Hello i did a cleaning of the dpf and need to do diesel particle filter regeneration on a 2009 audi a5 but there is a problem. When select Service regeneration of particle filter i press go and i do what the software says (press brake and accelerator) and relase them when it says on the screen but after doing that it says timeout what is that and why is it not letting me do the regen here is a autoscan
any help would be appreciated
VIN: WAUZZZ8T69A054553 License Plate:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 3C 42 46 52 53 55 56
5C 5F 69
VIN: WAUZZZ8T69A054553 Mileage: 189520km-117762miles
13-Auto Dist. Reg -- Status: Cannot be reached 1100
20-High Beam Assist. -- Status: Malfunction 0010
5C-Lane Maintain. -- Status: Malfunction 0010
Address 01: Engine (J623-CCWA) Labels:| 059-907-401-V1.clb
Part No SW: 8K2 907 401 HW: 8K1 907 401 A
Component: 3.0TDI EDC17 H01 0006
Revision: 15H01---
Coding: 0114002C190F0A28
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM30TDI0118K2907401 001006
ROD: EV_ECM30TDI0118K2907401.rod
VCID: EA989AF70DBB011419-80BE
6 Faults Found:
4528 - Coolant Fan Control Circuit 2
P0481 00 [039] - Electrical Malfunction
Mileage: 189522 km
Date: 2018.07.17
Time: 09:45:04
Engine speed: 640.00 /min
Normed load value: 21.6 %
Coolant temperature: 72 °C
Intake air temperature: 40 °C
Voltage terminal 30: 13.840 V
Crankshaft speed (RPM): 640.0 /min
Vehicle speed: 0.00 km/h
Intake air temperature: 40.4 °C
Air mass: specified value: 200.0 mg/stroke
C Thmst r: 0.00 %
Field regeneration status-Bits 0-7: 00000000
Field regeneration status-Bits 0-7: 00010000
Exhaust gas temp.bef.turbocharger: -273.1 °C
5188 - Diesel Particle Filter
P2463 00 [167] - Excessive Soot Accumulation
Mileage: 189522 km
Date: 2018.07.17
Time: 09:45:06
Engine speed: 2472.00 /min
Normed load value: 26.7 %
Crankshaft speed (RPM): 2472.0 /min
Particle filter: soot mass measured: 33.70 g
Particle filter: soot mass calculated: 51.43 g
Particle filter: kilometers since last regeneration: 895358 m
P Flt Rgn st Intr-Bits 0-7: 00000001
P Flt Rgn st Intr-Bits 0-7: 00001000
Particle filter: time since last regeneration: 0 s
5308 - Throttle Body Actuator Bank 1 (J338)
P0638 00 [039] - Implausible Signal
Mileage: 189522 km
Date: 2018.07.17
Time: 09:45:05
Engine speed: 1395.50 /min
Normed load value: 99.6 %
Voltage terminal 30: 13.880 V
Crankshaft speed (RPM): 1395.5 /min
Thr Vlv r: 100.00 %
Ambient temperature: 28.5 °C
Throttle valve output stage: 5.00 %
Vehicle voltage terminal 30: 13880 mV
9491 - Oile Pressure Regulating Valve
P164E 00 [039] - Electrical Malfunction
Mileage: 189522 km
Date: 2018.07.17
Time: 09:45:04
Engine speed: 642.00 /min
Normed load value: 21.2 %
Voltage terminal 30: 13.800 V
Crankshaft speed (RPM): 642.0 /min
Vehicle voltage terminal 30: 13800 mV
4709 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [039] - -
[Lost Communication WithCruise Control Front Distance Range Sensor]
Mileage: 189522 km
Date: 2018.07.17
Time: 09:45:04
Engine speed: 641.50 /min
Voltage terminal 30: 13.860 V
Crankshaft speed (RPM): 641.5 /min
Accelerator position: 0.00 %
Vehicle voltage terminal 30: 13860 mV
Bus Diag st Node 0-Bits 0-7: 00000000
Com ct Rx TO ACC-Bits 0-7: 00001000
Cr C st Key 0-Bits 0-7: 00000000
5189 - Particulate Trap Bank 1
P2002 00 [039] - Efficiency Below Threshold
Mileage: 189522 km
Date: 2018.07.17
Time: 09:45:06
Particle filter: difference pressure: 60 hPa
Exh t Adap T Oxi Cat Ds: 115.7 °C
Exhaust gas temperature before particulate filter: 83.6 °C
Exhaust gas vol.flow particulate filter: 260.9 m³/h
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8K0 927 158 A HW: 0B6 927 156
Component: 0B6 30 TDIRdW H04 0050
Revision: --H04---
Coding: 001001
ASAM Dataset: EV_TCMAL651 A01004
ROD: EV_TCMAL651.rod
VCID: B424448F1FFF87E473-80E0
4765 - Functionality limited due to Engine Control Module
P1719 00 [047] - -
[Text noch nicht vorhanden - KFC_GBMOT-KFA_KSM]
Mileage: 189522 km
Date: 2018.07.17
Time: 09:45:04
Transmission input speed: 618 /min
Transmission output speed: 0 /min
Engine torque: -12 Nm
Transmission fluid temperature: 57 °C
Accelerator position: 0.0 %
Clutch status: 0
Part No SW: 8K0 907 379 AH HW: 8K0 907 379 AH
Component: ESP8 quattro H04 0230
Coding: 14CD00
VCID: FF4E5BA36E3994BCDE-80AA
Fault Frequency: 74
Reset counter: 13
Mileage: 189195 km
Date: 2018.04.16
Time: 16:13:10
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x0024
Hex Value: 0xB48F
Hex Value: 0x00FF
Fault Status: 00101101
Reset counter: 48
Mileage: 189210 km
Date: 2008.05.27
Time: 00:05:19
Hex Value: 0x00C0
Hex Value: 0x07A2
Hex Value: 0x0031
Hex Value: 0x029B
Hex Value: 0x00FF
Part No SW: 8K0 907 064 CQ HW: 8K0 907 064 CQ
Component: BCM2 2.0 H07 0437
Coding: 050000
Shop #: WSC 49816 002 1048576
VCID: 814ADD5B18CDE24CA8-80D4
Subsystem 1 - Part No SW: 8T0 959 754 K HW: 8T0 959 754 K
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000013725003
Component: J764 ELV MLB H38 0042
Serial number: 3216000122698016
6 Faults Found:
03285 - Sensor for Contact with Door Handle; Front Left
Reset counter: 4
Mileage: 189195 km
Date: 2018.04.16
Time: 16:13:15
Fault Frequency: 37
Reset counter: 48
Mileage: 189210 km
Date: 2018.06.04
Time: 17:27:29
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Fault Frequency: 53
Reset counter: 48
Mileage: 189210 km
Date: 2018.06.04
Time: 17:27:30
02811 - Control Module for Electronic Steering Column Lock (J764)
Reset counter: 44
Mileage: 189210 km
Date: 2008.05.27
Time: 00:00:58
Reset counter: 48
Mileage: 189210 km
Date: 2008.05.27
Time: 00:00:00
00447 - Function Limitation due to Over-Voltage
Fault Status: 00100001
Reset counter: 48
Mileage: 189244 km
Date: 2018.07.11
Time: 10:35:23
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
Component: KLIMA 3 ZONEN H06 0150
Revision: C1000000 Serial number: 01210420091108
Coding: 36120000
VCID: F2A882972D6BC9D4A1-80A6
01230 - Left Footwell Vent Temperature Sensor (G261)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 4
Mileage: 189195 km
Date: 2018.04.16
Time: 10:13:35
Temperature: 21.0°C
Voltage: 13.70 V
Reset counter: 44
Mileage: 189210 km
Date: 2018.06.04
Time: 17:31:52
Reset counter: 44
Mileage: 189210 km
Date: 2018.06.04
Time: 17:28:45
Reset counter: 44
Mileage: 189210 km
Date: 2008.05.27
Time: 00:11:53
Reset counter: 44
Mileage: 189210 km
Date: 2018.06.04
Time: 17:31:52
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H26 0253
Revision: 05026001 Serial number: 00000000249005
Coding: 260050914074AF010009000300005D5D0F1C638800010141000000
VCID: B02C489FE3E7BBC417-80E4
Subsystem 1 - Part No SW: 8T1 955 119 C HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 250708 H13 0040
Serial number: SWFBIE 0005198
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10445598
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 AA HW: 8K0 941 531 AA
Component: E1 - LDS H07 0090
Serial number: 00000000001504091280
Reset counter: 45
Mileage: 189210 km
Date: 2018.06.04
Time: 17:27:00
01800 - Light Switch (E1)
Reset counter: 44
Mileage: 189210 km
Date: 2018.06.29
Time: 19:49:00
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 G HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0040
Revision: 11001001 Serial number: 40040911300092
Coding: 110101
VCID: BD3261AB24B546AC8C-80E8
Reset counter: 47
Mileage: 189210 km
Date: 2018.06.04
Time: 17:28:40
Temperature: 26.0°C
Reset counter: 48
Mileage: 1048574 km
Date: 2018.07.09
Time: 11:57:21
Temperature: 77.0°C
Address 13: Auto Dist. Reg
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H37 0520
Serial number: 003EFD0231U
Coding: 30313433363030303030554A304C38543053
VCID: C1CA1D5B504D224CE8-8094
Serial number: 6334MSME46662F77Q
Serial number: 6344MSME472206386
Serial number: 6352QSME712804188
Serial number: 6362QSME7423323EG
Serial number: 63732SME2F240717.
Serial number: 63832SME2D230E0F6
13697280 - Component Protection
U1101 00 [008] - Active
Mileage: 189210 km
Date: 2018.06.04
Time: 17:32:05
13635840 - Supply voltage
[Powersupply lower threshold fall short of]
Reset counter: 44
Mileage: 189210 km
Date: 2008.05.27
Time: 00:12:02
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319IDF00046
Coding: 00009E
VCID: BE3066A729B35DB495-80EA
Component: E221 - MFL H02 0003
02795 - Steering Wheel Vibration Motor (V331)
Fault Status: 00100111
Reset counter: 45
Mileage: 189195 km
Date: 2018.04.16
Time: 16:13:05
Fault Status: 00100011
Reset counter: 44
Mileage: 189196 km
Date: 2018.04.17
Time: 12:58:26
Reset counter: 44
Reset counter: 47
Mileage: 189210 km
Date: 2008.05.27
Time: 00:00:46
Part No SW: 8T0 920 930 S HW: 8T0 920 930 S
Component: KOMBIINSTR. H16 0224
Revision: 00200000 Serial number: 9DD21U949
Coding: 0F0701004F000008000000
VCID: C6C00E4771630574DD-8092
Reset counter: 4
Mileage: 189195 km
Date: 2018.04.16
Time: 10:13:43
01298 - Instrument Cluster Lamp Test
Reset counter: 47
Mileage: 189212 km
Date: 2018.07.10
Time: 08:48:18
Part No SW: 8T0 907 468 Q HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0095
Revision: FB600048 Serial number: 4800F094040162
Coding: 000303
VCID: CFEE2B639E19C43C6E-809A
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
Serial number: 190725BC250309
Reset counter: 4
Mileage: 189195 km
Date: 2018.04.16
Time: 10:13:41
Fault Frequency: 16
Reset counter: 49
Mileage: 189210 km
Date: 2008.05.27
Time: 00:05:00
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8K0 857 511 C HW: 8K0 857 511 A
Component: FLA H04 0003
Revision: AA001002
Coding: 02019864747464545425363E
VCID: B12A4D9BE8EDB2CC18-80E4
Fault Frequency: 14
Reset counter: 45
Part No SW: 8K0 907 566 B HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0050
Revision: 00H01000 Serial number: 6PZ 009 014-13
Coding: 0010104
VCID: B6207E87C18395F44D-80E2
Subsystem 1 - Part No: 8K0 907 568 B
Component: J0770_SWA_Slave_H01 0050
Subsystem 2 - Serial number: 6PZ 009 014-33
Subsystem 3 - Serial number: 5F02.04.0900H010003C910486ÿ
Subsystem 4 - Serial number: 910486ÿ
02857 - Supply Voltage for Lane Change Assistance Control Module 2
Fault Frequency: 17
Reset counter: 44
Mileage: 189210 km
Date: 2009.01.01
Time: 00:00:00
Fault Frequency: 26
Reset counter: 44
Mileage: 189210 km
Date: 2009.01.01
Time: 00:00:00
Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000008797294
Coding: 011C12224000120102
VCID: C1CA1D5B584D224CE8-8094
Fault Frequency: 19
Reset counter: 45
Mileage: 189210 km
Date: 2018.06.04
Time: 17:27:34
Reset counter: 48
Revision: 00002001 Serial number: 0444392079
Coding: 011A0E80003904010120000000000000
Component: LIN BACKUP HO H03 1301
6 Faults Found:
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 4
Mileage: 189195 km
Date: 2018.04.17
Time: 12:42:04
02738 - Bulb for Tail/Brake Light; Left
012 - Electrical Fault in Circuit - MIL ON
Fault Status: 11101100
Fault Frequency: 56
Reset counter: 13
Mileage: 189195 km
Date: 2018.04.17
Time: 12:43:41
02741 - Bulb for Tail Light 2; Right
Fault Frequency: 88
Reset counter: 13
Mileage: 189195 km
Date: 2018.04.17
Time: 12:44:13
02615 - Fuel Tank Cap; Lock
Reset counter: 4
Mileage: 189195 km
Date: 2018.04.17
Time: 12:47:15
Reset counter: 44
Mileage: 189210 km
Date: 2008.05.27
Time: 00:00:00
00532 - Supply Voltage B+
Reset counter: 48
Mileage: 189244 km
Date: 2018.07.11
Time: 10:39:38
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000008801971
VCID: C0CC185F53472B44E7-8094
Fault Frequency: 23
Reset counter: 13
Mileage: 189195 km
Date: 2018.04.17
Time: 12:42:04
Fault Frequency: 22
Reset counter: 45
Mileage: 189210 km
Date: 2018.06.04
Time: 17:27:34
Reset counter: 44
Mileage: 189210 km
Date: 2018.06.04
Time: 17:29:30
Reset counter: 48
Mileage: 189244 km
Date: 2018.07.11
Time: 10:37:18
Part No SW: 8K0 907 801 G HW: 8K0 907 801 G
Component: EPB Audi B8 H08 0080
Revision: 00000003 Serial number: 00000000349352
VCID: B326479312F180DC6A-80E6
02432 - Supply Voltage for Left Parking Brake Motor (V282)
Fault Status: 00101011
Reset counter: 48
Mileage: 189244 km
Date: 2018.07.11
Time: 10:29:41
Voltage: 15.30 V
Count: 28
Hex Value: 0x0260
Hex Value: 0x0001
Hex Value: 0x0101
02434 - Supply Voltage for Control Module for Left Channel
Fault Status: 00101001
Reset counter: 48
Mileage: 189244 km
Date: 2018.07.11
Time: 10:29:41
Voltage: 15.30 V
Count: 14
Hex Value: 0x0260
Hex Value: 0x0001
Hex Value: 0x0101
02435 - Supply Voltage for Control Module for Right Channel
Reset counter: 44
Mileage: 189210 km
Date: 2008.05.27
Time: 00:05:19
Voltage: 14.80 V
Count: 15
Hex Value: 0x02E3
Hex Value: 0x0001
Hex Value: 0x1010
02433 - Supply Voltage for Right Parking Brake Motor (V283)
Reset counter: 44
Mileage: 189210 km
Date: 2008.05.27
Time: 00:05:19
Voltage: 14.80 V
Count: 29
Hex Value: 0x02E3
Hex Value: 0x0001
Hex Value: 0x1010
Address 55: Headlight Range Labels: 8T0-907-357.clb
Part No SW: 8H0 907 357 A HW: 8H0 907 357
Component: AFS 1 H01 0020
Coding: 0000017
Shop #: WSC 06324 000 00000
VCID: B02C489F23E7BBC417-80E4
Subsystem 1 - Part No: 7L6 941 329 C
Component: AFS-Modul links H01 0004
Subsystem 2 - Part No: -----------
Component: AFS-Modul rechts
02631 - Voltage Supply for Swivel Module Position Sensor; Left
007 - Short to Ground - MIL ON
Fault Status: 11100111
Reset counter: 4
Mileage: 189195 km
Date: 2018.04.17
Time: 12:42:14
Reset counter: 4
Mileage: 189210 km
Date: 2018.06.04
Time: 17:28:44
Fault Status: 11100100
Fault Frequency: 49
Reset counter: 8
Mileage: 189210 km
Date: 2018.07.06
Time: 19:26:02
01771 - Control Module for Headlight Range (J431)
Reset counter: 45
Mileage: 189212 km
Date: 2018.07.09
Time: 08:58:56
Part No SW: 4F0 035 056 B HW: 4F0 035 056
Component: Radio U STD H45 0020
Revision: AB001007 Serial number: 342D$097596366
Coding: 010003020100000001
VCID: 9F0EBB238E7934BCBE-80CA
03029 - Subwoofer (R157)
Reset counter: 4
Mileage: 189195 km
Date: 2018.04.16
Time: 10:13:36
Voltage: 13.50 V
Address 5C: Lane Maintain. Labels: None
Part No SW: 8K0 907 217 A HW: 4E0 907 217 C
Component: J759 LDW 0070
Revision: 00H07012 Serial number: 2002093120001B
Coding: 0002003
VCID: AE1056E739D3AD3405-80FA
Reset counter: 48
Mileage: 189196 km
Date: 2018.04.17
Time: 12:58:27
Fault Frequency: 65
Reset counter: 11
Mileage: 189195 km
Date: 2018.04.16
Time: 10:13:41
Fault Frequency: 23
Reset counter: 47
Mileage: 189210 km
Date: 2018.06.04
Time: 17:28:41
02858 - Windshield Heater for Directional Stabilization Assistance (Z67)
Fault Frequency: 12
Reset counter: 48
Mileage: 189210 km
Date: 2008.05.27
Time: 00:03:46
Part No SW: 8T1 035 670 D HW: 8T1 035 670
Component: H-BNT-EU H65 0047
Revision: -------- Serial number: 320DG097531052
Coding: 010100020006A9ED39000B1E000000030000
VCID: B6207E87018395F44D-80E2
Subsystem 1 - Part No: 8R0 060 884 C
Component: EUROPE 2008 5608
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356DR091090627
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000000271219
Reset counter: 4
Mileage: 189195 km
Date: 2018.04.16
Time: 10:13:38
Voltage: 13.60 V
Reset counter: 47
Mileage: 189213 km
Date: 2018.07.10
Time: 14:41:51
Bin. Bits: 00010010 00100000
Bin. Bits: 00001000 00000000
Bin. Bits: 00000000 00000000
01043 - Control Module; Incorrect Software Version
Reset counter: 44
Mileage: 189210 km
Date: 2008.05.27
Time: 00:04:44
Bin. Bits: 00000000 00100000
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 B HW: 8K0 907 383 B
Component: Anhaenger H08 0080
Revision: 1A002002 Serial number: 00000118152079
Coding: 0100000000000000
