: Climatronic H03 0808
Revision: 00001K01
Coding: 0050019002
ROD: EV_ACClimaBHBVW411_VW41.rod
VCID: 679E7F049E6C357C85-8032
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0174
Revision: BL122001
Coding: EF200E3FE82B2AD4088800013600854800F1A08655A005B064806000AC70
VCID: 78BC2C78CBD2AA841C-802C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 201014 05 54 0403
Coding: 06300A
Part No SW: 5C0 959 655 AA HW: 5C0 959 655 AA
Component: AirbagVW10 500 0975
Serial number: 003LYD01U4EY
Coding: 0000474A
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 71AA115CA0A8FBCCDB-8024
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y14000195RX04
Coding: 303047
Serial number: 3572MSME1B321E49ZZZ
Serial number: 3582MSME76510849ZZZY
Serial number: 3516KSME5F376A31ZZZ$
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME40387431ZZZK
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME516B0432ZZZQ
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME22610432ZZZF
Part No SW: 1K5 953 521 BR HW: 5K0 953 569 AH
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20140822300331
Coding: 000A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7EB03A60E1F694B456-802A
Component: E221__MFL-8LP H07 0023
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 870 E HW: 561 920 870 E
Component: KOMBI H04 0813
Coding: 331E01
VCID: 1B7613F412A4219CD1-804E
Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM
Component: J533 Gateway H55 1653
Revision: H55 Serial number: 30101403000916
Coding: 461000
VCID: 004C44989302E24424-8054
Fault Status: 00110100
Reset counter: 128
Mileage: 24960 km
Date: 2018.07.15
Time: 14:26:39
01304 - Radio
Reset counter: 128
Mileage: 24960 km
Date: 2018.07.15
Time: 14:26:39
Fault Frequency: 102
Mileage: 24960 km
Date: 2018.07.15
Time: 14:15:15
Component: IMMO H04 0813
Coding: 000007
VCID: 6A9806308D7E08149A-803E
Address 2B: Steer. Col. Lock (J764) Labels:| 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 14000286681005
Coding: 4100000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 302CD4586B22B2C494-8064
Address 2E: Media Player 3
Part No SW: 561 959 760 B HW: 561 959 760 B
Component: MEM-FS H04 0182
Revision: AA000000 Serial number: 00000120860744
Coding: 00581B0000000000000021010100202020202120202020
VCID: 22082E103DCE105412-8076
Address 37: Navigation
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0009036014
Coding: 0405FD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1C7410E817AA26A4D8-8048
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14102630141028214400
Coding: 800000
B11EC 54 [008] - Missing Calibration / Basic Setting
Reset counter: 131
131584 - Motor for Rear Window Regulator
B11EE 54 [008] - Missing Calibration / Basic Setting
Reset counter: 136
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 215 3501
Revision: 00H22000
VCID: 393AE97C7058738C23-806C
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0007788
VCID: 281C3C3853F2FA044C-807C
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1653
Coding: 01030108
VCID: 6FAE1724BE9CED3CCD-803A
Subsystem 1 - Part No SW: 561 959 591 A HW: 561 959 591 A
Component: J245 P05 9BA3 H08 0005
Serial number: 53388786011412200139
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 009 0005
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0009058685
Coding: 0405FC
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D721DEC0CB02FAC2F-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14102631141110104414
Coding: 800000
Reset counter: 131
Reset counter: 128
Address 56: Radio
Part No SW: 5C0 035 684 HW: 5C0 035 684
Component: MU-S-NS-US H21 0241
Serial number: VWZAZ2R0347350
Coding: 02630102BE00000051220001001808001F0100D400200105C6
Shop #: WSC 00066 790 00015
ROD: EV_MUStd4CTSAT_VW27.rod
VCID: 62886E10754E505452-8036
Subsystem 1 - Part No SW: 3G0 919 866 B HW: -----------
Component: NAR 2015/16 --- 0220
17 Faults Found:
B11CF 53 [009] - Deactivated
Reset counter: 14
Mileage: 43 km
Date: 2016.11.14
Time: 21:09:29
Voltage terminal 30: 12.2 V
SDARS_tuner_status_2-Antenna current: 0 mA
SDARS_tuner_status_2-Reception quality: No_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 00
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 00
0512 - Rear Right Bass Speaker
B1067 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 1: Unterbrechung (DC-Diagnose)]
Reset counter: 14
Mileage: 43 km
Date: 2016.11.14
Time: 21:09:29
0517 - Front Right Bass Speaker
B1062 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 2: Unterbrechung (DC-Diagnose)]
Fault Frequency: 12
Reset counter: 97
Mileage: 43 km
Date: 2016.11.14
Time: 21:09:29
B1064 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 2: Unterbrechung (AC-Diagnose)]
Reset counter: 0
Voltage terminal 30: 13.5 V
B1061 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 3: Unterbrechung (AC-Diagnose)]
Reset counter: 97
Mileage: 25179 km
Date: 2018.07.18
Time: 06:33:59
Voltage terminal 30: 12.1 V
0527 - Rear Left Bass Speaker
B1065 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 4: Unterbrechung (DC-Diagnose)]
Reset counter: 14
Mileage: 43 km
Date: 2016.11.14
Time: 21:09:29
0009 - Antenna for Satelite Radio
B10F4 13 [008] - Open Circuit
Reset counter: 128
Voltage terminal 30: 13.8 V
2565 - GPS Antenna
B1054 13 [008] - Open Circuit
[GPS aerial - open circuit]
Reset counter: 128
6720 - Rear View Camera
B1102 31 [009] - No Signal
Reset counter: 88
Mileage: 24961 km
Date: 2018.07.15
Time: 00:00:23
Voltage terminal 30: 12.3 V
1564 - Microphone 1
B129B 13 [009] - Open Circuit
Fault Frequency: 35
Reset counter: 97
6702 - Databus
[ESP: no communication]
Reset counter: 128
Voltage terminal 30: 13.7 V
6706 - Databus
[Instrument cluster: no communication]
Reset counter: 128
6714 - Databus
[VIN: no communication]
Reset counter: 128
0001 - Antenna 1 for Radio
B1119 13 [008] - Open Circuit
Reset counter: 128
Status of antenna 1 for radio-Antenna current: 0 mA
Status of antenna 1 for radio-Connection between radio and antenna amplifier: Electrical OK
Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Electrical OK
Status of antenna 1 for radio-Reception level antenna 1: 0 dB�V
0003 - Antenna 2 for radio
B111A 13 [008] - Open Circuit
Reset counter: 128
Status of antenna 2 for radio-Antenna current: 0 mA
Status of antenna 2 for radio-Connection between radio and antenna amplifier: Electrical OK
Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Electrical OK
Status of antenna 2 for radio-Reception level antenna 2: 0 dB�V
U11B8 00 [008] - No Communications
[USB - communication error]
Reset counter: 128
Voltage terminal 30: 13.4 V
Interface for external media: status-Status: Open circuit
7223 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 0
BAP-BAP_Function_ID: 02
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666748944
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 3228DE50652E80D4E2-8066
9455635 - Telephone Microphone
B1048 13 [009] - Open Circuit
Reset counter: 88
Mileage: 24960 km
Date: 2018.07.15
Time: 14:23:21
9457427 - Left audio channel for speech/telephone
B104F 13 [009] - Short to GND
Reset counter: 97
Mileage: 25179 km
Date: 2018.07.18
Time: 06:36:20
End----------(Elapsed Time: 01:16, VBatt start/end: 12.3V/12.3V)-----------
