Greetings from Calgary, AB Q: Q5 TDI
Lord Diesel
Canada
C?ID=341707
Jumping into the deep end with the documentation on my new HEX-V2, but running up against a time crunch with my 2015' Audi Q5 TDI. I have a scheduled maintenance apt this Friday, and one of the goals with the V2 is to "snap-shot" the factory firmware loaded on the ecu prior to the service appointment. I fear the dealer may accidentally or inadvertently flash the ecu with the diesel "emissions fix" with all its negative consequences. My thought is to have a "before" and "after" snap-shot of the code loaded such that I can compare and determine if there's been any unauthorized modifications to the fw. I have archived a copy of the factory fw as a precaution should it be inadvertently over-written, however I'll need hard evidence to prove to the dealer should it ever come to that.
Is there a function or procedure that can be suggested which would give me the necessary data? Something as simple as identifying a code release, or as targeted as identifying code changes specific to the emission system? Looking for any/all options that will get me what I need prior to my Friday visit.
Looking forward to exploring the vast features of VCDS and its application to the 3.0L TDI.
Regards.
Lord Diesel
Very easy. Run and save an Auto-Scan as described in this thread. That will get you the software part numbers and versions for all your control modules, not just the ECU.
Feel free to post the scan here for posterity as well.
Lord Diesel
Canada
C?ID=341707
Uwe, thank you sir! I was planning on trying that after digging into the documentation last night. It looked like it would suffice but being I've just scratched the surface of this incredible tool, thought best to see if there were other tools in the chest, so to speak.
Thanks for your quick reply. Be happy to post the output.
Lord Diesel
Lord Diesel
Canada
C?ID=341707
Seems like it might be a good idea to download and install the beta to ensure I detect any unauthorized "messing about" with the factory code?
http://forums.ross-tech.com/showthread.php?12843-2013-Q7-TDI-Post-Emission-Fix-Unknown-Error-Code
Here's the current scan (pre-dealer visit)
Sunday,22,July,2018,14:17:20:24426
VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
VIN:    License Plate:
Mileage: 26110km-16224mi   Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 3C 42 44 46 47 52 53 56
          62 6D 72 77 AC
VIN:    Mileage: 26110km-16224miles
Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 401 S    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  H14 0001
   Revision: 58H14---
   Coding: 2A2A4012052603050000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TDI0118K5907401S 001003
   ROD: EV_ECM30TDI0118K5907401S.rod
   VCID: 40D9BCF33A0635A7314-8014
   Part No SW: 8R0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H18 1003
   Revision: --H18---
   Coding: 000001
   VCID: 4BC39BDF0340E6FFD46-801E
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
   Component: ESP8 quattro  H09 0020
   Coding: 23150C03
   Shop #: WSC 06335 000 00000
   VCID: 117F49B7216C8C2FEEA-8044
   Part No SW: 8K0 907 064 JP    HW: 8K0 907 064 JP
   Component: BCM2 2.0      H14 0650
   Coding: 0DA54040000000000000
   VCID: 074B67EF5F28C29F30E-8052
   Subsystem 1 - Part No SW: 8K0 959 754 B    HW: 8K0 959 754 B
   Serial number: 0514000104452009
   Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
   Serial number: 0214000131122016
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01240720140199
   Coding: 3621228080
   VCID: 77AB172F2FC8B21F40E-8022
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000858605801
   Coding: 26000096863CAFE00100488300003D0D0F1CC70826090221000008004400010200040020000000
   VCID: 7AAD0E1B1CDAAF773F0-802E
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 140709  H12 0050
   Serial number: 90243014140703110713
   Coding: 01DD13
   Serial number: 22923509
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001707141695
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R915603
   Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 59190C37000000000001
   Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NED12B4VG
   Coding: 30373431343238313230554A304C38523053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4CC198C3064EE1C7DDC-8018
   Serial number: 6334MSME477C2A70M
   Serial number: 6344MSME4829717AM
   Serial number: 6352QSME5F431170D
   Serial number: 6362QSME3343484AH
   Serial number: 63732SME7142485A/
   Serial number: 63832SME3643455A/
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NGP000WH
   Coding: 000017
   VCID: 48C9A4D312B60DE7F94-801C
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 930 T    HW: 8R0 920 930 T
   Component: KOMBIINSTR.   H35 0564
   Revision: 00200000    Serial number: ZD446AN7F
   Coding: 8B8622000A010008020000
   VCID: 45D7ADE725A4108F022-8010
   Part No SW: 8R0 907 468 M    HW: 8R0 907 468 B
   Component: GW-BEM 6CAN   H11 0060
   Revision: 1X120029    Serial number: 2941X1431101AA
   Coding: 80CF07FF00
   VCID: 49CFA1D709BCF4EFE6A-801C
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 2888603903
   Serial number: 14204001547021200181
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   VCID: 392FD117595C646F76A-806C
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000109887833
   Coding: 01581B00000000000000
   VCID: 42DDB6FB348A27B7270-8016
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Component: SWA Master    H05 0071
   Serial number: 0338316002
   Coding: 010211
   Shop #: WSC 06334 000 00000
   VCID: 3FDBBF0F47F84A5F48E-806A
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0340367285
   Coding: 010211
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000110105586
   Coding: 011D13205E00440004
   VCID: 4FFB8FCFF7D8DADFB8E-801A
   Part No SW: 8R0 909 144 J    HW: 8R0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0014767149
   Coding: 100000010001
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   Revision: 00002001    Serial number: 0341886695
   Coding: 0126023A20FA709584A0053600040047
   Component: GTO BF  H01 0080
   Serial number: 00000000000000867730
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8R0 035 223 H    HW: 8R0 035 223 F
   Component: DSP STD       H11 0470
   Revision: 00000000    Serial number: 00000000000001
   Coding: 0203010102
   VCID: 313FE937812CAC2FCEA-8064
   Revision:             Serial number: 0000111257840
   VCID: 4EC592CBF0D2D3D7B38-801A
   Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 00000001516941
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2DCE1B5CDA6F777F0-806E
   Part No SW: 8R1 035 186 Q    HW: 8R1 035 186 Q
   Component: Con3 Sirius   H09 0471
   Revision: 00000003    Serial number: AUZ5Z6N2066670
   Coding: 040200020105870003DB270800
   VCID: 43D3B3FF2B902EBF2C6-8016
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000111162672
   Coding: 010C13204000240004
   VCID: 46D5AAEB18A21B970B8-8012
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D27C5074D74584F5A2-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000111154024
   Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005383717
   Coding: 0010370
   VCID: 3E25C20B4C724357438-806A
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 141850130
   ROD: EV_RDCMA00100_008.rod
   VCID: 2D07F5479D94C8CFEA2-8078
End----------(Elapsed Time: 02:04, VBatt start/end: 12.1V/12.3V)-----------
Which should I be looking at to detect a fw (emission) flash?
Revision:
Coding:
Shop #:
ASAM Dataset:
ROD:
VCID
Not necessary just to "detect".
Look for changes in the sections I've highlighted in blue:
   Revision: 58H14---
Lord Diesel
Canada
C?ID=341707
Just re-visiting this thread prior to taking my Q5 in to the dealer for a bit of warranty work. I am always very paranoid that the technicians will inadvertantly apply the diesel emissions "fix" to my ecm without my authorization (thus the thread on code matching above). Q: has anyone found their service center guilty of loading unauthorized emissions software on their TDI without authorization? I realize now that the second and subsequent diesel "fix" entails some hardware modifications to the emission system which might make it a bit more difficult to underatke accidentally.
What kind of warranty work?
Lord Diesel
Canada
C?ID=341707
I lost the side-assist system. Goes down after about an hour. Audi recalibrated the system...see if it fixes things (or not).
Uwe, can you please tell me what the following difference amounts to (and actually what VCID refers to.
Between scans in 2018 and now the VCID has changed.
2018 SCAN
   Revision: 58H14---
2020 SCAN
   Revision: 58H14---
   VCID: 40D9BCF33A0635AB333-8014
I was planning on using the 2018 oem flash for submission to a tuner for ``performance enhancements`` however I`m wondering if the code thats currently residing on the ECM should be submitted rather than the original. Given the delta in the VCID string I`m concerned Audi may have added some patches over time. The vehicle does not have the diesel fix installed (never will).
I`d planned on just déloading a new image of the ECM however the damn loader won`t let me save a second flash from the vehicle for security reasons. If I clear the original out of the tool I run the risk of bricking the beast apparently. Thus the question about using the 2018 image and whether the VCID means anything.
Forget VCID. It is calculated and rather than read directly from the module. Changes to VCID are expected with different versions of VCDS. I see no changes to the ECU itself between those scan snippets.
Lord Diesel
Canada
C?ID=341707
Thanks Uwe, thats all I needed to hear. Yes, I see no other changes to engine to trans so likely we're ok to use the older file. Its only been into the dealer twice since the ECM code was backed up so its not likely they would have made any major changes/recalls etc.
